Jeff Bagby's Helios CM Bookshelf Speaker Kit
2456
  • stangman67
    stangman67 Posts: 2,330
    75 dollars! In my estimation that’s not a bad price for some professional level know how
  • rooftop59
    rooftop59 Posts: 8,120
    stangman67 wrote: »
    No that is very reasonable I think…thx!
    Game Room 5.1.4:
    Bedroom 2.1
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,919
    @stangman67 Great thread about your project!
    Superb work!
    Harry / Marietta GA
  • maxward
    maxward Posts: 1,727
    I’ll second that! What is the brand of “pegboard” in your shop?
  • stangman67
    maxward wrote: »
    The whole wall is “wall control” from Amazon. Really nifty stuff!
  • Milito
    Milito Posts: 2,003
    I've got some of the "wall control" in my garage, love it.
  • stangman67
    First brace done. I used a bit larger holes than Javad did in his build. Trying to keep as much volume as possible given I am using a extra half inch panel on the side. Not sure if I am gonna add additional bracing like he did
  • stangman67
    If I had the chance to do it again I’d use a smaller middle hole and bring it down away from the driver cut out
    txcoastal1 Posts: 13,519
    Nice work
    Have you decided what you are going to use to seal the MDF before you paint?
  • stangman67
    edited April 2022
    I’m gonna use automotive epoxy sealer/primer from TCP global, and then going to use their “Dove Gray” stock color urethane base boat/clear coat system as well. A few coats of epoxy primer/sealer should lay down plenty thick and prevent the MDF from soaking up the paint
  • stangman67
    Sorry misrepresented, going to use DTM high build 2K primer to seal the MDF
    Sweet, so you're planning on using the green auto paint?
    You mentioned "or a gray" earlier. What came to mind was using the green then a slate gray pearl on top of that would be interesting
  • stangman67
    No British racing green anymore unfortunately, my wife said if I want any chance of these going in the living room they need to be blue or gray. So gray it is
    Clipdat Posts: 13,100
    Great progress so far, looking forward to seeing the finished result!
    xschop Posts: 5,651
    Im a fan. Nice work.
  • stangman67
    Adding the 1/2 MDF panel on the inside of the side baffle. This will allow me to safely recess the PR in which has a flange thickness of about 1/2 inch
  • stangman67
    Probably the last meaningful progress this weekend. May get a bit of time to work next weekend before I get underway. Then this project will be paused until early June
    Booo!!
    We hate cliffhangers >:)
  • stangman67
    A bit more progress. Both cabinets are completely built with the exception of the baffles. I will cut the driver holes before I glue the baffles, just in case. Awaiting the aluminum tweeter waveguides before I start the driver holes, I wasn’t happy with the 3d printed ones some spent a bit more coin for a finished product
    These things are huge and are going to be very heavy fully built. I’m anticipating 50ish pounds each. I really didn’t account for them being so large lol
    xschop Posts: 5,651
    Those look solid.
  • stangman67
    A bit more progress. Scary progress. Cut the hole for the first mid. Made a few practice holes and was happy, was a little more slop than I wanted in the last practice, so I went one smaller on the jasper jig and still a bit more extra space around the woofer than I wanted. Still fairly successful for my first time doing this. I figure I am going to do at least two coats of primer, two coats of base and two or three coats of clear, so that gap should close up significantly. Probably will work out great in the end
    Looking good! That's a hell of a woofer!
  • stangman67
    Thanks! The woofers are no joke, rare to see 8” woofers on “bookshelf” speakers. These things should get down for stand mounters. I’m starting to wonder if 80WPC is gonna be enough lol
    Speaking of stands, what are you planning on using to support these big boys?
  • stangman67
    I’m either going to buy some 4 leg walnut stands from Timbernation or build my own. Not sure yet, not thinking doing them myself is gonna save me much, so probably just gonna buy some. I’ll broach that once the speakers are done and I’m sure I want to/ am allowed to use them in the living room. These are much bigger than my wife is expecting lol (some jokes to be had there)
  • maxward
    Well, she can take a joke, can’t she?
    edited April 2022
    Really looking forward to when you get these ramped up. Had a similar project with Russman ie The Rooster years ago.
    Had large Morel 8" hybrid mid-woofer and Morel Soft dome tweeter. Large ported cabinet TL design.
    Pic is grainy due to lighting of our room at LSAF. The integrated was a Jolida 801 65-80watt using 6550's
    Really nice. I think you really like those speakers you are building.
    What comes to mind on playing is .... to test room resonant
    Mark Knopfler
    Shangri-La
    I'm watching this thread in excitement :)
  • stangman67
    Funny you mention Mark Knopfler, I’m jamming to “sailing to Philadelphia” on repeat right now on the Focals. Really lovely stuff.
    Thanks for sharing, I’m sure those speakers sounded great, morel makes a fantastic driver. And yes I am really enjoying this build thus far. I enjoy a good project from time to time, usually it’s house stuff so it is nice to do a project surrounding one of my hobbies
  • stangman67
    edited April 2022
    Got the CNCed aluminum waveguides for the tweeters in. These things are awesome! Next update will be in June
  • stangman67
    Found a day to make a little progress. Did one of the tweeter cutouts done. Baffle 1 is now complete. I’ll try to get the first speakers passive radiator cut out today too and then I’ll glue the baffle on the cabinet
    Speaker 2 needs its two baffles glued together and all speaker cutouts done.
    Then I will move on to crossover/binding post mounting and then onto the painting process
