1133134136138139185
    mhardy6647 Posts: 33,092
    edited March 2022
    I had some time* -- and some fairly hefty metal strapping-- and a hacksaw...
    so...
    finally...
    today I did a little redneck New Hampshire frugal Yankee style time alignment of the 'super' tweeters on my much-beloved Frankenaltecs. :cool:
    Before:
    Somebody... somewhere (ASR, IIRC) kinda constructively busted my chops about my, umm, opportunistic tweeter mounting, umm, opportunity, so I've been meaning to do something about it.
    After:
    You know -- I really am lethargic... so this is, like, a major achievement for me, OK? :confused::o
    _____________
    * see what I did there?
    :p
  • DividedSky
    DividedSky Posts: 108
    DividedSky wrote: »
    A couple of examples here
    Follow up from MapleShade... the Ambrosia Maple has holes in it. Either from a beetle, fungi or possibly both. I will include one section from their email. I'm sure there will be some chuckles regarding mention of the holes resulting in enhancement of sonic performance.
    "What is Ambrosia Maple?
    Ambrosia Maple is the traditional name for a form of red maple found locally in Maryland and Virginia. It has distinctive long, tapered streaks running with the grain, streaks of a contrasting brownish or slightly purplish-grey hue. This striking coloration is also sometimes called Ghost Maple or Wormy Maple. At the head of each of these beautiful streaks is a pair of tiny holes bored by the adult Ambrosia beetle in which to lay its eggs—and to simultaneously lay down a unique fungus species. The eggs hatch into larvae that are incapable of digesting the maple; instead, they cultivate and feed on the fungus which flourishes by digesting the maple for the larvae, a remarkable example of nature's symbiosis. The tree's sap carries away the “runoff” from each larva's miniature mushroom farm, thus creating the pattern of lovely long stains that characterize this unique form of maple. There are no larvae left after the 3 to 6 years of drying; they all develop into adult beetles and fly away within a couple of months after the eggs are laid in the living tree.
    The small holes and their associated streaks appear to varying degrees across all of our maple products. Besides their striking looks, they actually slightly enhance the maple's sonic performance. Because of the inherently variegated grain and patterning of Ambrosia maple, every platform, stand and shelf we manufacture is unique. We show a representative sampling of these natural grain and coloring variations in our Ambrosia Maple With Clear Finish Gallery."
    Primary: Doshi V3.0 pre and phonostage, Vandersteen M5-HPA, Vandersteen Quatro CT, AMG viella, Goldfinger Statement, AQ Niagara 5000, AQ IC and power cords, Mapleshade Samson V.5
    Secondary: Nakamichi PA7, Nak CA5, Polk LS90, Sota Sapphire, Sumiko MDC800, Van den hul Crimson
    F1nut Posts: 49,855
    This quote from their site kind of cracked me up.
    Coloring maple is surprisingly tricky; standard wood stains give very mixed results. So we hired a finishing specialist to work with the Amish to develop for us special toned finish blends with a multi-step finish tailored to the unique problems of staining Ambrosia maple.
    While it is true that coloring maple with pigmented wiping stains yields unsatisfactory results the "special toned finish" comment is well...not so special. It's done all the time by furniture manufacturers and restoration/refinishing businesses. A dye is added to the clear coat and the mix is sprayed on. This results in a very even color tone over the entire piece because the color is in the finish not in the wood. It also results in greater transparency and depth.
    F1nut Posts: 49,855
    edited March 2022
    I'm going to comment on this also.
    I do not believe maple has any sonic performance advantage over any other wood species. If anything, MDF would be a better choice than any wood species due to density and in particular, uniformity.
    A side note and personal observation. At every CAF I've been to the Mapleshade room sounded worse than any other.
    Clipdat Posts: 12,622
    They have a lot to say about the subject:
    "Maple's sonic superiority over all other woods is old news to every violin and piano maker since Stradivarius and Steinway. Instrument makers taught us to NEVER use commercial, kiln-dried maple. The kiln's high heat weakens the wood's fibers, thereby deadening sound. Air-dried maple is less colored and closer to the sound of our master tapes than any other platform material—audibly better than harder or softer or denser woods, and notably better than kiln-dried maple or, worse yet, maple butcher blocks (excessively damped by their multitude of glue joints and their kiln-drying)."
    • MDF is the worst sounding wood product; it kills treble, smears detail and produces thuddy bass. Plywood is a slightly better but still way behind solid maple.
    • Glass, granite, or slate are even worse sounding than MDF and make treble sound harsh while weakening and dulling the bass.
    • Hi-tech damped composites strongly deaden overtones and dynamics.
    • Myrtle or exotic tropical hardwoods sound better than plywood but are tonally colored and suppress detail.
    F1nut Posts: 49,855
    They aren't making musical instruments.
    I believe they consider the equipment rack and/or speaker stands to be an instrument of sorts.
    VR3 Posts: 28,106
    Musical instruments need resonance and tone. Pretty much the exact opposite of what you would want in an equipment rack.
    But I also have my gear sitting on ventilated closet shelving, so there's that
    You heard it here first, putting your gear on wire racks make for the best sound.
    VR3 Posts: 28,106
    I agree! 😜
  • maxward
    maxward Posts: 1,524
    From what I recall from the Mapleshade catalog, the late Pierre Sprey was so over-the-top enthusiastic about the sonic qualities of his maple products that I could not believe what I was reading. It likely prevented me from trying some of his other offerings.
    treitz3 Posts: 18,404
    Anyone else smell that? It......it smells a bit like snake oil and the smell just got pungently strong on this particular page of the thread.
    The only thing I can smell is @Hermitism's Wireworld cables, that damn stench is permanently etched into my brain.
  • BlueFox
    BlueFox Posts: 15,251
    I love my Mapleshade rack, and it is a 1000 times better than my old rack. However, when I bought it in 2013 I had different gear than now. If I was buying new I would get a 5 shelf single wide rack, and two one shelf platforms for the amps, but I can live with the current rack.
    Old rack.
    New rack
    nooshinjohn Posts: 25,132
    edited March 2022
    Today I pulled my Arcam AVR30 out of my system and returned it to Best Buy. This is the second unit I had in my system and it suffered the same failure as the original one dead. I lost signal to all my HDMI connections to the point where the TV would flash on and off almost like a red light at a stop sign. After rebooting the AVR it lost all of the DSP information that needs to process signals.
    These units have been nothing but trouble for Arcam from the beginning and I am almost embarrassed that I even tried these things. The people at Magnolia have been very very helpful and are getting a brand new in the box AVR 20 which has been less problematic than the AVR30 have been. Hopefully this will work out better than what I had in the first place because it still has the same preamp sections as the AVR30 had. The difference is the AVR30 uses class G amplification whereas the AVR 20 uses AB.
    The bad news is my rig will be down for a week and a half to two weeks while I’m waiting for the new one to come in.
  • jbreezy5
    jbreezy5 Posts: 1,141
    Bummer! I know you like the sound, But I’d run after 2 failures.
    That was my initial reaction to. Arcam has a new lineup coming so I was able to get 1500 off the AVR20, in a sealed new box. If it fails I am back to square one, as the new line is a thousand dollars more across the range.
    F1nut Posts: 49,855
    Arcam whilst known for their sound quality is unfortunately more well known for their gear failures, particularly their AVR's. You might consider looking elsewhere.
    I already have... thinking Yamaha CX-a5200 or the Marantz 8805a
    Don't get the Yamaha. Your ears will thank you and you would just be wasting your time/money. I know they market, "Natural Sound" but they are nowhere close to it.....and IME? Completely underwhelming.
  • displayname
    displayname Posts: 1,136
    Will this new line likely be the first full line to be produced since the Samsung acquisition? I believe they released one line since that happened, but I think it was pretty much done and set to launch before that acquisition was finalized.
    Analog: MoFi MasterTracker > MoFi UltraDeck > Sutherland 20/20
    MastersounD Dueventi > Rosso Fiorentino Certaldo or Arcam rHead > Hifiman HE4XX
    Discogs
    VR3 Posts: 28,106
    I have a Yamaha 3070 for HT, it does a great job for theater. For 2 channel though, definitely no where close
    Agreed. Perhaps I should have clarified more. His use would be for both. While he may like it on the HT side of things, I don't think he would be impressed at all for his current speakers on 2-channel listening.
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,086
    From history regarding lots of things:
    ONCE BITTEN, TWICE SHY!
    Harry / Marietta GA
    I prefer third times the charm...
    how do you feel about:
    The early bird gets the worm,
    but the second mouse gets the cheese
    B)
    PS and now I've got that Ian Hunter/Mott the Hoople song (also covered by Great White) stuck in my head, too... :#
  • xsmi
    xsmi Posts: 1,797
    Added the black anodized aluminum trim to my XPA-2. The original owner preferred the silver, removed the black and lost them before he sold it to me. The black seems to classy it up a bit.
    2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
    treitz3 wrote: »
    The CX-a5200 is a pre/pro. The problem I have had with Yamaha is their amplification, as it is very dry and sterile sounding. Given that I will be using my tube amps and a different brand of 7 channel amp for the rest, I am thinking it might work.
  • ZLTFUL
    ZLTFUL Posts: 5,640
    treitz3 wrote: »
    Hey John.
    I started my HT journey with Yamaha. I have now had 2 different Marantz pre/pros since and would highly recommend the 8805A over the CX-A5200.
    In fact, the 8805A is what I currently have running in my theater and it does an amazingly good job with anything I throw at it acoustically. I would even go so far as preferring it when specifically listening to 5.1 mixes of stuff vs listening to the same mixes downmixed to 2.1 in my 2 channel system.
    In the end, obviously, your ears are your ears. But coming from someone who used to be a pretty heavy Yamaha fan-boy, go Marantz. You won't regret it.
    Thanks for that input. While I am looking into other options, I am still going to give the Arcam AVR20 a fair shot in my rig. The AVR30 was stellar until it went belly up. I am hopeful the replacement will be up to par as far as reliability goes...
