Must try MOD - Foam inside the stamped steel baskets - YES!
1…34689…12
  • benjaminlea
    VR3 wrote: »
    Guys... I love the passion but you are entering trolling territory
    You’ve come at the wrong time. We were actually chasing the trolls away.
    Polk 7B’s modded
    Velodyne CT 100
    Rega Elex R
    RME ADI2
    Eversolo DMP A6
    Pro Ject Audio Carbon Debut
    Schiit Mani 2
    MacBook Pro
    Apple Music
    Tidal
  • Gardenstater
    Gardenstater Posts: 4,922
    edited February 2022
    He gave his experiences to share a positive outcome and got denegrated for it through a LOL.
    I'm shocked that Polk went with stamped steel baskets on the new models I have seen, although they did try to make the geometry of the *uprights* so as not to reflect back at the cone so much, or at least that was my impression.
    I hope we can keep this thread as a Check Your Egos at the Door zone.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • mrbigbluelight
    VR3 wrote: »
    Well...wrong. 🥰
  • plastic_avatar
    The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
    xschop Posts: 5,800
    There is a pic somewhere on the forum showing a base plate ripped from an MW frame. Been searching to no avail. I remember seeing it a couple years ago. Maybe in Vanilla archives?
  • Gardenstater
    xschop wrote: »
    I'll look for it too. Pizza slice wedges of foam applied through that hole and stuck on underneath the spider if feasible. Would be super cool what effect that could have. But would VC have to be removed and re-installed ? I'm thinking yes but maybe you could try it on one of the ones you are working on that have fried VC's.
    Just look at the rave reviews the KEF Meta tech is getting!
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,800
    I'm thinking stuff the void/chamber with lamb's wool possibly?
  • Hansvelton
    Hansvelton Posts: 151
    xschop Posts: 5,800
    Hansvelton wrote: »
    Par for course here at the CCP.
    xschop Posts: 5,800
    edited March 2022
    Vandersteen mod is done and glue drying...
    I would only do this to a burnt voice Midwoofer before replacing the coil itself. Good luck doing it any other way.
    The MW 6500s have VERY little VC-baseplate gap clearance than all other MWs I've measured (1.070 vs 1.085), so I opened this one up to match all other MWs to prevent VC rubbing.
    I added a little extra Power Grab to the central circumference to make sure the small voids around the protruding baseplate rivets filled in as I pressed it in. I simply scrolled it in and it went in without hassle and sits perfectly in the inner chamber on raised basket frame...
    I cut the 1/8" thick PVA 2.50" OD and 1.1" ID using the same cutter I used on the phase plug felts.
    The diagonal cut on the foam allows for final adjustment away from baseplate ID where Voice coil travels....
  • Gardenstater
    edited March 2022
    The spiders are remarkably gauze-like and therefore somewhat transparent to sound. I held one of my dismembered....disassembled baskets up to the direct sunlight coming in through the kitchen window and I could see through the spider into the space beneath including all the features thereof and it is pretty *cavernous*. I was surprised at that for a driver with a max excursion rating of around 3mm.
    Can't wait to hear some listening impressions, however you may not have a XO that is compatible....?
    PS: I wouldn't be surprised if the sound is more.......emotionally engaging.....with a touch of nutmeg even.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,800
    edited March 2022
    I will wait til another burnt 6500 rears it's ugly voice coil lol
    I will hold off from phase-plugging it until I get another donor.
    xschop Posts: 5,800
    Now that Ive dissected this thing, the spider and surround look and feel exactly like the 6510, which happens to be about same ohm DCR.
    xschop Posts: 5,800
    6500 is done, vestigial tabs evicted too...
  • mordar
    mordar Posts: 1
    ... Regarding the basket acoustic treatment, I seem to recall some speaker baskets produced with a rough textured black undercoating type material on the outer basket...anyone? Also would like to see a before and after frequency response of just the basket treatment mod.
    F1nut Posts: 52,391
    Feel free.
  • Gardenstater
    mordar wrote: »
    Sounds like it is just a damping compound, trying to get a similar effect to what we're after with the Dynamat Xtreme or other similar product. I think Soundcoat is a material that comes in a can and can be rolled or brushed on. Could make a real mess if you weren't careful and it wouldn't be constrained layer damping because it wouldn't also have the aluminum layer on the outside.
    mordar wrote: »
    I'm assuming you mean the inside the basket sound absorbing material. It'd be technically interesting and I think you would see a difference if you had the right equipment and method but I doubt that you'd be able to look at the two curves and go.......see there.......look at the greater transparency and detail and separation of vocals and instruments. You have to use your ears for that.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • lms
    lms Posts: 54
    Two weeks ago, I did this to one of my CRS speakers, both drivers. I don't have the ability to speak the way others do in regard to statements like, more air, etc. All I can say is this... After two weeks it's apparent that the speaker I didn't do this to has more "shout" to it. LOL, it sounds louder and mids are tad more in your face. The one that I did do this to is mellower sounding, which I like. And that's all I have to say.
  • Gardenstater
    If your experience parallels mine, you will have the magic come in when you do the other speaker as well. Things need to be balanced. Let us know how it works out :)
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • JayMX
    JayMX Posts: 464
    edited March 2022
    I put my Monitor 4’s under the knife the other day. Figured since I was doing the whole Monte I’d give the inner foam thing a shot, just to see if it made any difference. Now, I did re-cap and damp the baskets with Noico all at the same time. Overall, I am just blown away how much better the speakers sound. Warm, but clear, tons of detail. Female vocals are lush. Norah Jones, more please. I’ll do my 7B’s when I do my rework of them and report back. Fun experiment. I think it has some merit! 🤘🏻
    It’s in there, Armacell, kinda tricky to fish it in there but not too tough to do.
    Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL (198’s), R100's, R200’s, R300 🤩
    Pairs that have passed through: Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5B (Peerless), Monitor 5b (SL1000), Monitor 5b (SL2000) (4x pair), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s), Monitor 10a (Peerless), Monitor 10b (5x pair), RTA8, RTA8TL, RTA 11T, RTA12c (194's), SDA1(mod to “a” & SL1000 Wuhan mod), SDA CRS, SDA 2 (2x pair), SDA 2a, SDA 2b, SDA 1b, SDA 1c, SDA SRS 2 (2x pair), SDA SRS 3.1TL (198’s) (2x pair)...and more to come, it’s a sickness.
  • gp4jesus
    gp4jesus Posts: 2,019
    mordar wrote: »
    Pre & post mod measurements may parallel those of IC, speaker cables, and/or power cable upgrades/swaps
    *all connected w/Premiere ICs
  • Gardenstater
    gp4jesus wrote: »
    mordar wrote: »
    I think THD measurements similar to what @DarqueKnight did with the tweeters in his epic thread "A Tale of 5 Tweeters" would probably show something beneficial.
    @JayMX way to step up to the plate and those are great little bookies! Did you also do the section between the spokes/uprights, by the spider? I really think that's not to be neglected and is not an insignificant amount of surface area for reflection back at the cone.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • gp4jesus
    Look carefully at JayMX’s last pic - he did the spokes. He’ll hafta say how close he got to the spider.
    @JayMX: you did use plain foam inside the frame. At least it looks that way from the pic.
    Regardless ENJOY! Tony
  • Gardenstater
    I'm talking about this area, in addition to the spokes:
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • JayMX
    JayMX Posts: 464
    Correct. I did not cover the rear perimeter/lip of the basket adjacent to the spider. I’ll do that on my 7B’s when the time comes.
  • gp4jesus
    edited August 2022
    Some “foaming” on the inside of an RTi A7 mid that Rob (xschop) just finished “pluggin’” recently. Look for it mounted on my Tri-amp ‘7 thread
  • plastic_avatar
    Here's a question:
    Would foam be detrimental to a passive, because its sound generation is from the air behind the membrane- since it's not generated by the cone itself?
    I'm 'matting the exterior of the baskets of mine (man, they're flimsy). I don't plan to foam them, but might 'matt the interior of the arms, just to add mass to dampen basket vibration even more.
    Anyone played with this?
    [in progress]
    pitdogg2 Posts: 27,893
    Really no need to do inside the basket. Most of us have all done the passive.
    xschop Posts: 5,800
    edited October 2022
    Dyna-Mat/butyl matting the inner frame spokes would be ok.
    My 5B PR baskets are inner-frame butyl matted. Foaming would be unnecessary as there are no midrange reflections to deal with from the passive. The passive is pneumatically decoupled from any midrange frequencies as well.
    P.S. Post edited and spell-checked for F1's peace of mind.
    F1nut Posts: 52,391
    edited October 2022
    A little Dynamat or the like goes a long way, there's absolutely no reason to cover every square inch and none should go inside the spokes.
