Musical Fidelity Tri Vista integrated
    Toolfan66 Posts: 18,412
    They don’t have a clue!!
    "Their techs "? Wow....
    F1nut Posts: 52,381
    Don't touch that one.
  • tratliff
    tratliff Posts: 1,891
    edited March 2022
    Yeah. I’ve bought and traded a couple of items with/from TMR but I would be out on this one. Surprises me on the replies. Tells a lot about the knowledge and research of the items on the site.
    2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables
  • jdjohn
    jdjohn Posts: 3,439
    Sadly, this casts a little shade on TMR...at least for customized items.
    nooshinjohn Posts: 26,138
    I have zero experience with TMR or the Tri Vista. Apologies to those tempted by my post... I had no idea there was anything amiss.
  • erniejade
    erniejade Posts: 6,327
    Again, to me, if a pro did it, I want to know who made the mod. A pro in my opinion, would not make another set of outputs both the same color, and what could they have tapped off of to do this that wouldn't mess with the sound?
    VR3 Posts: 29,731
    edited March 2022
    So the tri Vista, my understanding of the schematics that audio plus sent me is this.
    The preamp section of the tri Vista has one input and two outs by design. There is a control board that operates relays to decide which input the preamp sees. See my crude drawing.
    So there are a million ways he could have randomly wired another set of outs by just running a positive and negative lead off an out. The problem is I don't believe the tri Vista preamp section is designed to run three output signals at a time at its output voltage but I could be wrong.
    When not in use it shouldn't change the signal.
    I'm not an electronics engineer so I could be off base on how the preamp section works.
  • TroyD
    TroyD Posts: 13,124
    That’s pretty sexy, actually.....
    What gets me is, they apparently were too lazy to just pop the top and look. Those extra pre amp inputs could not even be wired up. If they are too lazy to pop the top on a piece this valued, what does that say for other items they sell of lessor value. What they just turn it on, make sure all controls work and that's it? That's not "tech work", a 5th grader can do that.
    msg Posts: 10,639
    I'm a big MF fan, and nice to see this pop up, but I'm glad you guys are passing on it.
    I understand the temptation due to rarity, but they're asking a premium price for this. It's a little beat up with no known history, no oe box and packing, and no solid history/explanation on that mod. As mentioned, I'd want to see photos of its implementation first hand to judge for myself whether I'd be comfortable moving forward with it.
    It likely works fine and/or could be restored to original if what Trey posts is the likely path to creating the additional preouts, but all of these things together devalue the piece significantly for me to the point that it would be a pass. I wouldn't even take it at $1500 because I'd always be wondering whether I was getting the proper experience.
    Most of us are pretty serious about gear. I don't like my stuff molested. This could also be a hard sell down the road should one decide to move it, not to mention, paying the premium just to get it in the house.
    Another one will turn up that everyone can feel good about.
    I requested a picture of the inside where the mod is done..
  • erniejade
    Toolfan66 wrote: »
    I went to MF's website it it re-directed me for support from a USA distributor : ticket@focal-naim.com. I did send an email to see if they have any kind of record of a modification to the unit.
  • jdjohn
    jdjohn Posts: 3,439
    Looking at that internal pic above (even though it is not the actual unit in question), is it common to have RCA connectors inside an amp like that? Seems like an odd design choice versus simply direct wiring.
  • erniejade
    Hello Brian,
    We have no trace of this unit here. Sorry !
    The extra RCAs do seem to be of very high quality.
    What would be really helpful would be a photo of the inside, showing where these RCAs are connecting to.
    If they are simply wired in parralel with the original PreOuts, it would be perfect.
    MICHEL ROUSSEAU
    SUPPORT & SERVICE
    USA 1 800 663 9352
    F1nut Posts: 52,381
    jdjohn wrote: »
    Very common.
  • CottageChz
    CottageChz Posts: 424
    jdjohn wrote: »
    Funny, I had wondered this same thing just last week when my friend sent me a pic of the innards of his Music Hall Mambo and I spotted RCAs. So it does seem common like @F1nut says.
  • BlueBirdMusic
    BlueBirdMusic Posts: 3,100
    We shouldn't let those two RCA terminals divert us from thinking about what other mods might have been made that are not apparent.
    Harry / Marietta GA
  • erniejade
    Agreed.
  • erniejade
    edited March 2022
    I got pics. Looks like they used Monster cable inside. I sent them to the Musical Fidelity distributor as well.
  • erniejade
    I got the same pics from Ben. So my question wouldn't splitting that off like they did change the sound quality and impedance since they tapped it off of mains? I see he said it doesn't effect the operation as an integrated but, I would think it would change the sound some? I am not electronically inclined, I am making a guess on the alteration.
    Anything Monster in a MF is pretty laughable IMO!!
    VR3 Posts: 29,731
    Eewwwww a splitter ewww
    Clipdat Posts: 13,104
  • erniejade
    VR3 wrote: »
    Had to read that twice. I first read it as a spitter >:)
    VR3 Posts: 29,731
    Assuming! They didn't dick around with anything else, that is easily reversible
    F1nut Posts: 52,381
    I guarantee that monster cable degraded the sound.
  • erniejade
    "Michel Rousseau , said 37 minutes ago
    Hello Brian,
    It all looks very good.
    I had our own tech examine the work and it looks professionally made with high quality components.
    That extra pair od RCAs is in fact an Input.
    It should be labelled as Power Amp In, rigt next to the Preamp Out.
    This makes it possible for you to use the unit asa stand alone Preamp with another Amp, or only as an Amp with another Preamp.
    Again, the work was well done and should not affect the unit's performance.
    It would still be a good idea for you to listen to it before you buy, just to confirm.
    My best
    MICHEL ROUSSEAU
    SUPPORT & SERVICE
    USA 1 800 663 9352 "
    I am still leery of buying it and taking a chance on it. I don't know enough myself to have it reversed or anything and would hate to spend that kind of money and then pay to have it looked at. If they lowered it down to like $1000 or $1400, I might take a chance but, again, I would want it looked at.
    Well done?? HIGH QUALITY COMPONENTS?!?!
