Post a picture... any picture
16646656676696701153
  • SeleniumFalcon
    txcoastal1 Posts: 13,519
    Hermitism wrote: »
    I'm not fully versed on aerodynamics, but wouldn't that work similarly to a parachute?
    With no front fender it would define the term mud flaps
  • BlueBirdMusic
    txcoastal1 wrote: »
    Your new guitar @BlueBirdMusic ...cute
    No, it reminded me of @afterburnt.
    Harry / Marietta GA
    mhardy6647 Posts: 35,526
    Sears SLR (ca. 1958) by Asahi.
  • aprazer402
    aprazer402 Posts: 3,458
    Next to the cee-ment pond, by the looks of that photo.
  • mrbigbluelight
    Interesting !
    You know, I wonder if....well....
    .....nevermind ....
    audioluvr Posts: 6,055
    Interesting !
    .....nevermind ....
    I know what you're thinking and do NOT try it. :D
    Call a physician if your bristles stand up for more than four hours...
  • kevhed72
    kevhed72 Posts: 5,204
  • SeleniumFalcon
    msg Posts: 10,623
    Captain Kangaroo?
    You know, to this day I'm still not able to slice an orange in half and then reverse it.
    ... and I am still mystified by why a guy called Mr. Green Jeans wore bib overalls...
  • SeleniumFalcon
    pitdogg2 Posts: 27,793
    That is hilarious...^^^
    SCompRacer Posts: 9,309
    Tony M Posts: 11,969
    SCompRacer wrote: »
    10 miles south of me, at Carolina Beach harbor, a roofer fell off a 2 story roof, head first, and stuck in the muck of the harbor bay. Somebody saw his legs later on but it was too late. He should've been wearing one of those harnesses but sadly he didn't.
  • sucks2beme
    sucks2beme Posts: 5,701
    I saw a lot of roofers at work around Dallas. I NEVER saw one in a harness.
  • aprazer402
    edited February 2022
    Well, I was told by my expert mechanic on Ford trucks of all kinds, that the bracket holding my f150 bumper probably was jarred and fell a bit from hitting a pothole. Common problem he said.
    I got out some cardboard and slid under my truck to put PB Blaster on the bolts for a day or so.
    Driver's side...PB Blaster applied...done. I thought it was in the original position to begin with. Like I said, I thought I slid my fingers on top of the bumper for 150 times over the years.
    Passenger side....WTH?
    RUSTED out bushing plate on top where the body sits on top of the frame had rusted away and the body fell down toward the bumper. The battery sits above and just to the side. Maybe the weight of Batteries sitting above the bushing helped rust it quicker than the other side which isn't that bad at all.
    I looked on-line and RUST is a common thing on these frames I see. The front-end can be taken off and then the fender to get to it. There's a few things that are rusted around there too that should be replaced.
    Grinding off some bolts, Welding a few new bracing / angle supports for that big bushing and it will be good to go again.
    My neighbor MIGHT help me repair this by using his welding skills. I hope so anyway. :) That will have to be done in the future though. :|
    In this picture before I replaced the light fixtures a week or two back , you can see the front-end sitting real close to the bumper. It probably happened when I hit a pothole hard on that tire under the battery in Nov or Dec. .
