Bob Carver Corp Crimson 275 stereo tube power amplifier.
123578
  • stangman67
    stangman67 Posts: 2,329
    It was more tongue in cheek than I can represent here I think lol. All in good fun
    nooshinjohn Posts: 25,922
    I was very clear that I was defending the man, not the company in any form. Frankie Schmaltz can KMA...
  • stangman67
    Yea I’m with ya
    mhardy6647 Posts: 35,014
    ahh, OK, cool. B)
  • From the amplifier's owners manual:
  • stangman67
    Such bs! I’m shocked someone more important than us hasn’t called Carver out on that
  • invalid
    invalid Posts: 1,455
    stangman67 wrote: »
    What about his DC restorer circuit, isn't it just used like a sliding bias scheme?
    VR3 Posts: 29,427
    If this was true i would think it would pick up all kinds of things
    F1nut Posts: 51,767
    What a crock.
    edited January 2022
    Any amp with a high output impedance "listens to the room" |(i.e., "feels" the load impedance) via the loudspeakers (probably the back EMF thereof).
    The 275 has an output impedance (well... OK... according to the specifications ) of 1.7 ohm. That's
    nearly twice the output impedance of my zero NFB SE 2A3 amplifier.
  • Also from the manual:
    hmmm -- what's the output impedance of Nelson Pass' oh-so-solid state (and not particularly abnormal, albeit single-ended and with no NFB) "Amp Camp Amp"?
    https://www.diyaudio.com/community/threads/amp-camp-amp-1.214808/
    DF of the original morph was "about 3" (i.e., output impedance's about 2.7 ohms).
    The Amp Camp Amp... is listenin' to the room. B)
  • CoolJazz
    CoolJazz Posts: 572
    h]
    Not without feedback to loop everything at the output back to the input.
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
    edited January 2022
    ^^^ That is not entirely correct -- in the sense that the high output impedance of the ACA makes it quite sensitive to the loudspeaker impedance curve, which is sensitive to the back EMF of the loudspeaker. To that extent, it sure does listen to the room! :#
    The 275 DOES NOT have the loudspeaker in any feedback loop. The ad hype for the 275 overstates and mis-states what the amp does vis-a-vis the load. Now, there have been servo drive loudspeakers, like the Philips NFB loudspeakers of the '70s that DO "listen to the room" (with their own, onboard amps in the loop), and there have been amp/loudspeaker pairs with an additional feedback loop connection (I think the LWE/Erath speakers were an example, but I'll have to check) -- but the 275's design does not do this, full stop.
    Don't give the 275 credit that it doesn't deserve.
    Read the lines posted by @SeleniumFalcon above. It's pretty clear that, between the lines, it says little more than "the 275 has a high output impedance"... which it does. The DF of the 275 at 8 ohms is 4.7 according to its specs (output impedance = 1.7 ohm, per the specs on the Carver Corp. site).
    I also rather doubt that it can repair "bad" KT120 tubes, either -- but that remarkable quality was ascribed to the 275 in its marketing blurbs.
  • CoolJazz
    CoolJazz Posts: 572
    Of course there is feedback on the 275. Right from the output (hint...attached to the speaker) and loops right back to the cathode of the input tube.
    The Amp Camp is an output device driving the speaker. No feedback so no way it loops back anything and re-injects it into the signal. That's what the "listening to the room" part is referring to.
    Apologies accepted. :)
    CJ
    Clipdat Posts: 13,095
    edited January 2022
    FMalitz wrote: »
    I laughed when someone wrote me and asked what DAC and compact disc player Bob would recommend. Bob has never seen a forum.
    Hmmmmm.. But yet he supposedly just posted on ASR's.
    Maybe instead of info@bobcarvercorp.com disgruntled customers should be emailing fmalitz@comcast.net
    F1nut Posts: 51,767
    edited January 2022
    Please don't invite that blowhard bozo back here.
    CoolJazz wrote: »
    CJ
    Yes the 275 has NFB.
    No the ACA doesn't.
    Both amps have low DF (high output impedance). Do you know what that means vis-a-vis a reactive load?
    Hint: NFB is all about the amplifier (decreasing HD, increasing flat response bandwidth) and not the load. Interestingly, one of the good reasons to use NFB is to decrease output impedance, which the 275, for whatever reason, does not do.
    Ciao, bambino.
    pitdogg2 Posts: 27,045
    edited January 2022
    Bet you never went to the circus as a kid....
    txcoastal1 Posts: 13,512
    He cried :p
    F1nut Posts: 51,767
    I knocked his red nose off :p
    I always wanted to see a grudge match "Captain Kangaroo vs Bozo" winner takes on Mr Rogers >:)
    txcoastal1 wrote: »
    Barney the Purple Dinosaur for the win...
    txcoastal1 wrote: »
    Big Bird takes out Barney
    txcoastal1 wrote: »
    txcoastal1 wrote: »
    And Yosemite Sam drops the Bird...
    tonyb Posts: 33,072
    edited January 2022
    At least Bob responded, if indeed it was Bob, and offered up refunds for anyone feeling like they got shorted. What else can he do really.
    Future buyers of his products are going to wonder now, with this creative marketing scheme, and past products still gracing peoples homes will start getting looked at cross eyed. Needless to say, this debacle has put a huge dent in his reputation.
    The good news is....lots of used 275's gonna be on the used markets alot cheaper. Can't say I'd kick one to the curb for not having a safety ground connected.
    txcoastal1 wrote: »
    Ever see Nine Months?
    https://youtu.be/yMnW0W5Aqy8
    (some language and violence -- albeit goofy violence)
    edited January 2022
    tonyb wrote: »
    I do believe it was the real Bob (FWIW), but of course his response was carefully worded. Nothing wrong, nor surprising, about that, but we're not (no surprise) gonna get a heart-to-heart with him about how he heals tubes or listens to the room with an amplifier (and not, presumably, using microphonic tubes).
    The whole affray is (again, no surprise) ugly and regrettable.
