Post a picture... any picture
16526536556576581153
    VR3 Posts: 29,635
    Yeah need a tub like 4 times that size and more space in the openings
    Otherwise cool vision
  • soundfreak1
    soundfreak1 Posts: 3,414
    treitz3 wrote: »
    Dear lawd, some people's kids....
    No "form follows function" there
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • motorhead43026
    ^^ I agree, would be easy to remove.
    Toolfan66 Posts: 18,295
    Toolfan66 wrote: »
    @Toolfan66, this is coming up for auction soon.
    Art by (and SIGNED, numbered 138/250 and doodled (flaming skull) in pencil by) Emek, extra-thick flat stock silkscreen poster is in near mint (A- to A-/B+) condition; really nothing more than a fairly small semi-pronounced pinch crease in the right margin and that's pretty much all there is to speak of... a pretty sharp-looking example of Emek's oft-requested "Cyberman" Tool poster from 2006.
    It will go for stupid money $3k-$5k if the foil variant my guess would be knocking at $10k
    edited January 2022
    treitz3 wrote: »
    pitdogg2 Posts: 27,606
    In a pinch I thought that fuse was ingenious. As long as it is the same value fwiw
  • SeleniumFalcon
    If Paul Klipsch made pianos.
    mhardy6647 Posts: 35,403
    ^^^ stealin' borrowin' that one! :)
    Meanwhile -- at least in northern New England, it's quite brumous today. :#
    Thanks I had to look up brumous :p
  • soundfreak1
    So what's it mean????
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    I looked it up...it means crappy
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    edited January 2022
    soundfreak1 Posts: 2,939
    12:32PM
    is that another adjustive B)
  • soundfreak1
    Ya gotta love capitalism. Wish I had thought of that!
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • Milito
    Milito Posts: 2,003
    Tony M wrote: »
    A co-worker gave me this truck many, many years ago (15+) because he liked my truck and saw this at a store.
    This truck has all wheel friction drive. You push it and it goes and goes... It was green. I was bored after trying to do some work in the front room sealing those ceiling board joints since they opened up a little. I can't reach any higher without putting my scaffolding back up.
    I saw this truck and thought...I've got primer and white spray paints. Do it. :D
    I did ok taping, but I sure wasn't trying to do contest level prepping.
    After sanding, priming and painting the white.
    Getting the side ready for metalflake blue. I taped it off and then sanded, primed and painted.
    This blue is close to what's on my truck. The blue on my truck is micro-metalflake.
    I really liked FINNALY painting this diecast truck to look kind-of like my full size one.
    From a distance, you can't see the flaws. The flaws will be fixed when I go to paint the black side trim with the chrome center. This diecast even has 3 ridges for that side trim layout. The tailgate has to be detailed also. The front of the hood and one rear side bottom needs more white paint. The windshield trim needs to be chrome along with the the side mirror's fronts. I just saw the rear taillights. I need red too.
    4zcau2bhaagy.jpg:)
    Nice job!
    Here's models of the cars I had in high school. Correct colors on both and accessories, but don't look to close at the workmanship as I'm not the model builder I use to be. Hard to paint a straight line at my age.
  • mrbigbluelight
    I always wondered what you'd get if you crossed a Rottweiler
    with a bat.
    Pretty potent Woof Woof I'd say.
    Might want to have it tested for any contagious infections though. 🦇😷
    Tony M Posts: 11,881
    edited January 2022
    Those are some great high school cars for sure.
    Your paint jobs look great from here. ;)
    @Milito quote;
  • CH46E
    CH46E Posts: 3,595
    edited January 2022
    Found out that Kennedy Space Center has a steady supply of E85 fuel. Very hard to find in Brevard County. Been driving 60 miles for it. Now I can run a E50 blend tunefrom ZFG Tunning. Now I have about 525HP. So much fun on this tune. It breaks all four 275/45/21 loose when it hits second. Pretty sure I'll end up in jail soon.
    Post edited by CH46E on
  • BlueBirdMusic
    coffee table from somewhere else
    Harry / Marietta GA
    ooh, I like that turbo take up reel!
    I'll bet that rascal churns up quite a breeze when fast-winding! B)
  • SeleniumFalcon
    Probably thinly slice cheese with that.
