Must try MOD - Foam inside the stamped steel baskets - YES!
    xschop Posts: 5,692
    edited December 2021
    I've since found a thicker aftermarket butyl mat that I'm now using. The original 6502's that I ever matted (@ 3 yrs ago) still have the power grab/butyl mat because the original mat adhesive was dried at the time. I tried recently removing it to add the new thicker butyl mat. It would not budge...
    I'll also add that for the fiberboard enclosure back walls on the modded 5Jr's Ive done, I had to paint/primer to get the foam pad adhesive to really stick.
    From a chemical standpoint, the formaldehyde glue of the particle board oxidizes over time to a thin layer of yellowish dust (formic acid).
  • Gardenstater
    Gardenstater Posts: 4,867
    Thankfully no I did not put the foam on the inside of the spokes.
    Ahh I think we found your problem.
    I'm highly doubtful I'd be able to hear a .4 db change perhaps not even 40 years ago. Kudos to you for having such acute hearing and hopefully the armacell has a much better grip and stays in place for your mod.
    I'm not sure I heard the sPL difference (ehh actually I did because the center image was a bit skewed to one side). What I heard was greater clarity in vocals. That of course isn't the only area but that is just what came to my attention first. It was only when I did the other speaker too, and rebalanced with whitenoise again that I went, WHOA what the hell this sounds fantastic. Everything has greater clarity and nuances. Vocals and piano especially but everything.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    Toolfan66 Posts: 18,335
    VR3 wrote: »
    Fwiw, having Sean's 1.2tl here, even cleaning the cabinet walls, black hole 5 was coming off after a month. I ripped it back off and used power grab to reattach and even two months later was super secure
    I don't recall having that problem, maybe I should pop mine open and just double check..
    xschop wrote: »
    Hopefully he doesn't consider the uber-mods naughty. I may never know what potential the XS-0198's could have achieved...
    What is going on here? did you add a chunk of aluminum on the back of the magnet??
  • motorstereo
    motorstereo Posts: 2,402
    So it would've been better to have the strips fall off from the inside of the spokes? :)
  • Gardenstater
    Ha ha no that isn't what I meant. I was referring to the fact that you said you didn't notice any difference in sound. This mod is about putting it inside the basket only, in order to absorb some of the backwave that would've mostly bounced around inside the basket and some of it would be perceived as distortion when it hits and transmits through the back of the cone, conflicting with the desired audio signal expression.
    That stuff you used and what I used is not at all what you want for damping of mechanical vibrations. And also speaker enclosure volume needs something much more substantial and thick like the 6" x 6" BH5 to notice any appreciable amount of standing wave absorption etc. in my opinion, and born out by your experience. I also doubt that weatherstripping foam is at all the right stuff because it has a smooth shiny skin on it usually (at least the stuff I have used), to make a seal against a window or door. The Armacell by the way, is closed cell but it isn't smooth or shiny.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • motorstereo
    VR3 wrote: »
    No doubt this is the best way to secure them. My way was to use my air stapler and shoot a couple of staples into each strip so I could button the speakers right back up. I also cleaned the backs first with lacquer thinner. One of the strips was just a tad crooked which I unsuccessfully tried to reposition as that adhesive held tight despite my efforts. I felt that any more tugging on that strip would've resulted in taking off some of the wood with the adhesive and I certainly did not want that. Being that I'm not a fan of opening up my speakers I wanted to be doubly sure there would not be a problem like the falling foam strips were. After reading about your issues I'm glad now that I did secure them a bit more.
    xschop Posts: 5,692
    Toolfan66 wrote: »
    xschop wrote: »
    Those are back-chambered RDO's with lamb's wool in the chamber and pole-piece.
    I re-posted the pic because this mod mirrors the same mechanical concept/backwave correction that Gstater's basket frame mod is accomplishing.
    xschop wrote: »
    Toolfan66 wrote: »
    xschop wrote: »
    Do you have more pics of this piece before install? Also, how are you securing it to the tweeter?
    xschop Posts: 5,692
    Toolfan66 wrote: »
    xschop wrote: »
    Toolfan66 wrote: »
    xschop wrote: »
    Where were you lol? I believe I have the only two sets back-chambered on the planet. Thanks to VSAT's enabling thread lol....
    https://forum.polkaudio.com/discussion/168239/a-real-sl-2000-hack-replace-stock-burnt-voice-coils-with-silk-diaphragm-dome/p15
    I got the oil-doped silk Wuhans sounding better than the factory RD0-194's. I can't say that about the 198's as I have now A-B'd those in the 8TLs now in the back-chambers.
    I now have Blue-Loctite with the pole-piece to billet chamber interface to answer your question.
    audioluvr Posts: 6,038
    So I often take @Gardenstater comments with a grain of salt (no offense) but this mod may be legit due to the basket being in such close proximity to the cone. I'm planning on upgrading my SDA 1C's driver circuit caps, internal wiring and speaker cable posts and may actually consider this as well. Unfortunately I won't be able to comment on whether it helps due to the other mods but WTH. Blind faith can be awesome!
  • Gardenstater
    Ha ha welcome aboard. Any port in a storm eh? No need to trust me, trust Richard Vandersteen
    https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=5073948A&KC=A&FT=D&ND=3&date=19911217&DB=EPODOC&locale=en_EP
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    Tony M Posts: 11,928
    Right under the red outlined box there is another fact about reflected waves that bounce back from the magnet and basket "being even more severe". I'd like to see more of that paragraph.
    F1nut Posts: 52,244
    No thanks, horrible speakers.
  • Gardenstater
    Oh well. I don't remember if I heard/saw them or not. I think maybe 10 yrs ago at the New York Audio Show but that was back when there were so many high end exhibitors that it is a blurr. I *think* I was impressed and I remember something that wasn't too appealing to me, looking like a red stealth fighter. Anyway, the man is definitely not one to be lazy or stupid and is not striving for mediocrity, to say the least:
    Searching for the Extreme: Richard Vandersteen of Vandersteen Audio: Part One
    https://www.ultraaudio.com/features/20090901.htm
    Searching for the Extreme: Richard Vandersteen of Vandersteen Audio: Part Two
    https://www.ultraaudio.com/features/20091001.htm
    I have to verify but these might be his driver technology licensed to ScanSpeak of Denmark:
    https://www.scan-speak.dk/product-families/illuminator/
    Post edited by Gardenstater on
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,692
    Now Bose I'd agree with, on the horrible speakers comment.
    So from the paper/patent, we can deduct that MW baskets are echo chambers and severity depends on frame to window area measurements/sizes?
    ....makes sense
    Post edited by xschop on
    Thank you. ;)
    I thought there was going to be a longer story on those reflections. :#
  • Gardenstater
    Ha ha no problem Tony. You should read the patent and look at the figures. It's pretty interesting and easy to understand and follow. It is interesting that he first shows his ideal design and then in figures 4 - 6 he basically shows what you can do with a more traditional stamped steel basket which is what we are dealing with. xschop - it would be awesome if we could get some thin foam between the spider and the basket/upper plate pole piece like in figure 5 of the patent. When you took one apart did you see how much clearance there was? Probably isn't enough but just wondering. Yes the frontal area of the spokes plus the magnet assy are the reflective areas. It is a very large percentage of the total area with our MW drivers.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    I have seen some cast baskets that have thinner spokes. I wonder if that was done for this topic of reflections.
    Yesterday, I thought about an amplifier's SLEW rate, I think it's called. Where the amp senses the back wave elec. signal and stops the speaker's movement.
    Subwoofer's servo controls do this, I think.
    xschop Posts: 5,692
    I listened to the 8Tl's yesterday at shop for a little while after them being on burn in all week radio FM channel....
    Impeccable imaging and clarity. More dynamic than the 5B's given the extra Midwoofer obviously. Incredible realism. Your mod is a keeper.
  • Gardenstater
    #170 in the figure is the foam we would want.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    Tony M wrote: »
    I think so no doubt. This patent is old and expired and anybody can do that now.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    pitdogg2 Posts: 27,691
    Are you sure you're not confusing that with dampening factor
    F1nut Posts: 52,244
    Tony M wrote: »
    No, the cast aluminum baskets have thinner spokes because that's all that's needed for their structural integrity.
    I believe you're right. ;) I think I read somewhere anything more than 50 is overkill.
    Like another member just said about time flying, it's been supersonic speed for me.
    But then again, at my age...I'm getting things wrong more often. My memory is scatterbrained it seems with all I'm doing the past few years as I got heathier. Body got healthier, brain, not so much. :D
    xschop Posts: 5,692
    Tony M wrote: »
    Plus there's less surface for reflections.
    F1nut Posts: 52,244
    xschop wrote: »
    Tony M wrote: »
    Stop.
    xschop Posts: 5,692
    Sorry F1, I've just begun. There's still performance to be had. I'll be relocating the terminal tabs next to remove them from the equation. I don't like them blocking the windows.
    VR3 Posts: 29,662
    I think you guys are over analyzing this one a little bit :-p
