Let’s see some Tube Glow!
  • invalid
    invalid Posts: 1,554
    invalid wrote: »
    Those are beautiful looking tubes all lit up. I have a pair of 6895 mercury vapor tubes (the largest one on the left) and I can only wish I had the knowledge to get them to light up. I bet they'd make a great looking night light. c4n46gg89qdi.jpg
    That is a big tube, it probably needs 5 volts and 10 amps on the filament.
  • motorstereo
    motorstereo Posts: 2,402
    Ok then; now how does one go about making steampunk night lites out of them? I'd love to see them lit up.
    mhardy6647 Posts: 35,462
    edited November 2021
    Well, you need a transformer with a 5.0 V @ (better than ) 10 A secondary. Probably not hard to find.
    The anode needs 20 VDC to ionize the mercury, apparently.
    You'll want to wear sunglasses to attenuate the UV produced by the mercury plasma -- although the glass envelope of the rectifier itself should help. The spectral line at 254 nm is intense (especially at low pressure).
    http://lamptech.co.uk/Documents/M3 Spectra.htm
    msg Posts: 10,595
    I like blubs.
    Parks Audio Budgie Tube Phono Preamp
  • motorstereo
    Thank you for the detailed advice. Now there's a little voice in my head telling me that I should not attempt this and enjoy those works of art as they are.
    Installing a kt88 one pin off is still fresh in my memory. That got my attention as the tube started vibrating, instantly turned green and then let the magic smoke out of the amp. Yes I'm thinking I'd be wise to listen to that little voice.
  • jdjohn
    jdjohn Posts: 3,426
    msg wrote: »
    I like blubs.
    That's a great pic, Scott B) Does this mean you have finally fired your vinyl system back up?
  • TEAforONE
    TEAforONE Posts: 1,100
    Aric Audio Motherlode II in the main system
    Light a normal vacuum tube's filament - safer and easier. Even better: put a string of tube filaments in series and use it on your holiday tree. :) Maybe use an isolation transformer, just in case. The filaments will get warm but not hot -- in most tubes, any way. :)
  • michaeljhsda2
    SDA SRS 2.3TL's
    SDA 2B TL's
  • michaeljhsda2
    SDA SRS 2.3TL's
    SDA 2B TL's
    ... another easy way to get cool visual effects -- get (or make*) a plasma ball. :)
    Probably goes without saying that our son took that photo, albeit a long, long time ago. :)
    https://www.deviantart.com/icouldbeahero/art/plasma-2-technicolor-28456036
    We still have the plasma ball; it's in the basement. Imagine that?! ;)
    _______________
    * see, e.g., https://www.instructables.com/Make-a-Plasma-Globe-out-of-a-Light-Bulb/ It's not exactly hard, but not quite easy, either. ;)
    msg Posts: 10,595
    jdjohn wrote: »
    msg wrote: »
    I like blubs.
    Hehe, unfortunately, Jody, that's just a poseur pic from a while back, probably back from before we started talking about those cart searches!
  • invalid
    I wouldn't use Mercury rectifier tubes as a night light, to easy to bump into and break. It would be a lot easier and safer to use a voltage regulator tube like an OD3 or something like that.
    invalid wrote: »
    Good call. The "glow discharge" voltage regulator tubes are filled with one of noble gases (argon, krypton, neon, perhaps others) which are benign (in fact, more or less chemically unreactive).
    I had to look up what gases these "cold cathode" tubes use :p so I cannot guarantee the accuracy of this -- but it sounds about right.
    https://www.tdpri.com/threads/0c3-voltage-regulator-tube-questions.314897/#post-3955886
    Pretty pictures, too :)
  • jbreezy5
    jbreezy5 Posts: 1,141
    @ZLTFUL - what a show!
    nooshinjohn Posts: 26,087
    msg wrote: »
    I like blubs.
    I believe that Budgie is out of production now, but very well sought after still. Hold on to that puppy.
  • DividedSky
    DividedSky Posts: 108
    edited December 2021
    Doshi Audio - not the best pics but love the tube magic preamp and phonostage zomxone5l4ep.jpeg
    Primary: Doshi V3.0 pre and phonostage, Vandersteen M5-HPA, Vandersteen Quatro CT, AMG viella, Goldfinger Statement, AQ Niagara 5000, AQ IC and power cords, Mapleshade Samson V.5
    Secondary: Nakamichi PA7, Nak CA5, Polk LS90, Sota Sapphire, Sumiko MDC800, Van den hul Crimson
  • cjmustang69
    Melody AN845 Integrated Amp. Tubes will keep room warm on cold days
  • Faustin
    Faustin Posts: 1,151
    Bottlehead Paramount monoblocks with 300b tubes and the 5670's replaced with an adapter and 6SN7's. Aric Audio Transcendent pre with phono stage.
  • hochpt21
    hochpt21 Posts: 5,423
    Old reliable
    Dared SL 2000a
    Dust much? :p
  • hochpt21
    Dust much? :p
    I’m doin mah best ova here
    :p:p:p
  • TEAforONE
    Faustin wrote: »
    Nice! I’m a HUGE fan of Aric’s gear! I have three of his preamps. Motherlode II, Unlimited,and an old 3.5.
    pitdogg2 Posts: 27,689
    hochpt21 wrote: »
    Old reliable
    Dared SL 2000a
    I have an early 50's Brimar for that.
    If you're interested.
  • Faustin
    Dared SL 2000. My first piece of tube gear.
    Sigh. Punches way above it's price point.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    A little EL34 Mono showing off
