Remodeling the house, so I did a few upgrades to my 2 ch system and the 7.2 in the family room. Here is a look at the 2 ch with the upgrades added;
FX-Audio X6 Mk II DAC
Crown XLi 1500 Amp
Fluance Signature Tower Speakers
https://youtu.be/mgO3HwiKbdQ Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Fluance bipolar Rear Surrounds FluanceXF8 Bookshelf Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp x2, Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Polk Audio R700 Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX301 Eversolo DMP-A6 Polkaudio R600 Towers Polkaudio Center R350 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Fluance Signature Bookshelf fronts, Rears Fluance Signature Bipolar Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX -
How do you like the Fluance towers? I heard a friend's Fluance powered bookshelf speakers and I was pleasantly suprised by how good they sounded. Seems to be a real bargain.Rega Planar 8, Apheta 3 MC , Aria mk2 Phono
Aurender n100h, Benchmark DAC2 HGC
Arcam SR250, Parasound JC5
Revel F208, SVS SB-4000 -
guyincognito wrote: »How do you like the Fluance towers? I heard a friend's Fluance powered bookshelf speakers and I was pleasantly suprised by how good they sounded. Seems to be a real bargain.
I have been a early adapter of the Fluance line, these signatures replaced an older pair of the SX (now called elite line) Towers and with the right/proper source and power these boys can fill any medium to large room. They will over power a small room, they need room to breath. The Crown XLi 1500 is just the right amount of power to keep them sounding clean from low volume to house party levels.Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Fluance bipolar Rear Surrounds FluanceXF8 Bookshelf Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp x2, Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Polk Audio R700 Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX301 Eversolo DMP-A6 Polkaudio R600 Towers Polkaudio Center R350 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Fluance Signature Bookshelf fronts, Rears Fluance Signature Bipolar Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX -
Very cool. Thanks for sharingRega Planar 8, Apheta 3 MC , Aria mk2 Phono
Today I made the arduous 10 hour round trip to Audio Classics to pick up 3 of my units that needed servicing. The mc2255 replaced the 10 wpc t amp that had been filling it's spot for waaayy to long.....now that was an upgrade.
butterbean wrote: »Today I moved my system to a new area in the basement. It’s about 15 ft wide, and has an insulated wood panel ceiling. The old space was like 40 ft wide with hung panel ceiling. Eventually it will be a home theater room but I just wanted to see how it sounds. So far it sounds great, gonna play tomorrow and tweak a few things lol! The wife says it’s still loud but not annoying. Hmmmm she says that about me also. It has a great sound stage, good depth and I don’t have to crank it as much! I have a lot to change, fix some drywall and paint and clear a lot of clutter but it’s a start.
You got those Tl’d
DynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3 -
Not necessarily all today, but here is the result of some recent upgrades.
Top to bottom:
Lehmann Silver Cube Phonostage
Innuos Zen Mk3 Streamer
Benchmark DAC3/HGC Preamp
PS Audio Stellar PowerPlant 3
Benchmark AHB2
The power supply brick in the bottom left is for the Lehmann Silver Cube Phonostage. The orphan RCA cables in the front are for testing various vintage components."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
I read somewhere that it's not advisable to leave a pair of interconnects connected on one end only like that as it can essentially act as an antenna, picking up stray RF interference and putting it into your system.
Not sure if there's any truth to that, or how anal you are about things like this, but just figured it was worth a mention. -
Thanks for the info, Drew. I am anal, but not quite THAT anal. This system is a constant work-in-progress."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Fair enough! I on the other hand am that anal.
I also wouldn't be able to use that rack unless I measured the distance between each shelf with a digital calipers and ensured all were spaced exactly the same. And used a level to make sure that each shelf is completely level, maybe even counting the number of turns of each bolt or counting the threads to make sure everything is completely symmetrical and even.
I've been told I have issues. -
Keep being a perfectionist as long as you can. There's a lot of worse issues we all could have.
…and perhaps using a torque wrench on each nut as well? I hear you, Drew.
There is an element of truth in the above and the first place I’d look for EMI.
Power wires, telephone cable and your house wiring of both kinds, under the right circumstances, can PU a lightning strike from miles away. I lost an SSP, small 2ch bedroom system, and my then desktop’s NIC THROUGH the modem. Modern still worked but from that day forward I’ve advocated to many UNPLUGGING anything like the above plus those containing microprocessors when ever a storm is imminent, pending, or you’re away from the house more than 48 hours.
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
You can get end caps which essentially put both +/- at the same voltage by connecting them.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Don't put those ideas in my head!Fair enough! I on the other hand am that anal.
I did use a level on each shelf, but had to compensate for the length of the interconnects and power cords as well, so unfortunately the shelves can't all be equidistant.
Earlier last night, before the pic, I had a CD player attached to those cables. Next will probably be a tape deck of some sort for testing."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
I couldn't imagine your shoe tying instructions..... 30 minutes later your ready
Did y'all see the Torque wrench in that music room / house where we all can only dream about?
It has to be there somewhere as much obsessing as that man put into it. Remember the chairs?
I took the SDA-1s out of the system and put the ADS L-1530s back in. Changed the little Audiosource amps from mono to stereo and am bi-amping the ADS.Make it Funky!
Put some bugle boy d getter gold pins in the carver c-19.
I've been very busy. I recently found my "forever" preamp. An Aric Audio Motherlode II. It has a separate power supply,which made things a little tight in the rack. So,since I mainly stream,and spin vinyl,the CD player got moved to the Pit,as well as my old preamp.(Aric Audio Unlimited) Yes,I'm a huge fanboy of Aric. He builds some incredible gear. Here,s the reconfigured rack in my main listening room,and the entirely reconfigured Pit system. I moved everything out of the entertainment/fireplace cabinet. Things were getting too tight in there.
See my profile for list of gear. -
Living the dream!
Ray, please rethink those springs on the tubed pre. You are reintroducing vibrations that were never there, not isolating. FWIW, YMMV.
Waz up Tom! Good to see you posting!2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources. -
Hi, Todd! Thanks. I am still somewhat reluctant to come back but we shall see how it goes.
On a different note?
I posted this thread thinking that it would be just one of those threads that died like all of the other great topics. Holy crap Batman! For some reason, this one stuck to the wall and won't come off. This is like the Black Paint thread or the famed Energizer bunny. It just keeps going and going and going....
....and going, and going.....
Hi Tom,
Thanks for the comment. Would you suggest sorbothane pads,or something else,or nothing? When I say nothing,I mean the stock rubber feet.
RaySee my profile for list of gear. -
Tom, I believe you are back!! Good to see!!
I always look at this thread every day.
Most interesting. Lots of "artists" with their equipment."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Hello, Harry. Hope all is well with you. We need to have another GTG before the world gets locked down again. Trey and a few others have monthly/bi-monthly GTG's often up here in the Charlotte area. Every one of them is a blast and it's fun to see the improvements/changes in the systems.
Ray, there are a multitude of isolators out there. Sorbothane is definitely one of them and from experience, it works. I use them on my LP player (albeit with a granite plinth that sits on spikes as well). My fear with what you are using is that the springs act like absorbers for vibrations and could possibly be ringing as the vibrations happen, introducing unwanted noise into the tubes.
If memory serves, Mapleshade had a couple of reasonably priced ones, as well as Amazon or Isoacoustics.
It has been a while since I have been in the market (so I'm not up to speed on the latest and greatest) and you have to be careful of two things. Sorbothane can damage wood if placed directly on it, as it has oils or something that will seep into the wood. There needs to be something between the Sorbothane and wood. The second thing is that you can "overdampen" a system. There have been many a testament on this forum to that.
My advice would be to play around with whatever you can get your hands on and choose what sounds the best for your particular application, as what works well on my rig may not necessarily work well on yours and vice versa.
I wonder how those springs would work during an earthquake."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
BlueBirdMusic wrote: »I wonder how those springs would work during an earthquake.
If this pre’s a rockin’ don’t bother knockinSee my profile for list of gear. -
Tom,
Thanks for the recommendation. I pulled the springs out. I have some sorbothane dots,but I'm going to use the stock feet for now.See my profile for list of gear.
