1116117119121122201
  • BlueFox
    BlueFox Posts: 15,250
    It would also help to angle the center up so that it is aimed at the ears versus the stomach.
  • guyincognito
    guyincognito Posts: 129
    Stained and added another shelf for the record collection. Much easier to browse through now.
    Rega Planar 8, Apheta 3 MC , Aria mk2 Phono
    Aurender n100h, Benchmark DAC2 HGC
    Arcam SR250, Parasound JC5
    Revel F208, SVS SB-4000
  • ADJ
    ADJ Posts: 46
    Finally put it together. Picked up a nice little NAD 310 integrated to go with my Keces 151 MKII and recapped RTi35s. Nothing esoteric but it puts a smile on my face for a budget computer rig.
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,789
    Nice! Your setup looks similar to the vintage UK cascading Standesign racks which I really like.
    Harry / Marietta GA
  • xsmi
    xsmi Posts: 1,804
    TEAforONE wrote: »
    I just replaced the old wobbly audio rack. It was time to get something much more stable. That was the first requirement. The second was I wanted more space between shelves. For any equipment changes in the future,and also if I want to add some sort of component isolation. I couldn’t find anything in my budget. I found a lot of great stuff at prices that are out of my pay grade. I have read some nice reviews of the Monoprice,Monolith 4 Tier Audio Stand XL. However,it didn’t check all the boxes. So,I ordered 2! By combining the parts from 2, I was able to make a stand that checked all the boxes. I was able to add some vibration control for my TT. I was also able to get a matching amp stand for the main system,and also one for the second system. These racks are really substantial, and super easy to assemble. To finish things off, I have 3/8" plugs coming to fill in the drill holes that are not being used. The total investment was $282. Tax included. (That price includes the plugs I found on epay)
    I have the same rack. How’d you handle cable management? Mine looks like a rats nest. LOL.
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • TEAforONE
    TEAforONE Posts: 1,064
    xsmi wrote: »
    TEAforONE wrote: »
    I just ordered some cable organizers. Ad another $10 to my total budget. I should have them next week.
  • Gardenstater
    Gardenstater Posts: 4,785
    First attempt at a more visually acceptable version. Practice makes perfect (will make). Another Monitor 7 set nearly completed. It would be fun to get some of these out to folks for independent review and feedback. I'm thrilled with the sound and these are never coming off my 7B set.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • TEAforONE
    i6zswthd491r.jpg[
    They look great. Looks like you have a new calling!
  • jbreezy5
    jbreezy5 Posts: 1,141
    Added Cyberpower UPS/Surge/Line Protection to bedroom system. Looking at adding a Greenwave Filter for line purification.
    https://www.bestbuy.com/site/cyberpower-1500va-sine-wave-battery-back-up-system-black/6408459.p?skuId=6408459
  • Gardenstater
    edited June 2021
    TEAforONE wrote: »
    Thank you! They make the frequency response smoother both on and off axis. Clarity and detail and transparency are significantly better and instruments and voices are more precisely located with a deeper soundstage. A good test for me was to play "Mercy Street" by Peter Gabriel on the album "So". Peter Gabriel's and Tony Levin's voices are similar in pitch and volume and used to be a subtle distinction, as far as separating them out. Not anymore! It is clear as day. I think that drastically reducing the diffractions takes out all those little time delayed reflections from the edges of the baffle and clears up everything.
    This is nothing new really. The way I am doing it they have a concealed hook and loop attachment system that allows repositioning and removal. They are made out of low density materials to reduce weight and also to reduce any resonances and reflections. They are effective at wavelengths down to 8 x Radius as a rule of thumb, so these ones I made are good for frequencies of around 1kHz and above. I'm sure their fundamental voices are lower than that, so it must be the overtones that are cleared up?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Jetmaker737
    Jetmaker737 Posts: 1,122
    Beautiful!
  • TEAforONE
    It’s easier to ask for forgiveness,than to ask for permission.
  • Gardenstater
    jbail2011 wrote: »
    I acquired these bad boys and am in love! I thought my 2b’s sounded great (and they do). These 2.3’s are next level. I’ve ordered the carpet spikes for the Gaia 2 feet. The speakers are overweight for their rating however the Gaia 1 are 1200 for 2 sets😳. I also have another Carver amp on the way. I’m going to get killed if I keep this up.
    If you put a screw eye hook into the center of each top and the ceiling with a pulley up there, then you can reduce the load on the Gaia 2s with a cable and a few sash weights. Don't say it was my idea. I don't need the credit 🤣
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • jbreezy5
    edited June 2021
    Stained and added another shelf for the record collection. Much easier to browse through now. [/quote]
    You should market these shelves; they’re beautiful and right-sized!
  • guyincognito
    You should market these shelves; they’re beautiful and right-sized![/quote]
    Well thank you for the compliments but I didn't actually build the shelves. Just did the finish work. They are modular units from Mapleshade that I bought in unfinished oak. I outgrew the double stack so added a 3rd (you can see the top shelf is just a little darker in the photos).
    https://mapleshadestore.com/unfinishedoakfurniture.php
  • Gardenstater
    edited June 2021
    Armacelled the inside of the basket on my R speaker's MW. Spokes and the spaces between near the spider. Initial impression is that everything seems smoother. Eva Cassidy "Live at Blues Alley" always seemed to have excessive reverb. It is still there but it is tamed now. This is going to require more listening before I do the L speaker. Some pictures to give an idea of what I did. No guts no glory is what I told myself lol. Ist two pics are on a spare drive with which I determined the size for the spokes to be 1-1/4" wide by 1-5/16" long. Kind of like surgery or that Operation game from when we were kids (ok some of us lol). Curved hemostats and the angle plate (to hold speaker vertically) were very useful tools, even mandatory perhaps.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    R speaker which is modified is definitely showing a smoother frequency response than L now with whitenoise and Advanced Spectrum Analyzer Pro on my phone. Bears out what I am hearing.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    Another interesting thing is that I had balanced my L and R speakers to within 0.1dB just prior to the mod on the R speaker and after the mod I had to lower the L speaker's level by 0.4dB to make them equal again, so it looks like the sound is cleaner on the R speaker after the mod but there is less sPL. Probably has to do with reducing some of those backwave reflections that impinge upon the rear of the cone.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    Tony M Posts: 11,662
    edited June 2021
    After re-caulking some ceiling joints along the front wall in the front room, I cranked up my entrance system with some music CDs I pulled from the area where the hidden window was.
    I hope I didn't wake the neighbors playing "Black Betty". :) I wanted to pull some favorites from there and put them beside the entrance system in that close rack for easy access. I've run through most of the CDs I like that are in the entrance rack already. I'll swap a lot of CDs I really didn't want to listen to with A LOT of ones I will. :) I found a Logins and Messina CD that has Angry Eyes on it but it's 2:30sec. long. I thought it was 6+ minutes...I'm going to look on the web...Yup...8 min.
    Yup...there is a long version... B)
    https://youtu.be/lFM-VaUO_CE
  • BlueBirdMusic
    ^^^^^ Good choice Tony!! Great music!
    Harry / Marietta GA
  • BlueBirdMusic
    The ones on eBay that were on my watch list?
    Harry / Marietta GA
    I hooked my RTA12b's up to my A/C wall receiver. An Onkyo HT-R520.
    I turned the bass up a little to hear more thumpin.
    Man do they sound great. It's been a few months since I heard them. They are special speakers!
    I hope I didn't disturb my new neighbor again. I finally came in at 3am. I was rockin on some classic rock right up till 3. :p
  • jbreezy5
    Put together a small bedroom set-up. Insignia 26” direct-lit LED tv ($80 on sale BB), Lepai 2-channel integrated amp ($40), Boston Acoustics CR55 speakers ($40 ebay), and Amazon Fire TV stick ($50?).
    Using 3.5mm headphone fixed out from tv to 3.5mm input on the amp; eliminates need for a full size receiver (hdmi/coax/optical not used for audio); still sounds great.
  • agfrost
    agfrost Posts: 2,471
    Found a set of NHT SB-1 bookies on local Craigslist for $30 (!!) and had to get them. Cosmetically just "OK", they sound stupid good, even putting nearly no effort into setting them up. I just set them on top of my 2BTL and transferred the speaker cables.
    These were the smallest of the line (early 2000's) and only go down to 70 Hz, but I'm more impressed than ever by the job my pair of Rythmik F8's do.
    Jay
    gudnoyez Posts: 8,169
    Just added a Locki to my Schiit stack a few minutes ago.
  • kevhed72
    kevhed72 Posts: 5,149
    It was the pre, amp, and CD player up in the Illinois burbs. Seemed like a quick sale priced to move deal to me. Now I just have to get it back to Georgia!
