Best Tube PreAmp under $500???
This...6DJ8 / 6922's
Never had a problem with overheating and did monitor the area after they were installed.
https://www.mundorf.com/audio/en/shop/Capacitors/AudioCapsClassic/MCapSupremeSO/MCap+SUPREME+Silver+Oil/?card=2891
Temperature range -25°C/-13°F...+60°C/+140°F➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
I'm thinking I will put a easy to remove vented plexi glass top on it. I'll be trying new tubes and love to see the tubes.
Those are superb caps!Gustard X26 Pro DAC
May not be a bad idea. I mentioned the 18+ screws to get into it...my BHK has 2 thumb screws and a rectangular plate built into the cover. Similar to the Bachart Labs offerings. I do appreciate the design. Just a general comment...better air circulation is never a bad thing.I'm thinking I will put a easy to remove vented plexi glass top on it. I'll be trying new tubes and love to see the tubes.
Absolutely. Did a lot of research when I decided on them.Those are superb caps!➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
Ok ok, fine. Send me your BHK and we will call it even!
When I first got my Belles pre I just left it out and the top off until I found the tubes that matched my system best. Then put it in the rack. It also has a ridiculous amount of screws to uncork.Gustard X26 Pro DAC
I stand corrected. I just counted. It's exactly 18. Strike the "+" from my previous statement and it seems much less daunting.
I guess if that's the only bad thing about it, I could live with that. -
No wonder this Hafler weighs 60 lbs.
Largest transformer ive ever seen in an amp.
Got everything hooked up. Sounds great. I find the analog out on the Marantz 7007 sounds more natural. But when i let the Yamaha do the DA the bass is a little better.
I prefer the analog so far.
No more hiss and the low volume distortion is gone from the amp. -
I've never seen a heat sink setup like that.
Glad to see your amp's back to normal.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
There were 7 fuses. Took them out and cleaned the contacts and the fuse ends. Put it all back. So far all good.
Looks pretty easy to upgrade the skimpy power cord. -
This ain't good is it????
Whoa. I've never seen voltage sags that low. 17 amps? Mine fluctuate from 117.8-121V.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
That will affect an amp ask me how I know.
If you've got an AC circuit sagging that much under a load... you might want to get an electrician in. Tonight. I am not being facetious.
Now, I grant you that 17A is a pretty serious load... but... unless that 80 VAC is very transient, it does NOT look good. Is the wall plug that whatever power gizmo you're using is connected to warm (or hot)? How about the wall itself? Anything smell warm?
Check another circuit for the no-load AC voltage. Do you have a Kill-a-Watt?
I'd also probably go down to the breaker box and listen for huming/buzzing. Check that circuit's breaker and see if it is hot. Kill whatever's on that circuit and cycle the breaker off and one a coupla times.
Where's @Lightman1? Still spelunking?
Unless it has a SMPS, in which case it probably won't care at all -- until the house burns down.
Ok... so the 104.9 @ 15.4 amps was me pushing the room to the limit. 7.2 channel stereo,, Sub amp, main amp, HTR amp and Denon 2910 to include some room lighting and a small cooling fan. I think my router and modem were also hooked up to the power condition that is a Belking PureAv60. It is fed from a dedicated 10 awg 4 line direct to the panel on a 30 amp breaker. The 4th line is being utilized as a second ground. (Don't know if thats a good idea or not???? Please share your thoughts)
The second photo @ 80v and 17 amps.... well I just happen to walk through the room (it was not a transient ) late at night (nothing was on) and noticed out of the corner of my eye those numbers. I switched ever outlet off and back on. No change. I finally unplugged the entire Belkin unit from the Levitron Hospital grade outlet on the 10awg line and back in and it returned to normal 121v 0.0 amps.
Is this Belking toast.
I no longer run the main amp or the sub amp from the Belkin. The Hafler (MAIN) is on the second Levitron Hospital grade outlet. And the sub amp (a Class D Behringer NX3000) on the house main line on another wall.
Not sure what to think about this 80v situation. Is the Belkin going bad? I'm the original owner and its only about 6 years old.... -
Me either. 16 transistors on the thing. -
What is SMPS? -
Switch mode power supply.
Hmmm
I'm not a believer in the power conditioner thing. Now I'm even more skeptical.Gustard X26 Pro DAC
Hmmm
Im questioning it myself. -
If money was no object I'd probably have the PS Audio Regenerater. But....$$$$ is an object for now. :'(
With this new Anthem tube pre, it uses 6922 tubes. I have some (6) 6SN7 tubes ( that I use in my Yaqin CD3 buffer) and found that the TubeDepot has some adapters so I can run the 6SN7 in a 6922 socket. Is this a bad idea? I will be buying some 6922s to play with along with the OEM tubes that JayCee is sending.
Just wanted some feedback about adapters. -
Largest transformer I've ever seen in an amp.
You should see the iron I have in my amps, or the transformers on the Carver Silver Seven tube amps...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »
I wish. Silver 7 is one of the amps I drooled over as a kid reading my dad's Stereo Review mags.
You got some pics?? -
Belkin not Belking in my post above.
The 6sn7 has a heater current of 600ma and the 6922 has a heater current of 300ma so I wouldn't try it unless you check with the manufacturer first.
