17677798182202
  • joecoulson
    joecoulson Posts: 4,943
    Also, do you sit with your left buttcheek lower than the right? If not, your not doing it right.
  • GlennDog
    GlennDog Posts: 3,158
    edited March 2020
    Clipdat wrote: »
    I bought this simple and unassuming looking Lumin U1 Mini from AudioThesis, and I'm amazed at how much difference a high quality streaming transport can make.
    I've never heard Tidal sound this good on my system. Worth every penny.
    We need a Polk Audio Forum "Excusive Drew Review"
    Clipdat wrote: »
    I have it connected to my Ruby DAC via an Audioquest Forest USB cable. Would like to try a higher end USB cable with it to hear any differences.
    Tidal SQ thru the Mini is very good. I’m impressed.
    Before you finalize that review, try the Mini with a “higher quality” cable. I’ve not heard the AQ Forest, it may be a very fine usb for a sub hundie. I’m currently running a WW Platinum and all I can say is wow.
    That said, I wonder what a Final Touch Audio usb could do for me? I’ve only heard great things about it ...
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • maxward
    maxward Posts: 1,712
    It’s all about the symmetry, isn’t it?
  • OldmanSRS
    OldmanSRS Posts: 419
    treitz3 wrote: »
    Do you notice any drum hits/strikes that are more noticeable in stereo?
    I'm not running stereo on the subs since the Adcom amp is driven from combining both channels in the left sub's preamp and feeding that mono signal to both channels of the Adcom which in turn feeds the driver in each sub speaker.
    Downstairs in the garage I do run one stereo channel to each sub. I can't say I notice much separation. Sometimes the bass content below 40 hz contains some out of phase info that when running stereo subs mixes in your head instead of being cancelled out by making it mono first, and I can hear the results like a ghost bass image behind me but it's rare.
    '65 427 Shelby Cobra
    '72 Triumph TR-6
    __________________
    '88 Polk SDA SRS 1.2, with upgraded XO caps and Erse SDA inductors
    '86 Polk SDA CRS+
    '84 Polk Monitor 10A (Peerless tweeters)
    '05 HSU VTF-3 Sub (Original OEM)
    '20 HSU VTF-3 Sub (three more, 100% cloned)
    '93 Carver TFM-35
    '88 Carver M-1.0t
    '88 Adcom GFT-555
    '88 Adcom GFP-555
    '88 Adcom GFA-555 (upgraded/restored)
    '88 Adcom GFA-555 (a second one upgraded/restored)
    '05 Onkyo DV-555 media
    '89 Fosgate 360 Digital Space Matrix
    '89 Fosgate 360 Digital Space Matrix, internal surround amp bridged to drive only a center channel
    '91 Kenwood Basic M1D Amp
    '89 Pioneer Laser Disc media
    '89 Sony SuperBeta HiFi media
    One PGA2310 based custom built remote volume control
    Four Polk T-15's
    Four Polk TSi-200's
    Four Polk TSi-100's
    Two Polk CS-10's
  • OldmanSRS
    treitz3 wrote: »
    Also, when listening, do you pull them out from the wall? The ports are choked when they are up against the wall like that.
    Not thus far. I listen pretty loud and the cones are not moving all that much. I ran a continuous 25 hz test tone through them and cranked it up until I could hear some port noise but I have yet to get them that loud with material. I will play around with distance from the wall and see if it changes their response.
    '72 Triumph TR-6
    __________________
    '86 Polk SDA CRS+
    '93 Carver TFM-35
    '88 Carver M-1.0t
    '88 Adcom GFT-555
    '88 Adcom GFP-555
    Four Polk T-15's
    Four Polk TSi-200's
    Four Polk TSi-100's
    Two Polk CS-10's
    treitz3 Posts: 20,083
    OldmanSRS wrote: »
    Hmmm, thanks for your observations. I have my subs up on stands and at the same height with the tweeters. The signal is in stereo on a full range system. If you ever have a chance to do this? I would highly recommend it sir.
    Great looking system!
  • OldmanSRS
    edited March 2020
    I was looking at your setup and did not know those were subs on the stands. I'm sure having them inline with the tweeters helps with sound continuity. What subs are they and how much do they weigh? I was planning on running stereo subs in the main room but since I could no longer buy the HSU plate amp for the second sub, I went with dual channel mono. T he main thing my 1.2s lack is tight bass when the listening position is midway between the speakers and a rear wall. I fought this and lost in several homes. My last home had a 26 long by 14 wide room and I listened from near the rear wall. The bass was great but if I moved to midway, the bass and the punch disappears. These subs restored that and then some in my current setup.
    I'm not a real high end guy or an audiophile. I just like stuff that works well enough for my taste, and to impress friends occasionally and I like to build as much of it as I can.
    '72 Triumph TR-6
    __________________
    '86 Polk SDA CRS+
    '93 Carver TFM-35
    '88 Carver M-1.0t
    '88 Adcom GFT-555
    '88 Adcom GFP-555
    Four Polk T-15's
    Four Polk TSi-200's
    Four Polk TSi-100's
    Two Polk CS-10's
  • OldmanSRS
    Dang, I just typed a long response to you and then edited it but it went away! It's too late to keep going. Signing off til tomorrow.
    '72 Triumph TR-6
    __________________
    '86 Polk SDA CRS+
    '93 Carver TFM-35
    '88 Carver M-1.0t
    '88 Adcom GFT-555
    '88 Adcom GFP-555
    Four Polk T-15's
    Four Polk TSi-200's
    Four Polk TSi-100's
    Two Polk CS-10's
    The subs are Rythmik F25's. As for the weight? Good question. They are heavy. Definitely a two person lift onto the stands. Once they are on? I simply twist them to make adjustments...although not easy given the space restraints.
    Even full range speakers could use subs IMO/IME.
    Although I am a KISS (Keep it simple stupid) kinda guy, the subs round out the system as a whole and offer yet another level of (in spades) listening enjoyment. When in stereo, the sound stage is at an even higher level of enjoyment/playback realism.
    It can offer you pinpoint reproductive efforts with so many things other than the drums. With the drums, it can offer you pinpoint locationality cues to where one can point a laser at each individual component within the drum set and/or sound stage.
    OldmanSRS wrote: »
    Trust me when I say that I have been there, done that. The guys on this forum have given me grief about it as well. It happens. TTY tomorrow.
  • marvda1
    marvda1 Posts: 4,961
    you need to get those bad boys set up now! :D
    Puritan PSM156
  • joecoulson
    ZLTFUL wrote: »
    What ever could these be...
    Maybe catnip?
    nooshinjohn Posts: 25,984
    Wipe them down with antiseptic wipes and bleach first. You don't know where they've been. ;)
  • Mike Reeter
    Mike Reeter Posts: 4,315
    ZLTFUL wrote: »
    New Elba 2's ?
    pitdogg2 Posts: 27,234
    edited March 2020
    ZLTFUL wrote: »
    I will use a set of Canare 4S11 or whatever they are...
    Not a dang thing wrong with Canare wire.
    I just happen to use a dual run to each speaker of 4S11. I can thank Frank at Signal cable for the idea. Is 8 gauge cable overkill???
    Nope!
  • Mike Reeter
    ZLTFUL wrote: »
    Indeed. Walnut pair.
    Good for you! I'll have to plan a little road trip this Summer. I'd love to get ears on a pair.
  • steveinaz
    steveinaz Posts: 19,546
    Very cool...get busy we want to see them!
  • displayname
    displayname Posts: 1,232
    Very exciting! I'm jealous, but hopefully at some point I'll snag a pair. Walnut would be my color of choice as well :)
    Analog: Hana ML > MoFi UltraDeck > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
    Discogs
  • indyhawg
    indyhawg Posts: 1,673
    ZLTFUL wrote: »
    Congrats on the Elbas's.
  • gp4jesus
    gp4jesus Posts: 2,019
    ZLTFUL wrote: »
    I just happen to use a dual run to each speaker of 4S11. I can thank Frank at Signal cable for the idea. Is 8 gauge* cable* overkill*???
    Nope*!
    go big* or go home*!
    *all connected w/Premiere ICs
  • motorstereo
    motorstereo Posts: 2,359
    gp4jesus wrote: »
    ZLTFUL wrote: »
    Nope*!
    I found there's a lot more to speaker cables than gauge when I tried a double run of Canare wire.
    I had to try it and see for myself though >:)
  • gp4jesus
    edited March 2020
    Is your Canare 4S11 10 gauge, too? That would make a double run equal to 7 ga? Specifically, what did you learn...? I’m gonna dodge a tomato or two before this is over.
    IME doing internal speaker mods, one channel’s speaker at a time; (more recently) bit by bit, progressing towards bi-amping*, size made an undeniable diff especially in the lower octaves. In the case of Polk speakers of ~12 years ago I’m certain that’s due to their wimpy internal wire. Jess says it’s 16 ga. I say 18.
    *and eventually tri-amping
    https://forum.polkaudio.com/discussion/174880/tri-amped-rti-a7#latest
    Upgrading the internal wire to 12 ga of my CC made most male dialogue heavier* and/or thicker*. Further, after I removed the passive XO filtering I upgraded to Canare 4S11 inside and out. More so* than before, I felt forced to make light use of my CC’s EXO’s PEQ capability to rebalance its tone.
    I hope this helps you to understand why I must chime in anytime someone attempts to downplay the value of wire gauge. I realize gauge increases doesn’t always apply. If it didn’t make a diff, I’m sorry, but you won’t know till you try.
    Sorry for the long winded rant. Tony
  • LoStrings
    LoStrings Posts: 38
    Love the stands!
  • hochpt21
    hochpt21 Posts: 5,423
    Thank you :)
  • indyhawg
    Those stands look nice.
  • dromunds
    dromunds Posts: 10,136
    Glad you’re liking the 703’s
    mhardy6647 Posts: 35,200
    edited March 2020
    ZLTFUL wrote: »
    Years back, within hours after I brought the new-to-me Altec 604E Duplexes back from western Vermont to MA, I was greeted with this tableau:
    Fortunately (??) I had draped a towel over each of the Duplexes to give them some semblance of protection -- but apparently all I really managed to do is to create a (tabby) attractive nuisance.
    Tony M Posts: 11,680
    Cats ARE curious creatures for sure! :#
    We love having one around.
    Oreo...who's a hoot! :D
    Cali, who has gone to cat heaven last summer. :'(
