I just pulled the trigger on a new tüübed pre....this one should be pretty sweet!
Johns just reminiscing about the one he once had 🤪AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
I am listening to it now. I will never go back to a tube pre, nor will I part with this one.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Three 20 amp circuits. -
You have tube amps, John. Big difference.
When I lost the tubes in the Jolida JD9, going from that to the Marantz? The only tubes left in the rig were in the Dodd MLP. I have had two other pre's in the rig (albeit temporary) that were SS. I could TELL I had an SS rig.
I need tubes man. No if's and's or but's about it.
nooshinjohn wrote: »I am listening to it now. I will never go back to a tube pre, nor will I part with this one.
It’s definitely nice kit.
I know it was up for sale last year, I didn’t know you ended up keeping it 😎AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
The wife backed down, so I stopped selling.
@treitz3 if you would, please do let us know what the Canary folks find when they delve into your preamp. One is always curious about root causes to build one's troubleshooting database.
Tom sorry to hear you're have a bit a drama with your new piece. Hope it all works out.
Is the seller helping you with the expenses since you're shipping it out to have some work done on it?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Wow,so sorry to hear of your difficulties with the new pre. Hopefully Canary will get this straightened out asap!See my profile for list of gear.
UPDATE - Well, I messed around on the insides and could not find anything noticeable that would be "out of order" within the pre side of the pre. (Have not looked at the PS yet but will tonight). Everything looked to be dead on and I am still in disbelief at how new this thing looks.
Anyhoo, I re-seated the tubes and hooked it back up. Same issue. So, I did something I have never done before but after watching Bob Carver work on gear hot?
(NOT RECOMMENDED UNLESS YOU KNOW WHAT YOU ARE DOING....THIS COULD BE LETHAL!!!)
I decided that I would do what I have seen him do. Mess around with it while it was hot. Tube 1, no change, tube 2, no change. Tube 3?
Shazam! Sonic difference that went from the 120Hz buzz to what sounded like a radio station that was trying to come in. Well, I powered her back down. Upon further inspection, the tube has lost its vacuum. I have no spare tubes for this, so I created another thread...https://forum.polkaudio.com/discussion/189446/urgent-need-reliable-and-trustworthy-shop-that-has-matched-quad-of-6sn7s#latest
Interesting Tom - So you're saying a bad tube?
I've got an octet of spare EH 6SN7's that are good, to use for troubleshooting. Let me know.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
PM will be sent here shortly...
I knew it was a bad tube...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
This is the tube that failed. Apparently not a stock tube. Sorry for the sideways pic's...
FYI, Verb has a set coming soon so that I can test the Canary. Thanks man...
My pleasure Tom! It was a great pleasure talking to you! Thanks for spending some time with me. Your insights and advice all things audio is really appreciated!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Thank you for the kind words, Dave. I enjoyed our conversation(s).
Have a great evening.
Glad it was just a tube, rock N roll- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
President of Club Polk -
Glad you got this resolved Tom. A bad tube makes for a bad audio experience. Please keep us informed on how the replacement tube from Verb turns out.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Just want to reiterate, John knew it was a bad tube.
Yes, I conferred with said baby and she agrees, tubes are a pain- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Good deal Tom. I'm sure the thought of having to ship it to the manufacturer for service was making your stomach turn!See my profile for list of gear.
That’s a relief! Way to go on the troubleshooting skill set!HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Just feel the need to include a bit from the manual from my Manley Shrimp: That EveAnna is a stitch.
Jay
How many times do you all think, in this thread, I've had to get up and take a walk... so as to avoid grabbing the computer and shaking it whilst screamingVacuum's not a THING... It's a NOT THING!
Well, of course, as any modern physicist can tell you, that's not really, strictly true -- the vacuum of space (or a tube) is full of all kinds of weird stuff that's, of course, not stuff as we know stuff... umm... oh, wow, man.
What was I talkin' about, man?
oh...
So, yeah, the vacuum leaked out
If you get too much of that stuff in the room with you, it can get hard to breathe.
I think vacuum is regulated by the State of California, in fact... for just that reason. You know, to protect its citizens. So they can keep doing... you know... whatever it is that they do out there...
Nature abhorred that tube previously.
She can tolerate it now.Jay
Well put.
Besides Nature...
cats, also, abhor a vacuum.
IME, that is.
So you're saying the tube was breached by atmosphere and therefore is compromised?Most people just listen to music and watch movies. I EXPERIENCE them.
Yup. Probably caused during shipping going to and from the cold or vice versa. There was no readily apparent signs of rough handling on the boxes other than a 1 inch "nick" on the PS box that went right into the 3" thick foam padding. The bad tube was on the Pre, not the PS.
Tom~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
