I just pulled the trigger on a new tüübed pre....this one should be pretty sweet!
    treitz3 Posts: 18,335
    edited January 2020
    Hi, Glenn. I am actually fine with DAC's at the moment. The one that is in the Marantz SA-7S1 is one of the best I have ever heard in my travels and the one I have for the server is kind of overkill for the server itself...(Photo below taken from random image off of the internet)
    My weak link in the network gear would currently be the Blue Node2. I typically don't listen to the network gear in the sweet spot, usually only when I'm in the office working (in another room) or doing other things around the house. Pretty much the only other exception is when I want to try new music that I don't have the "physical" media for. In other words, not really a priority for me. It's just a nice luxury to have (to me).
    Drew, I have not yet fiddled with the internal components within the two units. Hopefully I can find some time tonight. I exhausted every other test this morning and that's all that is left to check on.
    Then one final test before shipping off to double check my amp just in case it happened to fail the very moment I hooked up the pre (not likely and I'm not a believer in coincidences but I will check it anyways just for S's&G'ls).
    Just kind of overall bummed about the whole deal at the moment, TBT.
    nooshinjohn Posts: 25,100
    No tubes.
  • GlennDog
    GlennDog Posts: 3,085
    Johns just reminiscing about the one he once had 🤪
    Source Lumin U1 Mini into Lampi Baltic 4
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    GlennDog wrote: »
    I am listening to it now. I will never go back to a tube pre, nor will I part with this one.
  • BlueFox
    BlueFox Posts: 15,251
    treitz3 wrote: »
    No tubes.
    That’s right. Just excellent solid state sound. :)
    You have tube amps, John. Big difference.
    When I lost the tubes in the Jolida JD9, going from that to the Marantz? The only tubes left in the rig were in the Dodd MLP. I have had two other pre's in the rig (albeit temporary) that were SS. I could TELL I had an SS rig.
    I need tubes man. No if's and's or but's about it.
  • GlennDog
    It’s definitely nice kit.
    I know it was up for sale last year, I didn’t know you ended up keeping it 😎
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    The wife backed down, so I stopped selling. :p
    mhardy6647 Posts: 33,046
    @treitz3 if you would, please do let us know what the Canary folks find when they delve into your preamp. One is always curious about root causes to build one's troubleshooting database. :)
  • verb
    verb Posts: 10,176
    Tom sorry to hear you're have a bit a drama with your new piece. Hope it all works out.
    Is the seller helping you with the expenses since you're shipping it out to have some work done on it?
  • TEAforONE
    TEAforONE Posts: 1,004
    Wow,so sorry to hear of your difficulties with the new pre. Hopefully Canary will get this straightened out asap!
    UPDATE - Well, I messed around on the insides and could not find anything noticeable that would be "out of order" within the pre side of the pre. (Have not looked at the PS yet but will tonight). Everything looked to be dead on and I am still in disbelief at how new this thing looks.
    Anyhoo, I re-seated the tubes and hooked it back up. Same issue. So, I did something I have never done before but after watching Bob Carver work on gear hot?
    (NOT RECOMMENDED UNLESS YOU KNOW WHAT YOU ARE DOING....THIS COULD BE LETHAL!!!)
    I decided that I would do what I have seen him do. Mess around with it while it was hot. Tube 1, no change, tube 2, no change. Tube 3?
    Shazam! Sonic difference that went from the 120Hz buzz to what sounded like a radio station that was trying to come in. Well, I powered her back down. Upon further inspection, the tube has lost its vacuum. I have no spare tubes for this, so I created another thread...https://forum.polkaudio.com/discussion/189446/urgent-need-reliable-and-trustworthy-shop-that-has-matched-quad-of-6sn7s#latest
  • verb
    verb Posts: 10,176
    edited January 2020
    Interesting Tom - So you're saying a bad tube?
    I've got an octet of spare EH 6SN7's that are good, to use for troubleshooting. Let me know.
    PM will be sent here shortly...
    I knew it was a bad tube...
    This is the tube that failed. Apparently not a stock tube. Sorry for the sideways pic's...
    FYI, Verb has a set coming soon so that I can test the Canary. Thanks man...
  • verb
    verb Posts: 10,176
    My pleasure Tom! It was a great pleasure talking to you! Thanks for spending some time with me. Your insights and advice all things audio is really appreciated!
    Thank you for the kind words, Dave. I enjoyed our conversation(s).
    Have a great evening.
    VR3 Posts: 28,043
    Glad it was just a tube, rock N roll
    F1nut Posts: 49,802
    VR3 wrote: »
    You must be on baby duty.
  • headrott
    headrott Posts: 5,484
    Glad you got this resolved Tom. A bad tube makes for a bad audio experience. Please keep us informed on how the replacement tube from Verb turns out.
  • joecoulson
    joecoulson Posts: 4,943
    edited January 2020
    Just want to reiterate, John knew it was a bad tube.
    VR3 Posts: 28,043
    Yes, I conferred with said baby and she agrees, tubes are a pain
  • TEAforONE
    Good deal Tom. I'm sure the thought of having to ship it to the manufacturer for service was making your stomach turn!
  • halo
    halo Posts: 5,616
    That’s a relief! Way to go on the troubleshooting skill set!
  • agfrost
    agfrost Posts: 2,421
    Just feel the need to include a bit from the manual from my Manley Shrimp: That EveAnna is a stitch.
    Jay
    edited January 2020
    How many times do you all think, in this thread, I've had to get up and take a walk... so as to avoid grabbing the computer and shaking it whilst screaming
    Vacuum's not a THING... It's a NOT THING!
    Well, of course, as any modern physicist can tell you, that's not really, strictly true -- the vacuum of space (or a tube) is full of all kinds of weird stuff that's, of course, not stuff as we know stuff... umm... oh, wow, man.
    What was I talkin' about, man?
    oh...
    So, yeah, the vacuum leaked out ;)
    If you get too much of that stuff in the room with you, it can get hard to breathe.
    I think vacuum is regulated by the State of California, in fact... for just that reason. You know, to protect its citizens. So they can keep doing... you know... whatever it is that they do out there...
    B)
  • agfrost
    Nature abhorred that tube previously.
    She can tolerate it now.
    Jay
