Simple sda 2b tl upgrade question
    audioluvr Posts: 5,434
    I've blown 2 RDO 194's listening to Steve Miller Band on songs with heavy distorted guitar riffs. I don't think the 194's are built as well as the 198's because I rarely hear of anyone here having issues with them.
    F1nut Posts: 49,801
    I think you should examine why you blew a new tweeter before doing anything else.
    I don't know Jesse. I had my amps tested for DC current but other than that not sure what else could have caused it. Haven't had an issue since with the replacements.
    F1nut Posts: 49,801
    edited July 2019
    audioluvr wrote: »
    It seems I was writing my comment while you were posting yours as mine was directed at the other guy with a blown tweeter. Anyway, I can't imagine the build quality between the 194 and 198 is different, but what do I know.
  • windstriker
    windstriker Posts: 136
    1. Can speaker poping take out a tweeter when turning the preamp on and off?
    2. I just purchased a gimpod board and on his site he lists a 2.7 resistor but the closest i see in the mra-12 section is 2,3,and 2.7k will any of those work?
    txcoastal1 Posts: 13,132
    Are you following this:
    ON: source/preamp/amp; OFF: amp/preamp/source.
  • windstriker
    edited July 2019
    No... no i'm not. I had been told in the past to turn the amp on first then the pre amp otherwise it could pop a tube. Is this incorrect?
    turn off has been pre then amp
    You still want to follow above. If you're running a tube pre, when turning it on then let the tubes fully stabilize
  • windstriker
    Ok thanks, I will follow your advice.
    Any advice on the resistors?
    Mills
    Replace in both speakers
  • windstriker
    edited July 2019
    Self- Delete: answered my question with a little searching
  • windstriker
    Yesterday I was getting confused with buying the resistors because I didn't know the difference between Mills & the other version of Mills. I emailed Sonic Craft about it and they gave me a reply I thought I would post that reply, just in case if anybody else got confused.
    "All our Mills are true "NOS" Mills (made in the USA). Mills was purchased by Vishay Americas. They moved production to Mexico. The product was unusable to "us" the first couple of years. Vishay noticed that we were a top 3 purchaser from Mills. They wondered why we had not placed an order (3+ years into their ownership). They asked, and I told them...
    They said they would do what it took to earn our business. The parts that we have purchased from them are 99.8% as good sonically, and over a 100% in every other category:"
  • VSAT88
    VSAT88 Posts: 1,227
    +2^. Especially now that PA / Merger has went 100% into action.
  • windstriker
    I'm about to install my new crossover using gimpod board and I noticed they noticed something. The negative and positive on the P1 input is reverse from the P1 in put on the original board. Do I need to rewire the harness coming from my speaker to match this or is this the way it should be?
    F1nut Posts: 49,801
    I believe that is a misprint on the board, but let's ask @westmassguy to check it out.
  • westmassguy
    westmassguy Posts: 6,850
    Tony's @gimpod boards are correct. Some OEM boards were apparently misprinted.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • westmassguy
    Old and New. The date on the OEM board is 4/11/90. Maybe the earlier boards were misprinted.
  • windstriker
    hmmm weird, maybe its because I have a transitional 2b. IE early crossover printing?
  • windstriker
    So ya i followed the wires. Definently a miss print on the original board.
  • windstriker
    edited July 2019
    Update finished the crossover and ive started burning them in. So far so good.
    Question i read on another post somewhere that transitional 2bs cant take the dreadnaught mod. Is this true? If so y? I wasnt planing on doing it but since ive come this far i thought i might eventualy do it.
    F1nut Posts: 49,801
    You would need to connect the large blade post to the negative binding post.
  • keck
    keck Posts: 36
    edited January 2020
    Dear all, its been a couple of year since i own a pair of 10A and SDA 2B. I have done the recapped on my 10A previously and it sounds really great. Currently i am planning to do the SDA 2B TL mod. Would like to get any advice from all, and hopefully i am in the correct thread... :smile:
    Below are the parts i plan to purchase:
    A pair of Gimpod boards
    For High pass:
    2 x 2.7 Ohm Vishay Mills MRA-12
    2 x Gen I Sonicap 12 uF 200VDC
    2 x Gen I Sonicap 5.8 uF 200VDC
    2 x 0.22 Ohm Vishay Mills MRA-12
    For Low pass:
    2 x Clarity PX 20uf
    2 x Clarity PX 40uf
    I really wanted to go with all Sonicap, but is way over my budget.... :'(
    Any other recommendation for other Low pass cap or should i stick with Dayton cap just like my 10A crossover recapped?
    Anyway, i have attached some picts on my 10A(recapped) and 2Bs
    My 10A crossover recapped.
    Left 2Bs speaker. Notice the outboard driver is 6511 and inboard driver is 6503. Are they correct?
    Right 2Bs speaker. Notice the outboard driver is 6511 and inboard driver is 6503. Are they correct?
  • windstriker
    Are you plan on doing any other mods? Hnut dynamat blackhole ect ect?
  • westmassguy
    @keck you should start your own thread. The outer dimensional drivers are MW6511s, 4 ohm.
  • keck
    keck Posts: 36
    Hi, just plan on doing crossover mod to tl
    Thanks West, i will start another thread for discussion 😄
  • tonyp063
    tonyp063 Posts: 1,048
    Heat dissipation.
    pitdogg2 Posts: 24,576
    Cheap insurance for a few pennies more.
  • Gardenstater
    Gardenstater Posts: 4,184
    Less heat induced noise
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
