What Is Your Other Main Hobby Besides Audio?
1234568»
  • Milito
    Milito Posts: 2,003
    edited January 2020
    Raced against Team Associated numerous times when running 1/8 Gas. I raced a Delta car which was their main competitor when I was racing from 1975 to 1980. They won some and Delta won some, they did beat us in the 24 hour race we ran in.
    This is really going to date me. I remember when I first started racing the rear brake was a pad that pushed on the clutch bell to slow the car down. Then disc brakes were developed. We were running solid rear axle cars then. Then diffs were developed which lead to a big change as how the car handled. Right after I got out of it was when 4 wheel independent suspensions became popular.
    As far as engines when I started the K&B was very popular, then OPS and then Pico. We ran a tuned pipe and there were tricks you did to loosen up the motor. The manufacturing wasn't near as good as it is now so you keep your old piston and sleeves when the piston got too loose in the sleeve. You would then find a tighter sleeve and match the piston from a previous larger sleeve with it. I would lap the piston into the sleeve for a snug fit. I would also lighten the piston a little bit and polish the crank were it would spin better in the case. You also had to set the head clearance in relation to the piston so it wouldn't cause issues when running nitro in the model airplane fuel.
    mhardy6647 Posts: 35,551
    The tetras, pound for pound (gram for gram) are pretty ornery little critters, too. The neons and Cardinals are among the more docile ones, though, as I recall.
    ... and don't get me started on the topic of barbs. :)
  • joecoulson
    joecoulson Posts: 4,979
    That’s awesome!!!!
    That does look like fun.
    I'd like to see a GoPro car's eye view of that run. :)
  • boston1450
    boston1450 Posts: 7,758
    Wow. That hauls azz. Cool
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • verb
    verb Posts: 10,176
    ZLTFUL wrote: »
    Took a buddy out to play with the Notorious a bit this morning. He now wants one of his own.
    https://youtu.be/fMB_EakRnrI
    That is so cool! Loved on one of your jumps when you revved the motor to make a mid flight adjustment! Awesome! :smile:
  • deronb1
    deronb1 Posts: 5,021
    Golf. Not that good, but enjoy it
  • Hermitism
    Hermitism Posts: 4,348
    Hermitism wrote: »
    James35w wrote: »
    my question is -- are there bootproof snakes?
