Power Line EMI Meter - Alpha Labs (Demo Program)
12467
    mhardy6647 Posts: 34,996
    ^^^No the voltage is fine; it just reads a bit high on that unit and yes I'd be concerned if it was up that high.
    BlueFox wrote: »
    LOL. Then why do you think the other measurement are accurate. :)
    Indeed.
    Clipdat Posts: 13,094
    I think he meant the Furman reads the voltage high, not the EMI meter.
    edited December 2019
    Clipdat wrote: »
    Looks like the little EMI gizmo's reading a line voltage of 124 V -- which strikes me as kind of high.
    Not that I know what ours is right this second... might just go and check, after dinner.
  • motorstereo
    motorstereo Posts: 2,328
    BlueFox wrote: »
    I had thought the same thing when I first got it but the other measurements are used as a reference point.
  • phipiper10
    phipiper10 Posts: 961
    I've been paying close attention to voltage last few days since acquiring the Noise Harvester and signing up for the demo. During the day as high as 121 and as the evening arrives I have seen as low as 117 at which point the line boost light came on the APC.
    More than the belief that the Harvester is cleaning up noise, it's been helpful to see what triggers the blinking and where voltage is at. There are certainly more transients in the evening. Still narrowing causes and determining if there is correlation between more "cleaning" and low voltage. I've been surmising my neighbor has a massive grow operation and he is sucking up all the juice in the neighborhood! No doubt those dimmer switches set that thing off, and not on same circuit.
    Can't wait to try out this EMI meter to gather more info!
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • monepolk
    monepolk Posts: 1,154
    @Conradicles please PM me your shipping address.
  • monepolk
    Got it, thanks. I'll be shipping it out in the next day or so.
  • verb
    verb Posts: 10,176
    monepolk wrote: »
    Thank you sir! So what were your findings and impressions?
  • monepolk
    I was expecting higher readings because I live in a older home, but surprisingly my readings never got above 100mV (except the first day). Most of the readings in my listening area were around 20mV @ 119V. On the first day I got readings of 174, 145 and 137mV @ 116V on 3 outlets that are on the same circuit and the 137 reading went up to 245 when I unplugged the power strip connected to it. Since I wasn't able to duplicate those readings, regardless of the time of day, I think that the meter needed to acclimate to the temperature change. Readings around the house ranged from 17 @ 120V to the high of 85 @ 119V. But the listening area was 19-25 @ 119V So I think I'm good. B)
    Nice low numbers! Sounds like you're good to go!
  • verb
    verb Posts: 10,176
    Thank you Juan! :smile:@Conradicles you're next!
  • Conradicles
    Conradicles Posts: 6,339
    Got it in my possession!
  • verb
    verb Posts: 10,176
    Very nice! @jdjohn you're up next! :smile:
  • jdjohn
    jdjohn Posts: 3,347
    Cool B) I want to see what it reveals me about my PSA PowerPlay 9000, and also a Chang Lightspeed conditioner.
  • verb
    verb Posts: 10,176
    @Conradicles my man! Any update? Curious minds wanna know! :smile:
  • Conradicles
    Been testing about everywhere in my house that was built in 1968. I expected much higher numbers. Good news is that where I will be putting my future 2 channel rig is very low!
    Best case in the 30`s and worse case with everything on including the washing machine it was 120.
    This is a cool little toy!!!
  • Conradicles
    @jdjohn , PM me your address and I will send this to you.
  • jdjohn
    jdjohn Posts: 3,347
    PM sent
  • Conradicles
    Got it... will get it shipped soon.
  • jdjohn
    jdjohn Posts: 3,347
    I safely have it in-house :)
  • verb
    verb Posts: 10,176
    Very nice! :smile:
  • civilian
    civilian Posts: 357
    Can I still get in?
    ________________
    2 Channel-Denon AVR-4520/SDA 2.3TL's
    5.1-Denon AVR-4500h/RT3000P's/CS1000P/RT2000P's/
  • verb
    verb Posts: 10,176
    civilian wrote: »
    Can I still get in?
    Of course you can! However it looks like you just came back from a while ago. Stay and hang around with us, so I can get to know you a little better! Welcome back brother! :smile:
  • civilian
    civilian Posts: 357
    Would be interesting to compare to my AVS-2000 from that M-brand.
    ________________
  • jdjohn
    jdjohn Posts: 3,347
    Okay, time for some feedback about my results using this device.
    First, it was interesting and informative to find the 'hot spots' in my house...which is a town-home duplex with separate electric service to each side. We are on a slab.
    The initial readings seem to be dependent on individual breaker circuits, but I am not certain and have not mapped each outlet. Some outlets/circuits measure very low at 40-70mV, and other circuits in the house are up to 1130mV, with everything in-between.
    Sadly, the measurement at the outlet of my main 2-channel system is ~155mV, so starting at a fairly high measurement. Again, sadly, with my PS Audio PowerPlay 9000, the best measurement I could get by itself at outlets on the PP9000 was 130, only 16% or so less EMI than from the wall. But stay tuned for other variations/improvements from this outlet.
    The next significant thing I want to mention is the overall performance of the Chang Lightspeed power conditioner that I used during testing. The model number is CLS6400 ISO 20A. Using the Chang LSPC, EMI was reduced by an average of more than 80% of that from the wall. Some outlets went from 1130 to 200, others went from 186>68 and even 68>42. I had always experienced good results audibly from the Chang Lightspeed PCs, but this test proved scientifically the benefits of having one of these PCs in-line.
    In my next post, I will comment on interesting results of having a high-quality integrated amp in-line on an otherwise mediocre wall outlet.
  • jdjohn
    jdjohn Posts: 3,347
    I did some final testing last night, mainly in hopes of confirming earlier tests, so now I'm ready to report my findings.
    With my Cary Audio SI-300.2d integrated amp plugged into one of the sockets of my main wall outlet for audio, EMI measurements are better overall. In fact, having the Cary plugged into one socket makes a greater measurement difference in the other socket than my PSA PowerPlay 9000 power conditioner.
    To be more specific: with the Cary plugged into one socket, EMI from the other socket was reduced to ~70mV - whether measured directly from the second socket with the tester, OR if measured via one of the PP9000 output sockets. The PP9000 made no difference when the Cary was plugged-in. It's as if the Cary trumped the PP9000 in EMI reduction.
    FWIW: the outlet I use in this location is a PS Audio wall outlet.
  • jdjohn
    jdjohn Posts: 3,347
    Curiosity has gotten the best of me, so I just ordered a PSA Stellar Power Plant 3, and would love to test it with the EMI meter...if I can get a time extension with the test meter :)
    I will be taking advantage of PSA's trade-in program with this purchase, getting the max 30% discount by trading-in my PowerPlay 9000.
  • verb
    verb Posts: 10,176
    jdjohn wrote: »
    Of course you can have an extension! Your insights and comments are very well received! Thank you Jody! @tratliff hang in there, it's coming your way next! :smile:
    Viking64 Posts: 7,547
    verb wrote: »
    SCANDAL!!! OUTRAGE!!!
