Belles 21a Tube Pre in the house!
Well, Got me an early Christmas present!
Came with a couple sets of tubes. Unfortunately someone installed Dayton caps but I'm digging it as is for now! I'll probably upgrade them to something better. Any suggestions? I need 4ea. 15uF and 1ea. 2.2uF caps. I have a set of Mullards on the way thanks to @Gerres26.
«13
  • kharp1
    kharp1 Posts: 3,453
    YOU SUK! Just kidding, that was jealousy raring it's ugly head :)
    A pick of the innerds would help, some caps might not fit. I haven't heard this pre, but, I'm betting it sounds pretty sweet, or, will with the caps upgraded.
  • marvda1
    marvda1 Posts: 4,874
    kharp1 wrote: »
    here you go.
    https://forum.polkaudio.com/discussion/189041/ebay-sellers-misrepresentation#latest
    Speaker Cables: Organic Audio Organic Reference 2
    Interconnects: Argento Organic Reference 2, Argento Organic 2
    Puritan PSM156
    audioluvr Posts: 5,439
    I'm using it with a Hafler 500 amp. If it makes that crappy thing sound good I can only imagine what it'll sound like with my monos. It came with two sets of tubes. One set of Westinghouse's made in England and another set I can't read. The Westys were borderline harsh but these other ones are sweet!
  • kharp1
    kharp1 Posts: 3,453
    Posted this in another thread by mistake:
    I'm thinking that there cold be several ways you could go here. I'd try to work out some better deal with the guy, if possible, or, just play it as is for now and plan for a cap upgrade down the road. There appears to be enough room to make some improvement. Mundorf, Jantzen, Audyne, Jupiter all make some good sounding caps. The Jupiter are physically bigger, some are square or rectangular, but, you can come up with the values you need and play around with the space. This would be a good project that could provide good improvement for the buck.
    Thanks Kerry! I'll look into those others.
  • dromunds
    dromunds Posts: 9,984
    How many 12Au7's do you use in that preamp?
    tonyb Posts: 32,906
    Soo, is it more musical than your other pre ? Like we all said. :) Once you get addicted to that tube sound, it's hard to go back to SS.
  • marvda1
    dromunds wrote: »
    Two
    Puritan PSM156
  • dromunds
    marvda1 wrote: »
    dromunds wrote: »
    Two
    Duh, yeah I just looked at the photo in the other thread. Thanks.
    tonyb wrote: »
    Yes Tony, as always you are correct. From what I can tell so far it is quite a leap up from SS.
  • kharp1
    kharp1 Posts: 3,453
    A tube pre is, in my opinion, where you get real bang for the buck.
    Okay so some issues that I'm noticing which may make me have to return this if it can't be fixed. One is that one of the caps that some idiot ( no offense if it was one of you guys ) replaced on this at one time, is wrong. It's not one of the 4 that the factory usually replaces for the upgrade but the one between them. It's supposed to be 2.2uF and the one in there is 15uF. Another issue is while playing music it has a noticeable background hum like a tuning fork. When I press the mute it stops. Any thoughts?
    treitz3 Posts: 18,346
    Are any of your power cables in parallel and sitting close to a signal wire?
    No but I think I may have figured out where it 's coming from. The one set of tubes that are in boxes (the Westinghouse England) ones are 12ax7a's and this pre is supposed to be using 12au7a. Would that affect anything? Should I stop using it?
  • codycatalist
    audioluvr wrote: »
    Dunno but the a versions but 12AX7s have more gain than AU7s
    That would explain why when the volume is on 2 out of 10 everyone in the house starts freaking out.
  • dromunds
    Get those 12AX7’s outa there.
    tonyb Posts: 32,906
    dromunds wrote: »
    I agree. First things first is to get the right tubes in it, preferably NOS.
  • dromunds
    1959 Mitchum-made Mullards from Gerres26 coming. That'll make a difference
  • Gerres26
    Gerres26 Posts: 863
    dromunds wrote: »
    That they will!
    I got a $300 refund from the PO so I went ahead and ordered Mundorf Supremes to replace all the crappy caps that were in there. Curious what difference good / correct caps will make. Thanks again for all the help I've had here. One foot on audio nirvana and the other in the poor house!
  • dhart86
    dhart86 Posts: 1,594
    audioluvr wrote: »
    That's signature material...we all share in that dual reality. The right tubes and caps should show you what that preamp can do. Power it with a Shunyata power cord once you settle in
    Main Rig:
    Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
    Second Rig:
    Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
  • kevhed72
    kevhed72 Posts: 4,962
    Do us a favor and shoot some pics of the cap replacement process....Im thinking of trying out this pre next since I already have a Belles amp.
  • george daniel
    If you want a match made in heaven,,try an audible illusions with that Belles,, I had an L-1 and 350a for years
    edited December 2019
    Well today everyone left for post holiday life, leaving me the opportunity to install my newly acquired capacitors into this Belles 21A pre. I opted for the Mundorf Supreme caps as Auricap doesn't carry a 15uF any more. Upon their arrival first thing I noticed is that they are HUGE. Easily 4 times bigger than the Auricaps and Daytons. This of course made me have to do some modifications to the circuit board. I could have gone with the cheap Mundorfs but then I would have been always wondering what if...
    Project took WAY longer than it should have but me being borderline obsessive compulsive needed to make sure everything was clean and correct. Reflowed any questionable solders with Cardas solder etc. Since this was my first dip into the tube world I didn't want to do it half assed.
    Here's the way it came to me. Dayton caps and Cornell Dublier bypass caps. The PO bought it under the impression David Belles did a recap. Possible but I wouldn't think the original designer of this pre would would use lower grade poly caps that were in it originally.
    I pulled the face off first then removed all the RCA hold down nuts so I could remove the circuit board from the base.
    Here is the board stripped and the Dayton 15uF cap correct cap replaced with the correct 2.2uF Mundorf Supreme
    Post edited by audioluvr on
    Well, we all feel sorry for you that you would have to put up with such a loss. Prayers sent and best wishes for you and yours to come. If only we all had your problems...
    Here's a final picture of the new caps installed and a celebratory drink...
    treitz3 wrote: »
    Do not despair Tom. From what I've read with the "cap rolling crowd" these are a step up from the Auricaps.
    Oh, trust me....
    That was pure satire. Congrat's my man. Sweet. If only some had to "put up with" what you had too.
    Only a few hours burned in and already I'm noticing a significant 3D improvement. Sure could be the Irish whiskey but...
