Looking forward to L800 but have concerns, what are your thoughts?
191012141524
  • vcwatkins
    vcwatkins Posts: 1,993
    Excellent shots.
    Interesting, a bit "taller" triangle than I would have predicted.
    I don't know McIntosh gear - does it serve as your DAC and phono pre here? Also curious as to what app you use to stream.
    Have fun and take all the time you need to evaluate.
    Just kidding, you have 2 hours.
  • mpitogo
    mpitogo Posts: 516
    @tratliff they sound great but the only reference I have are to standard speakers without SDA. Sitting in front of them, these are the best sounding speakers in my house.
    I’ve been mostly playing them in the background with various streams to break in. Some speakers have a break in period printed in the manual, these don’t so I’m just aiming for ~100 hours of play.
    vcwatkins wrote: »
    Excellent shots.
    “Taller” - Its based on the manual see below. I don’t have experience with SDA so it mainly reading and trying. Should I try shorter? Make it 8’x8’?
    Yes, the DAC and Phono pre are built into the McIntosh preamp.
    Experimentation with speaker-to-speaker and listener-to- speaker distance is necessary to find the best combination
    for a listener and the listening space. A recommended 6-8’ speaker-to-speaker placement and 10’-12’ speaker-to-listener placement is a good place to start. Find the combination where apparent stage width, timbral accuracy and direct-to-reflected ratio is the best. Keep side wall reflections as far away as possible, or absorbed if necessary, for maximum performance. Follow the below directions to ensure optimal sound performance.
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • vcwatkins
    mpitogo wrote: »
    vcwatkins wrote: »
    Excellent shots.
    Don't read anything into my comment regarding spacing - I had no idea what was recommended in the manual - just that my preference with the 1.2's is a bit closer to an equilateral triangle. And the positioning of my CRS+'s when I heard the most exaggerated wrap-around SDA was equilateral within a few inches (and very close to me). I tend to move them around a lot, trial & error, when setting up after changes have been made to the room or gear.
    Hope they're sounding good during break in!
  • motorstereo
    motorstereo Posts: 2,339
    Thanks for the review mpitogo. It's nice to hear a positive review of the L800's and hopefully they improve even more for you after 100 hours
  • @mpitogo congratulations on the new L800's.
    I'm green with envy; I imagined the reddish LEDs along the floor being green. How did you do the lighting?
    It's really great to have a Polkie with the newest!
    Harry / Marietta GA
    pitdogg2 Posts: 27,045
    Are you referring to the laser level to check square ?
  • TennMan
    TennMan Posts: 1,267
    mpitogo wrote: »
    I saw Part-1 & Part-2 of the review. Is this Part-3 of the review or did I miss something?
  • pitdogg2 wrote: »
    I guess I am. I didn’t realize it was for speaker placement.
    Harry / Marietta GA
    gudnoyez Posts: 8,161
    I wonder if a shop in Chicago has some L800s set up to listen to, if so I would go as I plan on making a trip to Saturday Audio Exchange this winter once cabin fever sets in and I need a new preamp and some gear to trade in. I would go out of my way to demo those L800s congratulations to the OP on the purchase of yours.
  • mpitogo
    mpitogo Posts: 516
    @bluecomet LOL @pitdogg2 got it right, laser level for setup, just being slightly OCD for imaging.
    @TennMan no Part 3 yet, hosting holiday festivities and life outside of music ate up a bit of time. Every chance I get, I put some play time to the break in hours.
  • vmaxer
    vmaxer Posts: 5,120
    mpitogo wrote: »
    Any updates @mpitogo
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • mpitogo
    mpitogo Posts: 516
    edited December 2019
    We’re getting there! I found playing a 30Hz test tone can show a 3V AC drop on my Panamax regulator. I normally see anywhere from 122-125V. Earlier today it was at 122V and dipped to 119V playing that 30Hz sine wave. It went right back up to 122 after it stopped. I played the entire Test CD from 20Hz to 20khz. All the rest was ok.
    And also been reading.
    http://www.gr-research.com/burnin.htm
  • BlueFox
    BlueFox Posts: 15,251
    How about some music reviews? You can always add to it as they burn in.
    audioluvr Posts: 5,915
    Awesome! We're all coming over!
  • mpitogo
    mpitogo Posts: 516
    Listen to album, Explorations in Space and Time.
  • mpitogo
    mpitogo Posts: 516
    Hope everyone had a great holiday and a happy new year to come. I took a bit of a break from critical listening but still put enjoyable play time on them.
    One thing I’m exploring is a front end change from the McIntosh C47/MC452 combo. I’m not getting as much of the SDA effects as experienced at demos. Based on some feedback, I’m putting in a Marantz PM-10 and a Denafrips Aries II DAC.
    I did a quick comparison in my master bedroom between the MA-5200 and PM-10 on Totem Hawks and noticed increased clarity, sparkle and bass playing the same song. But that may also be the DAC as the MA-5200 has one built-in while I had to use an external DAC for the PM-10 so this change may also be attributable to the DAC. Further testing needed.
    tonyb Posts: 33,072
    soupbone wrote: »
    Crickets
    Probably sound pretty awesome on the L800's. Crickets all around you, pretty cool.
  • mpitogo
    mpitogo Posts: 516
    edited January 2020
    Part 3.
    How do they sound?
    Cross posting. Verdict :)
    I believe I have mine dialed in to resolve the balanced differential amplifier issue. I have my McIntosh C47 preamp bi-amp feeding both an MC450 bass and an MA5200 treble. The integrated was taken from my master bedroom which I’ve setup with HT-PassThrough on BAL1. BAL Output 1 and Trigger 1 goes to the MC452 and BAL Output 2 and Trigger 2 goes to the MA5200. Even though the input is Balanced the topology of the MA5200 is not fully balanced through to the output stage so the signal going to the mid/high has the full signal for improved SDA. I also compared the sonic qualities with my Rotel RA-1570 which also exhibited improved SDA imaging. The fully balanced output of the McIntosh MC452 and Marantz PM-10 did not provide the same effect as I heard in Polk’s demos (It was there but very subtle). I used John Rutters Requiem Pie Jesu from 1993 by Turtle Creek Chorale. The soundstage opens up when the whole choir comes in and you feel surrounded as the hall comes alive.
    As far as the non SDA aspect. The L800 are more similar to the LSiM707 than they are to my Martin Logan Motion 40 and Totem Hawks. The latter is always surprising, how they get the balance between the metal dome tweeter and doped paper cone woofer and how artfully they are melded together to create such sweet warm sounding combo which disappear. The hawks excel at providing great detail but will not rock very hard. They are best played at low to moderate volume but what you get is smooth silky midrange, capable bass without the need for a sub and a treble which is present but not as annoying (fatiguing) as what’s in my KEF L100. The Martin Logan’s are for my ears more dry, cold and in need of a sub. They can be played at high volumes but become harsh the folded motion tweeter can really move air but for me are bright and fatiguing. I currently have them in boxes but when I had them setup, they were in my 16x15 office setup using the Ken Ishiwata placement method and worked well.
    So how does the L800 compare, the plastic drivers are basically the middle ground between metal and paper, between cold and warm. Playing Melody Gardot Currency of Man album from cover to cover you get a very delicate presentation. Switch it up to more modern pop recordings Halsey, Taylor Swift, The Chainsmokers and you get a very energetic and full soundstage across a very wide band which you can push assuming you have good clean power. For my taste no subs are needed. I like the presence of deep bass but don’t need it ball shakingly overwhelming. Moving to classical, I played three version’s of Beethoven’s 9th symphony and pretty amazed at each recording and what instruments they pickup and reproduced playing through the L800s. The recordings still got too crowded/compressed when there’s alot going on, its as close to a concert but not quite like being there. I am going to see the NJSO perform at NJPAC this Saturday for Mozart’s Don Giovanni and Figaro so I‘ll have fresh material to compare, experientially.
  • Mankite
    Mankite Posts: 14
    So can you run room correction like audyssey XT32 with these speakers or is it recommend just to address the sub with correction?
    F1nut Posts: 51,763
    Mankite wrote: »
    It'll likely tell you the speakers are out of phase, but that happens with standard speakers as well.
    Clipdat Posts: 13,095
    mpitogo wrote: »
    @mpitogo, are you running all of your equipment through the Panamax?
  • mpitogo
    mpitogo Posts: 516
    As as said earlier, wow! So I recently went to see NJSO and no comparison but home reproduction has usually been a compromise.
    The real wow was from playing the LP of The Flaming Lips Oczy Mlody - One Night While Hunting for Faeries.
    @mpitogo so is that a yes/no on the Panamax powering everything?
  • mpitogo
    mpitogo Posts: 516
    edited January 2020
    Hi @Clipdat no. The model I have is a PM-5400. Are there better? Probably but I'm not really into power cables, power plants etc. I don't hear much of a difference between the wall and with a power conditioner. I bought different power cables but did not notice any beneficial gain.
    I hear more differences in amps, speakers, sources, DACs than in cables and power but that's just me. I did some testing between AQ Mackenzie XLR vs Monoprice Premium XLR and maybe my system is not high end enough for me tell the difference.
  • ptrooper
    ptrooper Posts: 501
    edited January 2020
    What cables do you run?
    I have noticed Allot of people here agree to Mit cables, they apparently go extremely well with their systems. I started looking into them and loved the the way you can change their impedance to match equipment with a simple little switch!.
    I myself was too deep into Transparent cables before knowing about Mits and have recently stopped upgrades at MM2'S which made a huge difference being two lvls up from their reference line!.
    I think most people here said the best value for money was Mit s3.1's or 1.3's.
    Some one might chime in regarding the model numbers. I'll bet Mr lefty and righty that good cables will really expand your L800 sound stage and put a smile on your mellon!.
  • Emlyn
    Emlyn Posts: 4,705
    I have found over the years that the main benefit of using MIT Shotgun and up series is the holographic sound image they help produce compared to others. Take them out of the loop and to me stereo goes flat. Bass reproduction is also great and gets better with more "poles of articulation" the more expensive the cables are. The switchable impedance on interconnects I have not found to be a big factor because most gear operates in similar ranges. Speaker cables of course don't even have that.
    Others may prefer a more direct/accurate sound, like something from Audioquest, Kimber, and many others. I've tried others and always fall back to MIT cabling (except for power cords). I simply find they produce a more entertaining sound quality for music.
  • joecoulson
    joecoulson Posts: 4,943
    The common theme we all agree on is synergy.
    I didn’t believe that conditioners made a difference until I took a chance on one. Now I cannot imagine my system without it.
    The type of system I have built revolves around the music I listen to. Diverse but more centered around electronic. Therefore AQ serves me well as a more direct/accurate sound as stated above.
    But through all of this, I wouldn’t discount cables and power to be unnecessary. But I would say they need to be properly selected.
  • mpitogo
    mpitogo Posts: 516
    edited January 2020
    Hi @ptrooper
    for interconnect I am using AQ Mackenzie XLR
    for speaker I am using BlueJeansCables Canare 4S ultrasonically welded onto spades
    for power I am using the OE cables
    The biggest change for me on the L800 was the move from McIntosh MC452 and Marantz PM-10 to McIntosh MA5200 for the treble section (SDA). This was truly a game changer, the MC452 still services the bass and had a warmer sound but the single ended direct coupled output of the MA5200 really brought SDA to life.
    The best way to illustrate this is to show via an image. The two balanced amps were feeding the SDA channel with only half of the signal while the single ended MA5200 was in your head and really brought out the soundstage they were intended to. If anything maybe a bit more than I expected since sometimes it seems the sound is coming from behind me, eg The Flaming Lips Oczy Mlody. But for other like Karen Elson Double Roses or The Kills Ash & Ice albums the sound stage was more expanded beyond the borders of the speakers.
    OR
  • BlueFox
    mpitogo wrote: »
    Other than these two sentences in November 2019, you have not provided a speaker review.
