Post a picture... any picture
Ivan, that was the same one we heard at Axpona - and again, best system I have heard in my lifetime. Amazing stuff.
That vertical VAC integrated is the pinnacle of audiophile design and quality. Lust-worthy.
Roommates bike.
afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Blue Ridge Parkway
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
My wife’s design handiwork....
My Father-in-law and my labor in building the counters, and then installing everything.....
PS we are NOT DONE, so I already know I need to sand/fill/paint the one section and redo the backsplash to continue it all the way down on the backside..."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Can I make a suggestion?
Building the counters......elaborate por favor.Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!!
They appear to be epoxy coated.
joecoulson wrote: »Can I make a suggestion?
You can..... but it’s already basically done lol"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
The old ones were your normal Home Depot Builder grade.
We took those out, made our own templates and then built them out of MDF with 3/4 top and then strips underneath to provide a 1.5” lip. Then measure and cut the sink out.
Wife then prepped and epoxied them, and then we installed them, and the sink..."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Was just going to say, where you doubled in material on the edge for thickness, if you use Bondo for automotive, you will be able to get a great edge like the top surface. Otherwise over time it will start to separate. We build hundreds of MDF tops every year and use this all the time and MDF does not do well with any sort of paint on the ends without help.
joecoulson wrote: »Was just going to say, where you doubled in material on the edge for thickness, if you use Bondo for automotive, you will be able to get a great edge like the top surface. Otherwise over time it will start to separate. We build hundreds of MDF tops every year and use this all the time and MDF does not do well with any sort of paint on the ends without help.
Good to know, lol.... Bit late in the game unfortunately lol...
Does it make a difference if we used epoxy over primer?
She ran the epoxy down the edges not just over the top."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Epoxy will help hold it together on the ends, however expect over time for the ends of the top to expand. Just humidity will do it.
Looks great though. -
joecoulson wrote: »Epoxy will help hold it together on the ends, however expect over time for the ends of the top to expand. Just humidity will do it.
Looks great though.
Gotcha. We let it drip over all the sides and the 1.5 reveal is over the entire border, not just the front. This is also a short term solution.
We still want solid stone, just not where we can afford it right now lol...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Not bad for a Computer nerd...
Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
The maiden voyage has begun...
First wall has been framed in what I am predicting to be a 2 year project.Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
There isn’t one, until my wife decides she wants it done.
If I didn’t have kids, more time would be devoted to the cause. Unfortunately, the little, uh, loves of my life, consume any free time that I stumble upon. Thus, a prediction of 2 years. Could be less, but could also be WAY more.Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
You can come up and do mine when you're finished
Too much snow...mhardy6647 wrote: »You can come up and do mine when you're finished
The rebooted TWA terminal @ JFK: From back when the world was cool
TWA Hotel KJFK New York NY 2019 0013 by ✈ concord⁹⁷⁷, on Flickr
TWA Hotel KJFK New York NY 2019 0006 by ✈ concord⁹⁷⁷, on Flickr
TWA Hotel KJFK New York NY 2019 0011 by ✈ concord⁹⁷⁷, on Flickr
TWA Hotel KJFK New York NY 2019 0015 by ✈ concord⁹⁷⁷, on Flickr
Ol' Blue Eyes should be standin' next to that Connie, hat on and tipped at a jaunty angle.
Blade Runner 2049 4K Ultra HD. Picked up a Sony 4K UHD Blu-ray player UBP-X700. Performs flawlessly! Really nice 4K player for under buck fifty. -
