Looking forward to L800 but have concerns, what are your thoughts?
The only thing I could do to improve upon that is maybe adding a pic.
Right, here are what two right and one wrong speaker looks like. These are 7.5 feet apart and rear baffle is 14” in front of the rear wall.
- Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
- Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
- Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
- Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
- Office-2.1 B&W Formation Duo and Bass
- Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
- Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
- Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
- Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
- Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
- Maintenance: Pro-Ject VC-S Record Cleaning Machine
Well, they look all right to me.Post edited by pglbook on -
I have a hypothetical on the situation.
Is Frank Malitz a part of Polk now?
Kidding Kidding...
Having two right speakers, if you were to toe-in your left speaker so that the outside array is pointed at your listening spot and not use the SDA cable, shouldn't that work to get a good center image in non-SDA mode while you wait for the replacement? -
You're... right!
(y'all knew I was gonna do that...)
Seriously, and on topic -- @mpitogo are you currently using them as stereo loudspeakers (i.e., with the interconnect cable unplugged), or just using something else until things are sorted out with a proper L/R pair?
best way to avoid the aggravation. escape, At Avant Gardner watching Kim Petras concert.
Got a hold of dealer today. They will check warehouse if they have two “left” and will call me Monday to confirm swap scheduled tentatively for Wed. Another few more days...arg
Well there is sure some drama here! On multiple levels! Makes this a very nice thread to read @mpitogo ! Hope you get the correct speaker soon!
I have to smile a bit, forgive me, cause I know you're a bit frustrated. The human element is something you can never process out of. In my biz at the assembly plant, no matter how many fail safe process we put in (bar code scanners, colored light picks, mechanical features to distinguish left/right) sure enough a human can build it wrong! Just my experience.
At the end of the L800 distribution chain, there is a human being that has to pick the correct speakers! I predict that there will be huge left/right stickers on the boxes soon!
Hang in there!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
If you designed better cars and trucks, this would never happen.
Well John, I kind of knew that was coming.
Not really funny.
If fact, your incessant attacks on my ability to perform my job is really annoying to me. I've been ignoring the whole host of em since my disclosure of whom I work for, but in this case, on this thread, I don't appreciate it.
Not funny.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I used to work the trim and final assembly line at Subaru, and we used to joke about the guys in the shirts and ties coming up with stuff just to make our lives hell, and that is where that comes from. I remember, and never will forget one example.
We had two different ECU's for the Toyota Camry in 2008. One was 49 state compliant, and the other for California. they were labled CC and CG respectively. The font for these parts was insanely small like the fine print on a credit card application, and at a line speed of 90 seconds to install 23 small parts, you had less than a second to ID the part. The guys bringing parts to the line would even screw up and put them on the wrong shelf or the guys filling the parts bins off-line would even put them in the wrong box.
There were numerous other examples of this in the time I was there.
My apologies for the dig Verb, as I meant no offense. It was meant in the spirit of Navy/Marine jabber or "us vs. them" kind of banter.
My apologies.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Thanks John. Yep I have to smile in your above examples, as that still happens, but we have folks now that review the labeling and bar coding to make sure it's robust.
We have scanners in the station where the operators are supposed to scan, install, scan, etc., but they end up at times scanning a bunch and stockpiling em closer to the install locations, ugh!
Easy assembly is the key to great quality, for sure. Ergonomics is another area that we focus a lot on, hard to install usually means not installed correctly.
Your example above is a great illustration of what happened with the speakers, L/R not easy to read, easy to screw up!
And, for the record, I still love ya John! All good brother! Thanks for your comments, I know your just jabbing me, but, well, um, still love ya!
True... now if the suppliers and outside vendors would stop sending substandard parts. Thanks Takata!The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Not really funny.
Not funny.
Maybe a lot less of comparing everything to your job would help. Just saying, ya knowPolitical Correctness'.........defined
President of Club Polk -
Polk's new slogan.If you spend all your money on L800s and you have nothing LEFT it's going be all RIGHT.
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
looks the part...
It's going to be a REAL nice setup when it all gets sorted out.Right, here are what two right and one wrong speaker looks like. These are 7.5 feet apart and rear baffle is 14” in front of the rear wall.
I totally understand your point John. A place where I used to work new college "engineers" would come down every so often and try to reinvent the wheel, sort of speak. Lot's of us guys that had been there and on the job for 10+/20+ years didn't know a damn thing about what we were doing but the new young bucks knew everything, but had only been there a year or under. I didn't work on an assembly line, our work was hand crafted solely by us. A perfect example -
Engineers - "We're going to do such and such"
Regular Joe - "They tried that already, more than once"
Engineers - "But, we're going to it a little bit differently than last time"
Regular Joe - " (Roll eye's) Ok, here we go again..."
Then the engineers would look at us like we were total idiots.
Just the sheer arrogance of those people still gets my blood going...Remember, when you're running from something, you're running to something...-me -
I remember a thousand life-times ago when I was working as a train controller. I was a young fella working a night shift with an old seasoned veteran controller who actually had helped at the conclusion of WWII re-establish the railroads in Italy while in the service. He knew his shite, and had worked his whole career "in the trenches" so to speak, eventually culminating in his position as a controller. A young "train master" who had never worked a day in the trenches came in shortly before the start of the day shift, looked at the old guys train sheets and asked why the guy had set up a train meet at a certain time at a certain place. The old controller never blinked an eye, just looked up and said, "Because I saw fit to." He then turned back to his work. The "trainmaster" stood stunned until he turned on his heels and left the office without a further word. I should add the railroad unions were strong in those days.
We’ve talked a tad about life on the railroad Don. Boy the stories I could tell from my 6.5 years being an engineer and conductor! Not all bad but..., now back to our regularly scheduled program...Remember, when you're running from something, you're running to something...-me
@TennMan your quote just put a song in my head from a very wise singer, Bob Marley."...this is my message to you ooh oooh
singin' don't worry, bout a thing
cause every little thing, gonna be alRIGHT"
Left is scheduled for delivery tomorrow, whoo hoo!Polk's new slogan.If you spend all your money on L800s and you have nothing LEFT it's going be all RIGHT.
Now on a more serious note. If someone where to get two LEFTs, I have a song for that one as well.
Its by Leftfield from their album Leftism and the song is Inspection (Check One) because someone certainly didn't. Anyway I advise you to look it up and stream it, the L800's will certainly belt it out and will be magnificent.- Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
Good luck. Looking forward to your review.
This happened Saturday morning and they're not making it LEFT until Tuesday... that ain't RIGHT!
When the delivery man left he thought he had left the right speaker but he soon found out that what he left wasn't right. The good news is he plans to make it right on Tuesday. I'm looking forward to hearing the review of the L800s so I hope he doesn't get it wrong again. You know what they say... two wrongs don't make a RIGHT.
You guys aint right, but I will take whats left, dont worry- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Starting to sound like an Abbott and Costello bit...
ken brydson wrote: »Starting to sound like an Abbott and Costello bit...
Right you are!Stan
Main 2ch:
HT:
Other stuff:
More like Laurel and Hardy. At least Lou Costello knew his right from his left.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Well, todays the day! I'm sure you haven't slept much since the original day of delivery
Good Luck!
What's the break-in period on the L800's?
