This joint needs some more vintage hifi
1535456585962
    mhardy6647 Posts: 34,940
    Lots of nice stuff. Looks like even a Marantz 8 or 8B peekin' out from behind one of those Duplexes :)
    I am a big 8B fan. Nice, nice sounding amplifier (especially given that it's PP EL34).
  • Mikey081057
    Mikey081057 Posts: 7,127
    Garage | Polk Monitor 5B's
  • Mikey081057
    NU TZ is censored?
  • jdjohn
    jdjohn Posts: 3,329
    A Dual 1019...who else is excited?!?
    The underside of a DUAL... or a Garrard changer, for that matter...
    the stuff of nightmares.
    :o
  • jdjohn
    jdjohn Posts: 3,329
    Embrace the fear...
  • maxward
    maxward Posts: 1,679
    What could possibly go wrong?
  • tonyp063
    tonyp063 Posts: 1,131
    maxward wrote: »
    Everything.
    Ask me how I know.*
    * a 1237
    Steuerpimpel, baby.
  • jdjohn
    jdjohn Posts: 3,329
    :o
    Like this one?
    https://forum.polkaudio.com/discussion/comment/2482238#Comment_2482238
  • jdjohn
    jdjohn Posts: 3,329
    Found this vintage integrated amp amongst my dad's collection last weekend.
    Pioneer SA-8100:
    I did some testing/cleaning on it, so partially naked and in an awkward position in the pic. Based on initial tests, I think this will sound very nice once re-habbed a bit more.
  • Wardsweb
    Wardsweb Posts: 942
    I fixed this Nakamichi 700ZXE deck over the weekend.
    Nice deck, the 700...
  • maxward
    @jdjohn that is the same integrated I bought in 1973 for my first system. It had an aggressive loudness contour and I often had to turn it off after my roommates listened to it.
  • jdjohn
    jdjohn Posts: 3,329
    Aggressive, for sure. The entire complement of tone control adjustments is somewhat daunting. Luckily, they are stepped attenuators instead of pots, so not terribly noisy. But there is a little scratchiness somewhere that I am still chasing. Cleaning the volume and balance pots helped a lot, and showed me the potential this unit has. This unit has seen better days, but I think it still has some life left in it :)
    audioluvr Posts: 5,890
  • jbreezy5
    jbreezy5 Posts: 1,141
    jdjohn wrote: »
    I got a Dual 721. The speed varies a bit. I’m afraid to try to fix this after the photo. 😲
    Anyone know the pecking order for this against other Dual’s?
    Viking64 Posts: 7,528
    I wish I had one of those Dual turntables when I was in prison. I could have taken it apart and fashioned a whole sheeetload of knives out of it. :D
  • jdjohn
    jdjohn Posts: 3,329
    jbreezy5 wrote: »
    The 721 is a direct-drive, so much less complicated. It is well-worth fixing, as it was Dual's TOTL direct-drive...much quieter than their idler and belt-drive tt's.
    First thing to try is cleaning the fine-pitch potentiometer with DeOxit.
  • verb
    verb Posts: 10,176
    Viking64 wrote: »
    Oh. When did you get out? :smile:
    verb wrote: »
    Viking64 wrote: »
    Sorry, I was a little deceptive with how I worded that.
    I am up for parole in 2023.
  • krazypolk
    krazypolk Posts: 745
    Viking64 wrote: »
    verb wrote: »
    Viking64 wrote: »
  • jdjohn
    jdjohn Posts: 3,329
    Viking64 wrote: »
    I call BS. A man with real time in the joint would know they are called 'shanks'...not knives :p I've seen movies and stuff.
  • jbreezy5
    jdjohn wrote: »
    jbreezy5 wrote: »
    Thanks!
    The plasticky base had me wondering; but the walnut finish, spring suspension, and tonearm seem top notch, as you say.
  • jdjohn
    jdjohn Posts: 3,329
    There were always 'options' when purchasing new turntables, so the plinth/base was one such option. Yours has the 'tray' option, but here is one (mine :) ) that has the wooden plinth option.
    The (suspended) chassis is the same for both, but the base/plinth is different. The included cartridge was another option.
    One nice feature of the 721 is that the tonearm counter-weight had more advanced anti-resonance properties. In fact, the stock counter-weight on a 721 (and same design from a few other models) is considered an upgrade to counter-weights on earlier Dual turntables with similar fittings.
  • soundfreak1
    soundfreak1 Posts: 3,414
    krazypolk wrote: »
    Viking64 wrote: »
    verb wrote: »
    Viking64 wrote: »
    That's cold man....cold.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • jbreezy5
    jdjohn wrote: »
    I think I have seen the base you’re sportin’. I’m gonna be on the lookout for one now.
  • maxward
    Looks great! What finish did you use? Nice looking isolation base, too.
  • Wardsweb
    Wardsweb Posts: 942
    maxward wrote: »
    Liberon Finishing Oil
