Looking for Misc Audio Deals of the Day? Updated info here!
1300301303305306359
  • ken brydson
    ken brydson Posts: 8,981
    FestYboy wrote: »
    verb wrote: »
    Interesting piece. Sony 400 disc CD/DVD/SACD player for only a hundie! :smile:
    https://detroit.craigslist.org/okl/ele/d/clawson-sony-es-dvp-cx777es-400-disc/6995482640.html
    I have the 200 disk, non-ES version of this and it's rock solid... If that was local it'd be in the house right now. I've never had an issue with any Sony product I've owned.
    Ageed. I have a 200 AND a 400 disc player. Both have worked flawlessly since I got them in the 90's. High fidelity? Nope, but damn convenient. Doesn't sound bad to me in my meager rig though. I can hit random play it they will go for months, lol
  • codycatalist
    codycatalist Posts: 2,662
    Not sure this fits the spirit of this thread :p but it probably fits the letter of the thread's title B) ...
    PE has a big buyout sale of cheap, Chinese-sourced audio ('hifi' ?!?) components from "FX Audio"! :) Now, there's a little preamp sold under this brand name that's all the rage in some circles (I'm not endorsin', I am just sayin') -- that little preamp is not one of the little boxes available, but there are a bunch of things... and they are all cheap!
    I have one of them little preamp things. It's not bad at all, I even have it hooked up to a linear power supply. I can't compare it to anything as I haven't heard a real tube pre but it does impart qualities to my sound I like.
    To be honest with the tearing down of my system I've been thinking of giving it away in a Karma with said power supply to someone who may get more use out of it than I.
    Is that the "31 dollar" thing that certain folks are going absolutely nutso about elsewhere? :#
    https://audiokarma.org/forums/index.php?threads/fx-audio-6j1-tube-preamp-a-31-wonder.848535/
    FWIW, this isn't one of the components in PE's buyout sale :|
    Indeed it is Doc, indeed it is.
  • aprazer402
    aprazer402 Posts: 3,352
    ZLTFUL wrote: »
    aprazer402 wrote: »
    https://omaha.craigslist.org/ele/d/omaha-klipsch-klipschorns/6995747988.html
    No Affil.
    I'm not quite sure what the seller is trying to describe about enclosing them off and clay on the rear. I last heard a pair of these in probably 1973 at a dealer's showroom.
    They look good, could probably be returned to original configuration.
    The Klipschorns were often backless as they are meant to be corner loaded. Enclosing the rear of the cabinet allows for them to be placed elsewhere (and generally ruins them too).
    The clay is in reference to duct sealant clay being used on the horn itself to dampen resonances.
    Thanks for explaining. I wasn't considering them. I have too many big boxes now. :)
    mhardy6647 Posts: 34,918
    edited October 2019
    aprazer402 wrote: »
    No Affil.
    Folks go to great lengths to keep Klipsch loudspeakers from sounding like Klipsch loudspeakers :|
    BTDT.
    Klipschorns are clever folded bass horns that were purpose-built to use the room corner as part of the horn expansion.
    (borrowed image)
    The "enclosed" part means (should mean, I think) that they've had 'artificial' corners added to them so that they don't have to be jammed fairly tightly into corners. The newest morph of the K-horns are built so that they can be in corners or not (IIRC).
    As to the 'clay' -- I think they've damped the horns with rope caulk (or modelers' clay, perhaps?) in a more-or-less futile attempt to control the notorious ringing thereof. :|
    Here's the damping I attempted on my Cornies' MR horns. Helped a tiny bit, but they're almost unbearably shouty horns (with very cheap, low quality Atlas PA compression drivers, in this particular case -- 1974 vintage).
    9592399107_d4c397963d_z.jpgdampedcornyhornies by Mark Hardy, on Flickr
    K-horns are actually OK; best of the 'heritage' Klipsch lot overall (closely followed by
    the Cornies, which can still produce reasonable bass without being in the corners).
    The LaScala, and its domestic cousin, the Belle, are best used for torture (regulated by international convention) or for removing paint. The Heresys are best used as kindling.
    B)
    Viking64 Posts: 7,508
    Mark, that is the CORNIEST post you have ever made.
    The same could be said for my "joke". :|
    EndersShadow Posts: 17,687
    Viking64 wrote: »
    Its almost "Heresay"........
    nooshinjohn Posts: 25,878
    edited October 2019
    Viking64 wrote: »
    Mark, that is the KHORNIEST post you have ever made.
    Fixed...
  • joecoulson
    joecoulson Posts: 4,943
    I have had the 300 cd changer for almost 20 years. I did have to replace the rubber bands inside for the gears
  • verb
    verb Posts: 10,176
    Conrad Johnson, Audio Research, LFD, Rega, B&W, turnkey system, Oh my! :) 42 hundie OBO!
    https://detroit.craigslist.org/mcb/ele/d/flint-conrad-johnson-tube-amp-rega/6999320415.html
  • verb
    verb Posts: 10,176
  • dromunds
    dromunds Posts: 10,097
  • CGTIII
    CGTIII Posts: 1,234
    Could be trolling. I've seen that around here with RVs and such that are dramatically underpriced.
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
  • CGTIII
    CGTIII Posts: 1,234
    Probably not then since he responded. At least that's not the kind of trolling I was talking about. Great deal for someone here I hope! :-)
  • displayname
    displayname Posts: 1,202
    If anyone has been on the fence about trying Tidal, I just got an ad offering $20.20 for 4 months of Tidal HiFi. Also supports Rock the Vote if you're into that.
    https://offer.tidal.com/campaigns/5d9b6208fb206600114b969e/products
    Analog: Hana ML > MoFi UltraDeck > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
    MastersounD Dueventi > Rosso Fiorentino Certaldo or Hifiman EF600 > Hifiman Arya Stealth
    Discogs
  • CGTIII
    CGTIII Posts: 1,234
    edited October 2019
    Lexicon Digital Controller DC-1. Not a beauty but no bids yet and reasonable shipping. No affiation. :D
    https://www.shopgoodwill.com/Item/78017076
    audioluvr Posts: 5,877
    Not exactly the Telefunken that Frank was was referring to but hey!
    https://portland.craigslist.org/mlt/msg/d/portland-dual-channel-telefunken-v672/7000800538.html
    Don't know crap about turntables but back in the day this was one of the "go to" TT's
    https://portland.craigslist.org/mlt/ele/d/portland-sota-sapphire-turntable-with/7000442790.html
  • JayCee
    JayCee Posts: 1,502
    For all you Niagara fans. Not sure if this is a good deal but appears to be?
    https://forum.psaudio.com/t/fs-audioquest-niagara-1000/13556
    "FS: AudioQuest Niagara 1000
    New price was $995. Selling for $585 plus shipping. If paying with PayPal add 3% unless doing FF . I’m rating this an 8.5/10, I suspect most sellers would rate it 9/10 but I’m very conservative in my ratings, hard to photograph since it’s so shiny! All boxes packing etc."
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • aprazer402
    I will probably be acquiring this in the near future. Free too! Looks intact, it's an 800-B. I will need to get my learn on! A certain guy that resides in NH always provides good advice and information on these. Thanks in advance. :)
  • Nesmith98
    Nesmith98 Posts: 224
    edited October 2019
    Pass Labs x250.5 near Cleveland. $3400
    https://usaudiomart.com/details/649561378-pass-labs-x2505/
    Post edited by Nesmith98 on
  • boston1450
    boston1450 Posts: 7,758
    la2vegas wrote: »
    What's with all the vintage Fisher all of the sudden?
    https://youtu.be/cfOSzIGj6mc
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • verb
    verb Posts: 10,176
    My ignorant past and poor decisions keeps coming back to torment me! Minty BSR Colossus speakers from DAK Industries! :) 75 bucks! And they are minty! :)
    https://detroit.craigslist.org/mcb/ele/d/sterling-heights-minty-pair-of-the-bsr/7003998048.html
    Tony M Posts: 11,567
    edited October 2019
    la2vegas wrote: »
    Misc audio equipment, no affiliation. https://orangecounty.craigslist.org/ele/d/garden-grove-altec-speaker-cd-sony/7003641546.html
    Does anyone have any info on those speakers?
    Somebody is going to get the deal of the year right there! :o;)B) I'd have them all here by now! :p
    Don't know a thing about the speakers but I think they might be worth thousands.
    A pr. of some similar. I see they are different model #s. They look to be similar in size.
    ...Raleigh craig's list. 1800.00
    https://raleigh.craigslist.org/ele/d/durham-altec-lansing-846a-valencia/6980722081.html
  • verb
    verb Posts: 10,176
    edited October 2019
    Hermitism wrote: »
    Thank you Hermit! My first set of speakers from back in my youth! At the time I loved DAK, bought a lot of stuff from them, thought they were the schizzle! Some of the stuff was decent, I still have a SAE amp from them, but those speakers, well, meh! :)
    So every time one of these sets pop up, I'm reminded of my ignorance was bliss youth! :)
  • verb
    verb Posts: 10,176
    Well, this would have been worth a little road trip if only a bit closer! About 2 hours away from me. Would be fun to go through, if the seller was willing to part em out. Could be some jewels in there! :smile:
    https://flint.craigslist.org/ele/d/goodrich-massive-estate-of-approx-5000/7003186604.html
    pitdogg2 Posts: 26,932
    verb wrote: »
    That would be a nightmare....
  • BlueFox
    BlueFox Posts: 15,251
    la2vegas wrote: »
    Not sure if it's a deal, especially with the described issue, no affiliation. umlymh6nkxia.jpg
    https://orangecounty.craigslist.org/ele/d/anaheim-sunfire-tga-5400-amplifier/7005600746.html
    So far, my TGA-5400 works great, although it is only used for the center and rears.
  • Dabutcher
    Dabutcher Posts: 2,604
    edited October 2019
    Some Marantz gear and Denon TT and Maybe Wilson Puppy speakers at local auction Monday night. Too rich for my blood so I thought I would share it.
    Love yours. D
    https://app.sparkmailapp.com/web-share/T0liTxZXYkY0jXK-XjdCEy7vLn56bwo1-zdvmxIPbrqq0357f7pn.png
