Looking for Misc Audio Deals of the Day? Updated info here!
1302303305307308357
    tonyb Posts: 32,906
    mrbiron wrote: »
    Your like the audiophile version of the Frugal Gourmet...
    LMAO...Probably the best description of Doc I've heard to date.
    Tony M Posts: 11,017
    more like American Dumpster Divers.
    I'm a long time member for sure. :pB)
    mhardy6647 Posts: 33,046
    edited October 2019
    e-mail sale flyer from MusicDirect (FWIW):
  • verb
    verb Posts: 10,176
    Interesting piece. Sony 400 disc CD/DVD/SACD player for only a hundie! :smile:
    https://detroit.craigslist.org/okl/ele/d/clawson-sony-es-dvp-cx777es-400-disc/6995482640.html
  • delkal
    delkal Posts: 764
    verb wrote: »
    It is interesting. Until 400 of your CDs get jammed up in it. Then you are cursing!
    pitdogg2 Posts: 24,579
  • codycatalist
    codycatalist Posts: 2,662
    Not sure this fits the spirit of this thread :p but it probably fits the letter of the thread's title B) ...
    PE has a big buyout sale of cheap, Chinese-sourced audio ('hifi' ?!?) components from "FX Audio"! :) Now, there's a little preamp sold under this brand name that's all the rage in some circles (I'm not endorsin', I am just sayin') -- that little preamp is not one of the little boxes available, but there are a bunch of things... and they are all cheap!
    I have one of them little preamp things. It's not bad at all, I even have it hooked up to a linear power supply. I can't compare it to anything as I haven't heard a real tube pre but it does impart qualities to my sound I like.
    To be honest with the tearing down of my system I've been thinking of giving it away in a Karma with said power supply to someone who may get more use out of it than I.
    verb wrote: »
    To quote the best boss I ever had*
    Mark. We don't need "interesting".
    _________________
    * Sometimes, when he asked me about some big issue that we were working on in the lab, I would say, "Well, it's interesting..." :p
    edited October 2019
    Is that the "31 dollar" thing that certain folks are going absolutely nutso about elsewhere? :#
    https://audiokarma.org/forums/index.php?threads/fx-audio-6j1-tube-preamp-a-31-wonder.848535/
    FWIW, this isn't one of the components in PE's buyout sale :|
  • aprazer402
    aprazer402 Posts: 3,097
    edited October 2019
    https://omaha.craigslist.org/ele/d/omaha-klipsch-klipschorns/6995747988.html
    No Affil.
    I'm not quite sure what the seller is trying to describe about enclosing them off and clay on the rear. I last heard a pair of these in probably 1973 at a dealer's showroom.
    They look good, could probably be returned to original configuration.
    Post edited by aprazer402 on
  • FestYboy
    FestYboy Posts: 3,861
    verb wrote: »
    I have the 200 disk, non-ES version of this and it's rock solid... If that was local it'd be in the house right now. I've never had an issue with any Sony product I've owned.
  • ken brydson
    ken brydson Posts: 8,650
    FestYboy wrote: »
    verb wrote: »
    Ageed. I have a 200 AND a 400 disc player. Both have worked flawlessly since I got them in the 90's. High fidelity? Nope, but damn convenient. Doesn't sound bad to me in my meager rig though. I can hit random play it they will go for months, lol
  • codycatalist
    Indeed it is Doc, indeed it is.
  • ZLTFUL
    ZLTFUL Posts: 5,640
    aprazer402 wrote: »
    No Affil.
    The Klipschorns were often backless as they are meant to be corner loaded. Enclosing the rear of the cabinet allows for them to be placed elsewhere (and generally ruins them too).
    The clay is in reference to duct sealant clay being used on the horn itself to dampen resonances.
  • aprazer402
    ZLTFUL wrote: »
    aprazer402 wrote: »
    No Affil.
    Thanks for explaining. I wasn't considering them. I have too many big boxes now. :)
    edited October 2019
    aprazer402 wrote: »
    No Affil.
    Folks go to great lengths to keep Klipsch loudspeakers from sounding like Klipsch loudspeakers :|
    BTDT.
    Klipschorns are clever folded bass horns that were purpose-built to use the room corner as part of the horn expansion.
    (borrowed image)
    The "enclosed" part means (should mean, I think) that they've had 'artificial' corners added to them so that they don't have to be jammed fairly tightly into corners. The newest morph of the K-horns are built so that they can be in corners or not (IIRC).
    As to the 'clay' -- I think they've damped the horns with rope caulk (or modelers' clay, perhaps?) in a more-or-less futile attempt to control the notorious ringing thereof. :|
    Here's the damping I attempted on my Cornies' MR horns. Helped a tiny bit, but they're almost unbearably shouty horns (with very cheap, low quality Atlas PA compression drivers, in this particular case -- 1974 vintage).
    9592399107_d4c397963d_z.jpgdampedcornyhornies by Mark Hardy, on Flickr
    K-horns are actually OK; best of the 'heritage' Klipsch lot overall (closely followed by
    the Cornies, which can still produce reasonable bass without being in the corners).
    The LaScala, and its domestic cousin, the Belle, are best used for torture (regulated by international convention) or for removing paint. The Heresys are best used as kindling.
    B)
    Viking64 Posts: 6,688
    Mark, that is the CORNIEST post you have ever made.
    The same could be said for my "joke". :|
    EndersShadow Posts: 17,534
    Viking64 wrote: »
    Its almost "Heresay"........
    nooshinjohn Posts: 25,100
    edited October 2019
    Viking64 wrote: »
    Mark, that is the KHORNIEST post you have ever made.
    Fixed...
  • joecoulson
    joecoulson Posts: 4,943
    I have had the 300 cd changer for almost 20 years. I did have to replace the rubber bands inside for the gears
  • verb
    verb Posts: 10,176
    Conrad Johnson, Audio Research, LFD, Rega, B&W, turnkey system, Oh my! :) 42 hundie OBO!
    https://detroit.craigslist.org/mcb/ele/d/flint-conrad-johnson-tube-amp-rega/6999320415.html
  • verb
    verb Posts: 10,176
  • dromunds
    dromunds Posts: 9,984
  • CGTIII
    CGTIII Posts: 1,028
    Could be trolling. I've seen that around here with RVs and such that are dramatically underpriced.
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
  • CGTIII
    CGTIII Posts: 1,028
    Probably not then since he responded. At least that's not the kind of trolling I was talking about. Great deal for someone here I hope! :-)
  • displayname
    displayname Posts: 1,132
    If anyone has been on the fence about trying Tidal, I just got an ad offering $20.20 for 4 months of Tidal HiFi. Also supports Rock the Vote if you're into that.
    https://offer.tidal.com/campaigns/5d9b6208fb206600114b969e/products
    Analog: MoFi MasterTracker > MoFi UltraDeck > Sutherland 20/20
    MastersounD Dueventi > Rosso Fiorentino Certaldo or Arcam rHead > Hifiman HE4XX
    Discogs
  • CGTIII
    CGTIII Posts: 1,028
    edited October 2019
    Lexicon Digital Controller DC-1. Not a beauty but no bids yet and reasonable shipping. No affiation. :D
    https://www.shopgoodwill.com/Item/78017076
    audioluvr Posts: 5,437
    Not exactly the Telefunken that Frank was was referring to but hey!
    https://portland.craigslist.org/mlt/msg/d/portland-dual-channel-telefunken-v672/7000800538.html
    Don't know crap about turntables but back in the day this was one of the "go to" TT's
    https://portland.craigslist.org/mlt/ele/d/portland-sota-sapphire-turntable-with/7000442790.html
