New Speakers
2
  • Nightfall
    Nightfall Posts: 9,426
    Clipdat wrote: »
    What kind of speaker cables were you using with them, just simply out of curiosity.
    https://hifiheaven.net/shop/MIT-StyleLine-SL-12-Speaker-Interface-Cables-10ft-Pair
    afterburnt wrote: »
    Village Idiot of Club Polk
    Clipdat Posts: 9,475
    Nice! I like MITs but they didn't play nice with my PMC speakers.
    You might try a different brand of speaker cables with them if you have a spare pair.
  • Nightfall
    edited September 2019
    Clipdat wrote: »
    ...and interconnects or just speaker cable? MIT interconnects too.
    I have nothing else. Suggestions?
    afterburnt wrote: »
    Should be fine to keep the same interconnects, but I just think it's possible that MIT doesn't always play well with all brands of speakers.
    I don't really have any suggestions, but this is what I'm using right now and I've been extremely impressed with them: https://www.ebay.com/itm/KnuKonceptz-Krux-Interlaced-Braided-8-Gauge-Bi-Wire-Speaker-Wire-Cable-8-Pair/382747321152
    They also offer a single wire version which I also have that I'm not using currently, I could send them to you to try out for a while.
    They're an 8' foot pair, is that long enough?
  • SIHAB
    SIHAB Posts: 2,095
    Analysis Plus copper oval ## should work well with this speaker.
    This might be the wrong type of speaker for your application...
  • Nightfall
    So I take it I would like but not love Harbeth and Spendor?
    afterburnt wrote: »
    tonyb Posts: 32,154
    DSkip wrote: »
    Nightfall wrote: »
    I wouldn't go that far. Harbeth is not rolled off on the top end. I can't speak for Spendor.
    The US importer for Harbeth IS quick to mention that these speakers are not intended to be rock out speakers, but that doesn't mean they can't do it. The only one I see really struggling with Rock is the little P3ESR. My personal feelings towards this speaker is that its a helluva nearfield monitor anyways.
    I would agree with that also. Steve has had the P3's and also felt Rock was their weaker link. The 5's should do better with Rock music, but for the price of the 5's, your options open up fairly wide.
  • SIHAB
    SIHAB Posts: 2,095
    I was hoping Skip would jump in. The Harbeth P3ESR aren't rated to go as low
    as the WD equivalent, but as noted rock isn't the strong suite. HOWEVER,
    what the P3's do is darn near perfect. Rock and Jazz were good and you
    were left with a feeling of "I want more good" rather than lacking.
    Anyway, I would be interested in @DSkip experience w/ cables and this
    type if speaker...
  • Nightfall
    @DSkip Could cables make or break these speakers?
    afterburnt wrote: »
  • marvda1
    marvda1 Posts: 4,292
    @nightfall, what's the rest of your system?
    Transport/Dac: L.K.S MH-DA004, Cayin Venus cd-100i, Musical Paradise mp-d2 mkI,
    Musical Paradise mp-d2 mkIII
    Speaker Cables: Organic Audio Organic Reference 2
    Cerious Technologies Graphene Extreme
    Interconnects: Argento Organic Reference 2, Argento Organic 2, Gabriel Gold Reckoning
    Power Cables by: Argento Organic Reference, Cullen Cables, 6sons Audio, Swiss Cables
  • Nightfall
    Dared MC-7P tube preamp, RCA 5U4GB, RCA 6V6, Amperex 12AT7, Amperex 12AX7 X2, PSVane 12AX7 X2 Special Edition.
    B&K Reference 4420 350 watts @ 4 ohm
    Cambridge CXN
    PS Audio, Wireworld, and the brand bluefox uses (brain ****) power cords. Edit: Shunyata
    afterburnt wrote: »
  • marvda1
    if you want to try new cables look into analysis plus and straley reality cables.
    reality has two lines, standard and reference, i am about publish a review on the reference line.
  • Nightfall
    I'm too poor for that concept. ;) I need all speakers to work perfect on what I got.
    afterburnt wrote: »
  • marvda1
    the new usher book shelf
  • Nightfall
    I've always thought of cables as fine tuning, not make or break difference.
    afterburnt wrote: »
  • Nightfall
    DSkip wrote: »
    Nightfall wrote: »
    They make or break every system. With that said, every component is important and blindly blaming cables probably isn't ideal. The B&K might not be the right fit for those speakers honestly. If you've got some speakers that are dark and also have no top end extension, you're going to want gear behind it to liven it up.
    So I need to get my Yamaha CA-1010 repaired and recapped.
    afterburnt wrote: »
  • Nightfall
    What about the small sound stage? You could say the room is the problem then I'd say why isn't it for the Dyn's.
    afterburnt wrote: »
  • BlueFox
    BlueFox Posts: 14,197
    Nightfall wrote: »
    I used to think that, but then I realized that cables and power are the foundation for a stereo. The better the foundation then the better the stereo.
    Lumin X1 file player
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
  • How far do you have them out from the front wall?
    First Watt,Monarchy Audio,Aric Audio,Promitheus Audio,April Music,Wyred4sound ,Bluesound,Pro-Ject,Onkyo,Graham Chartwell,Nola,Hornshoppe,HSU Research.
  • Nightfall
    Back wall? (I might just be confused what's considered front and back) 15"
    Any further from the wall and they'd need to be closer together to make an equilateral triangle and they're right up against the sides of my Salamander rack already.
    afterburnt wrote: »
  • I would try getting them out 2' or so. It's just an experiment,so don't worry about the equilateral triangle. More near field listening in this case. They may just need a little "breathing" room.
  • dromunds
    dromunds Posts: 9,236
    I always liked that look.
  • Nightfall
    edited October 2019
    dromunds wrote: »
    It's all subjective. Just IMO.
    They look like they're straight out of a 1980's living room when their grills are on.
    afterburnt wrote: »
  • dromunds
    I have their big brother.
  • Nightfall
    How do you like them?
    afterburnt wrote: »
  • dromunds
    I always liked the vintage Infinity sound. Those EMIT tweeters are nice.
  • Nightfall
    edited October 2019
    I am really starting to fall in love with these speakers. They throw sounds all over the room like nobody's business. Some sounds come from well behind the speakers.
    Have any of you ever gotten crossovers redone on an Emit era pair of Infinity? Are they pretty complex or relatively simple crossovers?
    How about removing the tweeter pots from the circuit?
    afterburnt wrote: »
  • erniejade
    erniejade Posts: 5,536
    marvda1 wrote: »
    I think that guy lives out by me if it's who I am thinking of.
    Den: Lumin D1,Wireworld Silver Eclipse RCA, KEF LS50 Wireless, Velodyne SPL1200, Technics 1200, Denon DL160, Jolida D9,
    Living Room:,T+A PA 1530R,Wireworld Silver Eclipse SC, Tyler Highland H2, High Fidelity Reveal RCA, Innuos Zen MK3 , W4S recovery, LKS MH-da004,
    Have but haven't used in a while: LH Labs VI Dac, Cayin SCD50T, Grant Fidelity Tube Dac11,Aries Mini
Howdy, Stranger!
