Will my system work?
12345679»
  • mrloren
    mrloren Posts: 2,474
  • kharp1
    kharp1 Posts: 3,453
    Geoff4rfc wrote: »
    Romo11 wrote: »
    mrloren wrote: »
    What RCA cables are you using? Try a different outlet if you can.
    They aren’t the best for sure. I got them off of amazon. I’m going to wait until this weekend, when there aren’t as many distractions around to start going through the elimination game.
    Thanks for the suggestion,I’ll try that first.
    If you're handy with a soldering tool, I got my RCA materials from @helipilotdoug also known as Douglasconnection.com. And he not only treats Polk members right, he's that way with everyone. Well, he's a Texan, what more can I say :D
    I made some great RCA's that are hard pressed to beat quality-wise unless you spend hundreds....
    And he offers a discount for forum members as well.
  • PSOVLSK
    PSOVLSK Posts: 5,402
    kharp1 wrote: »
    Geoff4rfc wrote: »
    Romo11 wrote: »
    mrloren wrote: »
    AND you're already using his speaker cables ;)
  • Romo11
    Romo11 Posts: 101
    Thanks for the recommendations. That’s what I was looking for. I thought that maybe I had purchased the wrong ones. Was kinda hoping that I had.
    Anyhow I appreciate it very much.
  • Romo11
    Romo11 Posts: 101
    PSOVLSK wrote: »
    kharp1 wrote: »
    Geoff4rfc wrote: »
    Romo11 wrote: »
    mrloren wrote: »
    Dang,
    I forgot that I even bought those cables! It’s been a crazy summer so far. They will be connected very soon. Keeping my grandson today and tomorrow but I promise they will be hooked up.
    I’m so embarrassed but I truly have had a lot on my plate. This gives me something positive to think about. Thanks for bringing it up.
    Rob
  • mdaudioguy
    mdaudioguy Posts: 5,164
    Clipdat wrote: »
    Lame, your Yamaha only has XLR outs for the front L & R. Lame cost cutting move on Yamaha's part.
    Sarcasm, right?
    Clipdat Posts: 13,100
    edited July 2019
    No, that was actually a serious comment. It just seemed strange to me to only have XLRs out for the front L and R, and not the rest of the channels. This is a $2,000 AVR, and there's room for XLR outs for all channels. Doesn't make sense to me why Yamaha wouldn't include them, unless it was a cost cutting measure.
    His Outlaw amplifier has XLR inputs, so I was going to suggest he run XLRs to mitigate that noise he was mentioning, as I believe that would certainly do the trick.
  • Romo11
    Romo11 Posts: 101
    You guys please keep thinking. Y’all have helped me so much.
  • Geoff4rfc
    Geoff4rfc Posts: 2,968
    kharp1 wrote: »
    Yes he does! My bad for not mentioning that!!
    I will mention that when it comes to DIY RCA cables and speaker cables, I don't look anywhere else then Dougs.
  • Geoff4rfc
    Clipdat wrote: »
    Integra did that with their DTR 70.6 AVR. I don't know if its really lame or cutting cost since it's an AVR and not a Pre. I think it's more like a bonus...but that's just me.
  • mdaudioguy
    edited July 2019
    Clipdat wrote: »
    Without doing a ton of research, it doesn't seem like any of the consumer brand AVRs have a full complement of XLR outputs, even at the top of their lines. Not Denon, Marantz, Onkyo, Integra, Sony... One or two have what his Yamaha does, basically a pair for front left/right.
    The only place I'm routinely seeing a full complement of XLR pre-outs (7-13 channels) is in the more specialized preamplifier processors (pre-pros). Just doesn't seem typical for any AVR brand to have them, so I'm not sure cost-cutting is the appropriate term. RCA outputs are far more common and familiar to most consumers.
  • gp4jesus
    gp4jesus Posts: 2,019
    Romo, did I miss you solving the hum problem?
    Also Outlaw 976 pre/pro has 7.2* XLRs & RCAs. Be grateful you have a full complement of RCAs. Entry level AVRs, the ones that need more power the most, force upgrades.
    * same signal merely allows a second sub
    mdaudioguy wrote: »
    The only place I'm routinely seeing a full complement of XLR pre-outs (7-13 channels) is in the more specialized preamplifier processors (pre-pros). Just doesn't seem typical for any AVR brand to have them, so I'm not sure cost-cutting is the appropriate term. RCA outputs are far more common** and familiar to most consumers.
    Tony
    *all connected w/Premiere ICs
  • Romo11
    Romo11 Posts: 101
    gp4jesus wrote: »
    mdaudioguy wrote: »
    Tony
    Tony,
    You must have missed my post that I was going to try and solve it this weekend. I don’t remember if I thanked you for that great post on the steps to solve but, if not, I do thank you.
    I’ve been babysitting the past few days and it’s impossible for me to do more than one thing at a time.
    Rob
  • Romo11
    Romo11 Posts: 101
    Geoff4rfc wrote: »
    kharp1 wrote: »
    After I determine exactly what is causing it I will proceed to fix it. I it’s in the cables, I’m heading Doug’s way.
  • gp4jesus
    Romo11 wrote: »
    Tony,
    I did.
    Romo11 wrote: »
    my pleasure
    Romo11 wrote: »
    been there, done that more than a few times.
  • Romo11
    Romo11 Posts: 101
    PSOVLSK wrote: »
    Well this evening I went and found the cables that you sold me. I couldn’t wait to hear them then, I laid them along the floor and the one was too short.
    After I bought the amp, I realized that what I was using to hold my AVR, wasn’t strong enough to support my 100 lb. amp, so I had to buy a new rack. My entertainment center is big and heavy and it would not adjust wide enough to contain the rack and the television. I had to put the rack on the side of the entertainment center and the one cable was about 4 feet too short.
    Crapped out again. No worries as at some time I’ll set up a separate music center and those will work for me.
  • FestYboy
    FestYboy Posts: 3,861
    ^ so it sounds like, in the beginning of the post, that there was a difference in cable length. After reading through though, it appears to be an offset in position of the amp that is the issue, yes?
  • Romo11
    Romo11 Posts: 101
    edited July 2019
    FestYboy wrote: »
    Definitely.
    No problem though as hopefully if things work out, I’ll set up a stereo system and they can be used there, sometime in the future.
    Thanks for making it more clear.
  • Romo11
    Romo11 Posts: 101
    Well, my granddaughter plays in softball tournaments and the heat index is over 100 degrees. That’s too hot for this old guy so my seven year old grandson and I left after the first game and we are chilling this afternoon.
    Maybe tomorrow I can play with my “hum” noise. If not, I’ll get to it sometime.
    I would rather have two grandchildren that I can love and spoil as to having a system in every room in my house.
