13334363839203
    audioluvr Posts: 5,989
    Agree with Skip on that .... you want these on your SDA’s.
    Show off...
    nooshinjohn Posts: 26,002
    edited April 2019
    It has been nearly a decade since the project began and every time I look at them, they still bring a huge smile.... and the granite makes them look as spectacular today as they did when they were new.
  • Willow
    Willow Posts: 11,258
    mlistens03 wrote: »
    Rebuilt the stereo the other day. don't laugh... ;)
    Lol, so far I actually really like it. It doesn't look particularly great, but it will be better. It's useful for doing school, etc. I use a little folding table in front of where my chair is at while using the computer. The keyboard and mouse are wireless, but I need a USB Bluetooth adaptor for it to work. But once I get one, I'll stash them away in a drawer or something when they aren't in use.
    KEFs are sounding better than ever, finally got them really tuned in, and found where they sound best in the room.
    Before anyone asks, yes, I have been using the turntable. I realized that since the top is broken, I can put it in a lower shelf. There's probably some kind of acoustic drawback to this, but oh well. ;)
    Thoughts? :)
    I don't see a reason to laugh....not one bit.
    Clipdat Posts: 13,100
    Guaranteed it sounds better than my room/setup.
  • cfrizz
    cfrizz Posts: 13,415
    Good job, it looks great, enjoy.
    Tony M Posts: 11,732
    If that rack was made out of cinder blocks and pine 1X12's, a lot of us would've chuckled for nostalgic sake. Maybe even 2X12s were used for shelving too.
    I'm sure a few of us built cinder block racks back before they even made stereo racks separately.
    F1nut made his out of slate rocks and brontosaurus bones...
  • verb
    verb Posts: 10,176
    I tuned my basement rig on to warm up the Cary! :smile:
    edited April 2019
    Just got my Wireworld Silver Eclipse IC's back from the factory. I bought a 1.5 m pair of XLR's and had them make a pair of 1.0m XLR's and a pair of 0.5m pair of RCA IC's out of them. All installed and testing them out. Noticeable difference between them and the monoprice IC's for sure. Jamming out to Juno Reactor (Thanks Dave...) It's really freaking me out.
  • mlistens03
    mlistens03 Posts: 2,767
    Clipdat wrote: »
    Really? Those PMCs are pretty great speakers, plus you got good stuff behind them.
    Willow wrote: »
    mlistens03 wrote: »
    Thoughts? :)
    I thought he told your table in a lower shelf would be A cause laughter, but I guess not! :)
    Tony M wrote: »
    I had that for a while, but it looked really bad, and I found the Salamander and went for it. :)
    Remember, without y'all I'd be listening to a HTIB right now, so you guys are a big reason for how sweet my stereo is. :)
    Thanks!
  • GlennDog
    GlennDog Posts: 3,158
    audioluvr wrote: »
    What does WW charge for re-termination? . . . and is it extra for XLR? TIA
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    edited April 2019
    They charged me $200 for this. I sent one case and got back 2 and 2 cool bumper stickers!
    Post edited by audioluvr on
  • joecoulson
    joecoulson Posts: 4,943
    That’s a pretty decent deal
  • motorstereo
    motorstereo Posts: 2,369
    I added 3 more of these yesterday for a total of 5 now. With only 2 plugged in the change was barely if it all noticeable. But now with all 5 plugged in there is an unmistakable improvement on all sources.
    Instructions say to place then near the source of noise. I noticed it went berserk when I plugged it in the same outlet as my fridge when it was running. Not sure if that did anything for my sound but it made the kitchen look like a disco at night (until I covered up the light with aluminum foil tape).
  • motorstereo
    Yes on a couple of my lines they will go "beserk" to. But on my 3 dedicated circuits all 3 harvesters blink very slowly. On non dedicated lines near the rig they do blink furiously. Another thing I used them for is to find which one of my 120 legs has more noise than the other. Originally I was using the noisier of the 2 legs for my rig's power so I switched legs to the quieter one which helped a bit more. Every little bit helps.
    Good idea!
  • indyhawg
    indyhawg Posts: 1,674
    Hooked a Pangea AC-14SE up to my PS Audio DAC. Hearing a little more clarity and detail.
  • codycatalist
    codycatalist Posts: 2,661
    Turned the rig on for the first time in 2 weeks. No point in listening when your ears are plugged from a sinus infection.
    pitdogg2 Posts: 27,335
    What?
    Hooked up SVS SoundPath speaker cables.
    Got myself to less that an hour's work to complete the Dreadnaught upgrade for my SDA's... I need to install the terminal plate for the left channel and I will be good to go.
    Couldn't sleep so I just stayed with it and got it done.
    mhardy6647 Posts: 35,242
    I guess it might depend on whether one listens to music or sound.
    I mean, Beethoven was essentially deaf in his old age, but that didn't seem to stop him :p
  • dhart86
    dhart86 Posts: 1,594
    edited April 2019
    Changed the speaker cables from AZ Satori to Audioquest Oaks and added some basic Signal Cable silver resolutions RCA's to the mix. Improved transparency and bass
    Main Rig:
    Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
    Second Rig:
    Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
  • joecoulson
    Did you do them both at the same time @dhart86 ?
    Otherwise how do you know the AQs were better than the Satoris?
  • dhart86
    joecoulson wrote: »
    I had been using the Satori(s) previously but swapped the AQ(s) for assessment. I wasn't impressed w/ the supposed upgrade so I then put in the Silver resolution interconnects. At that point the synergy in the rig peaked. To make sure the improvement wasn't just due to the interconnect swap, I left them in and then tried the combo with the Satori(s). With the Satori(s) installed, the rig sounded better than the original set-up, but not as good as with the AQ's
    Main Rig:
    Second Rig:
  • joecoulson
    Very interesting
    Thank You man
  • HzTweaker
    HzTweaker Posts: 1,041
    Bad joke and late but this image^^^^^ came to mind :p
  • motorstereo
    ^^^^^^I find it highly doubtful that even one person on this forum would have any such mess as that.
