  • joecoulson
    joecoulson Posts: 4,943
    Got my cables. But have to wait to hook them up.
    Got the A1 cause they meaty
  • GlennDog
    GlennDog Posts: 3,085
    I just rolled a new-to-me Transparent Audio Premium 110 ohm cable between my NSD Supremo and PSA PWTransport. . . so far more detail :)
    Source Lumin U1 Mini into Lampi Baltic 4
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • aiconn
    aiconn Posts: 277
    I finally hooked up one of these in my office rig to compliment the Quad 12L Actives. Now I just need to find a reasonably priced preamp to replace the aging Pioneer SC-1222. 2715267_sa.jpg;maxHeight=640;maxWidth=550
    PS Audio Stellar Gain Cell DAC/Preamp
    Denon DVD 2910
    Quad 12L Active Monitors
    Marin Logan Dynamo 700W
  • codycatalist
    codycatalist Posts: 2,662
    Installed a Emo XPA200 that @afterburnt gave me. Too long for my rack so I had to put it on a thick cutting board. Looks nice, built nice... Been warming up for an hour or so, tine to listen.
    nooshinjohn Posts: 25,100
    Congrats Cody...
  • codycatalist
    Congrats Cody...
    Thanks... ;)
  • displayname
    displayname Posts: 1,132
    This was a few days ago, but I picked up a new rack from Marvin and got everything moved over.
    Analog: MoFi MasterTracker > MoFi UltraDeck > Sutherland 20/20
    MastersounD Dueventi > Rosso Fiorentino Certaldo or Arcam rHead > Hifiman HE4XX
    Discogs
  • motorstereo
    motorstereo Posts: 2,052
    This is one of my mc1201's from earlier today. The meter was unevenly lit so today was the day I decided to find out why. Turns out there's 8 original incandescent bulbs behind the 5''x10'' meter and several of them were burnt out. Led replacements ordered and now the waiting starts.
    audioluvr Posts: 5,435
    Jeez, do you use an engine hoist to move that thing around?
  • motorstereo
    ^^^^^hmmm now that's not a bad idea. I'll have to look for a spot to mount a hook. Thankfully I did not have to lift it today but I dread the day that it does have to happen.
  • verb
    verb Posts: 10,176
    Love the Mac gear! Now I have to search for your complete setup pic! Somewhere here in CP. Somewhere. :smile:
  • codycatalist
    Installed a Emo XPA200 that @afterburnt gave me. Too long for my rack so I had to put it on a thick cutting board. Looks nice, built nice... Been warming up for an hour or so, time to listen.
    I do like how the Emo looks however it just doesn't mesh well with my set up. Something is just missing, weight, heft to the sound and presence isn't up to par with the GFA545. I am trying to give myself a couple days with it but might just throw the Adcom back in and see how the Emo likes the ERA D5s.
    People get mad for saying things about Emotiva gear like that, but this has been the finding of quite a few that have tried it. It may fare better with the Era's, but it is my suspicion you will find the same conclusion. The Sunfire 5/200 is similar in terms of lacking weight/heft...
  • ZLTFUL
    ZLTFUL Posts: 5,640
    I have found that to get any real soul from Emotiva, you have to get into the XPR series.
    I went through UPAs and XPAs out the wazoo before finally springing for the XPR-5 and finally got what I wanted from the Emotiva.
  • dolbyd
    dolbyd Posts: 430
    ZLTFUL wrote: »
    The XPR and their current DR amps are where Emotiva shines. I also feel the Regular Gen3 amps are much warmer and a step up compared to the older generations.
    Also for a cheap 2 channel amp that performs. The X-300 is a great little amp.
    Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva X300, Sony 75" 940E, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
    Office- Legend L600, in ceiling Polk RC80i, Marantz 7704, OPPO 203, Pioneer Elite PDF-59 CD, PSA Stellar 300, Sony 55" 800B, Gik room treatment
    Master BR- Signature ES60, Signature S35 Center, Signature S15 Dolby Height, LSI700 in ceiling, SVS-SB4000, Marantz 5012, Emotiva XPA5 G2, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 55" OLED
    Patio- SDI Atrium8 x3, Emotiva A-100 amps x3
  • GlennDog
    edited March 2019
    Today I had a similar experience, but with a less desirable outcome . . .
    Meters on the pre were not illuminating. Owners manual says the festoon bulbs may need to be replaced occasionally. After discovering the local Battery n' Bulb store charges like $16 each, I ordered a few online. Received them today and after a ton of PITA stuff, discovered that both "light boxes" require replacement. Turns out owners manual is older/out-of-date. Newer light boxes have LEDs in 'em now ...
    Anyone need some 12V 1.2W 6x24mm lamps?
    Also, ordered a NOS Mullard 5AR4 for the PS B) to replace the lame Sovtek
    Post edited by GlennDog on
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • codycatalist
    I have heard some bashing on them but I don't feel it's a bad amplifier, just not a good mix with my equipment and sound preferences. I am sure they would sound good with certain speakers. The Era's are bass heavy already so they help fill in the gap from the amplifier. Granted this is a simple HT set up but it helped with the power hungry bookies.
  • motorstereo
    Also, ordered a NOS Mullard 5AR4 for the PS B) to replace the lame Sovtek[/quote]
    Ouch those are expensive!! I had pretty much the same experience. Mine are 8918's. Audio Classic has originals at $9.00 each and an ebay seller had 12 for $40. Needing a total of 28 bulbs this didn't seem the way to go. After lots of searching I was able to find led equivalents for $6 for 10 for the panel bulbs and $20 for 15 of the meter bulbs. I've done the 12 panel bulbs and they came out great. Hopefully the meter bulbs look just as nice.
  • steveinaz
    steveinaz Posts: 19,522
    joecoulson wrote: »
    Very cool.
  • joecoulson
    Thanks Steve
    They are SO much more powerful than the Linns - meaning at lower volumes they kick the bass out much harder. Have not tried ear bleeding levels yet as I wanted all to settle in.
    Not sure if you can tell, but I also installed a fan above the new Marantz to cool it during reference movie levels - stays cool!
  • Mikey081057
    Mikey081057 Posts: 7,127
    Today I sold and shipped my Parasound P5 and replaced it with this PS Audio Stellar Gain Cell Pre/DAC.
    So far so good very well built an a nice display on the vol. control.
    Garage | Polk Monitor 5B's
    Today I received and installed two new DBS units on my AQ Meteor cables...
  • GlennDog
    I just sprung for a matched pair of Sylvania JAN CHS 6SN7WGT 1950's 6SN7s
    ROLL'N Baby!
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • joecoulson
    Acoustic Zens now connected to the new PS A M700’s
    @Mikey081057 these need to be next on your list (the mono’s)
    treitz3 Posts: 18,333
    Any audible improvement over the old ones, Joe?
  • jdjohn
    jdjohn Posts: 3,004
    joecoulson wrote: »
    FWIW, Joe...your meat doesn't need steak sauce. Wait...that sounds weird.
  • joecoulson
    To be fair Tom, with the new amps and these, it’s going to have to be a swap later with the type 4’s going back in to make a accurate assessment
    Which I will do in a couple weeks.
  • halo
    halo Posts: 5,616
    edited March 2019
    joecoulson wrote: »
    Joe,
    I did the same thing after I bought the Type 4's to pit them against the Signal Cable Ultra speaker cables. The difference wasn't immediate but, when I swapped back the SC Ultra cables back in, the Type 4's sounded better to my ears, with/on my gear, in my listening environment.
