Showcase your setups
@halo I thought you sold the McCormack.
He did. Only I haven’t paid him full yet so in essence it is kind of both of ours at the moment2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
stangman67 wrote: »He did. Only I haven’t paid him full yet so in essence it is kind of both of ours at the moment
Oh yeah that's right! I remember now. Congrats on the pick up, what a nice piece! -
New Bluesound Node 2i in place. Sorry for the grainy pic, apparently Ipad 4 doesn't have a flash....below it is my WD Hard drive.
Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
How’s the node Steve?Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
Latest of the mini man cave rig with the Lumin U1 mini and the P5 back in the rack.
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Beautiful speakers and stands.
Beautiful set up Mikey.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Update with the AQ Niagara setup and the side rack removed
joecoulson wrote: »Update with the AQ Niagara setup and the side rack removed
Nice aquarium.The Gear... Carver "Statement" Mono-blocks, Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 380d DSDIn retirement...TriangleArt Reference SE with Walker Precision Motor Drive, Yamaha CD-S2100 SACD Player.“Every record has been destroyed or falsified, every book has been rewritten, every picture has been repainted, every statue and street building has been renamed, every date has been altered…History has stopped. Nothing exists except the endless present in which the party is always right” — George Orwell“If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.” -
Lol. Thank You John.
Not sure if this was an upgrade or not. I really liked my Emotiva Airmotiv 5 powered monitors but they sound quite different from how these are. None of the air and strong imaging that I was expecting based on those and the Stealth 8's I'd heard before. I'm thinking I should have just upgraded the crossovers in the 11TL's instead.
Before:
After:
Ok. I’m tired of the Niagara sitting out. Time for what looks like a simple move, but it’s not.
Moving everything around inside the cabinet to fit all gear. The Auralic will go on top as it’s beautiful and needs to be showcased.
Before pics, after to come later.
Step 2
/\/\/\ That looks much betterDenon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh" -
Looks like "50 shades of Coulson".Most people just listen to music and watch movies. I EXPERIENCE them.
Cable management is going to be your nightmare.The Gear... Carver "Statement" Mono-blocks, Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 380d DSDIn retirement...TriangleArt Reference SE with Walker Precision Motor Drive, Yamaha CD-S2100 SACD Player.“Every record has been destroyed or falsified, every book has been rewritten, every picture has been repainted, every statue and street building has been renamed, every date has been altered…History has stopped. Nothing exists except the endless present in which the party is always right” — George Orwell“If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.”
joecoulson wrote: »Step 2
Get yourself some grating, nylon bushings (available in various diameters and lengths) and use zip ties to secure. You can even trim cables to exact length if desired.
You can also use thin wall plastic pipe (not schedule 40), slit it if you have to, use 45 and 90 degree fittings (you can slit them and re-glue together) and cover with techflex.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Knee deep now.
Very neat and tidy Rich!!
Nearing the end
Seeing these pictures reminds me why I built an in wall rack with closed doors... Wiring everything is a breeze because it's all back to back- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Last steps
Looking good- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Fin!
Time for a rootbeer and music2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Dayum right!!
And oh man do they sound so much better closer together.
Audio nirvana right now.
Edit : not proofreadingPost edited by joecoulson on -
Nice rigs guys! Here mine late 90’s John Curl Designed Parasound rig, HCA2200II pairs great with the PLD2000, MIT cable loom and Polk Audio LS70... sounds pretty sweet!!
