Showcase your setups
1121315171824
  • steveinaz
    steveinaz Posts: 19,545
    Joey_V wrote: »
    How’s the node Steve?
    I like it a lot.
  • maxward
    maxward Posts: 1,710
    Beautiful speakers and stands.
  • cfrizz
    cfrizz Posts: 13,415
    Beautiful set up Mikey.
    nooshinjohn Posts: 25,955
    joecoulson wrote: »
    Update with the AQ Niagara setup and the side rack removed
    Nice aquarium.
  • joecoulson
    joecoulson Posts: 4,943
    Lol. Thank You John.
  • joecoulson
    Ok. I’m tired of the Niagara sitting out. Time for what looks like a simple move, but it’s not.
    Moving everything around inside the cabinet to fit all gear. The Auralic will go on top as it’s beautiful and needs to be showcased.
    Before pics, after to come later.
  • Manticore
    Manticore Posts: 408
    /\/\/\ That looks much better ;);)
    Denon AVR X4200W
    Parasound A23 amplifier
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Denon DP 3000 turntable
    Saec 308sx tonearm w/
    Dynavector 10x5 cart
    Vincent PHO 701 Phono Preamp
    MIT Avt3 Speaker c's
    Audio Quest Big Sur ic's
    Polk SDA 1C's modded
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Polk DSW PRO 440wi sub
    Infinity bu2 sub
    "The early Klingon gets the Gagh"
    Tony M Posts: 11,673
    edited June 2019
    Looks like "50 shades of Coulson". :D
    edited June 2019
    Cable management is going to be your nightmare.
    SCompRacer Posts: 9,121
    edited June 2019
    joecoulson wrote: »
    Step 2
    Get yourself some grating, nylon bushings (available in various diameters and lengths) and use zip ties to secure. You can even trim cables to exact length if desired.
    You can also use thin wall plastic pipe (not schedule 40), slit it if you have to, use 45 and 90 degree fittings (you can slit them and re-glue together) and cover with techflex.
  • joecoulson
    Knee deep now.
  • joecoulson
    Very neat and tidy Rich!!
  • joecoulson
    Nearing the end
    VR3 Posts: 29,496
    Seeing these pictures reminds me why I built an in wall rack with closed doors... Wiring everything is a breeze because it's all back to back
    VR3 Posts: 29,496
    Looking good
    txcoastal1 Posts: 13,514
    Time for a rootbeer and music
  • joecoulson
  • joecoulson
    edited June 2019
    And oh man do they sound so much better closer together.
    Audio nirvana right now.
    Edit : not proofreading
    Post edited by joecoulson on
  • cortico
    cortico Posts: 587
    edited June 2019
    Nice rigs guys! Here mine late 90’s John Curl Designed Parasound rig, HCA2200II pairs great with the PLD2000, MIT cable loom and Polk Audio LS70... sounds pretty sweet!!
  • verb
    verb Posts: 10,176
    VR3 wrote: »
    Did you ever post any pics?
  • cfrizz
    edited June 2019
    stevep wrote: »
    Not sure if this was an upgrade or not. I really liked my Emotiva Airmotiv 5 powered monitors but they sound quite different from how these are. None of the air and strong imaging that I was expecting based on those and the Stealth 8's I'd heard before. I'm thinking I should have just upgraded the crossovers in the 11TL's instead.
    Before:
    After:
    Wow that is one big center channel. Very nice set up, give your ears time to get used to the new sound! And put the grills on, it will look much nicer, and take another pic with them on.
  • cfrizz
    joecoulson wrote: »
    Fin!
    This looks outstanding, Congrats on all the hard work and enjoy!
  • joecoulson
    Thank You Cathy!
    I am still enjoying since I got done.
    VR3 Posts: 29,496
    verb wrote: »
    VR3 wrote: »
    I don't believe I've ever posted a pic with the doors off, next time I take them off I'll snap a pic
