Impressions of Tidal
135678
  • steveinaz
    steveinaz Posts: 19,545
    Joey_V wrote: »
    Maybe the bluesound is the limiter
    But in my room, the emm transport beats out the bluesound through tidal both going into emm dac.
    Enough of a difference that through an iPhone video it can be discerned which is which
    Just to be clear, I'm comparing HDD music to a CD player. I find tidal to be a bit soft around the edges (subtle, but noticeable), and I'd pick a CDP over Tidal, but not over flacs delivered via a hard drive.
  • Joey_V
    Joey_V Posts: 8,600
    steveinaz wrote: »
    Joey_V wrote: »
    Definitely I can tell it is soft around the edges. Which is not to say it's a bad sound.
  • joecoulson
    joecoulson Posts: 4,943
    edited February 2019
    That^ is exactly what I heard when auditioning the BS vs the CXN. We A/B tested directly with the node 2 and the Cambridge and the latter was more full and dynamic. I was lucky to have a dealer that carried both.
  • Mikey081057
    Mikey081057 Posts: 7,127
    Important to note that BS is now on their 3rd version (2i) of the Node.
    Now I am prolly going to upgrade from the Node 2 possibly to the Lumin u1 mini.
    But here is some feedback from other users as well.
    https://www.canuckaudiomart.com/forum/viewtopic.php?t=48820
    Garage | Polk Monitor 5B's
  • Mikey081057
    mhardy6647 Posts: 34,910
    There' s never going to be an appropriate time to add this, so I'm just going to do it now.
    Every time I see the title of this thread, I think of Visions of Johanna.
    B)
    https://youtu.be/nuTpTzYiR1w
  • Joey_V
    Joey_V Posts: 8,600
    I guess what I'm trying to say is that for my use, I'm too cheap to buy an aurender so the used bluesound node 2 that i got for $200 off audioaficionado is good enough.
    I'm sure there is better.
    One of the members in our DFW Audiophile club has the Aurender w20, that's $17,000 for a streamer.... so I know it gets good.
    I'm just at a point where the system is so good and enjoyable, I don't stress about the final %-ages of improvement.
    Clipdat Posts: 13,078
    sotm-tx-usbexp-large_1024x1024.jpg?v=1527284813
    @msg this up your alley
    msg Posts: 10,450
    Dayng! Nice.
    I think Rich @SCompRacer may be using this or an earlier version.
    When I set up my first USB DAC for continuous use with the home office PC, I had all kinds of clearly audible noise and other weird USB device interaction, like weird mouse and keyboard behavior with audio playing. You don't have to listen or look hard for it either. It was obvious.
    I noticed an immediate and huge improvement simply going with a dedicated USB 2.0 card to isolate the DAC from the rest of the USB devices. It really does work. I can only imagine what the SOtM tX-USBexp is like. Beautiful little piece of tech there.
    Which Power Supply are you using with it @fastz28 ?
    I'd love to build something completely dedicated with a card like this in it.
    Incidentally, this little near field system I built in the home office with the computer connected DAC was the first time I began to experience more profoundly some audio refinements, like imaging and player location.
  • Willow
    Willow Posts: 11,215
    Do they have a family version like Spotify? I'll take a look.
  • Joey_V
    Joey_V Posts: 8,600
    DSkip wrote: »
    You don't have to spend $17,000 to move up. I was actually turned off by Aurender because they use hard drive disks in their streamers. I know its not 'in the music chain' but it still bothered me enough to look elsewhere. I haven't had a chance to get my ears on them yet.
    Understood.
    But what I’m saying is if all I’m doing is streaming tidal rather than burned flac files of my music, then there’s a lot more limiting factors than the bluesound running coax into the emm labs dac2x.
    If I were streaming my entire flac collection, then that’s a different story.
    msg Posts: 10,450
    Oh, power from the same guys, nice. That makes sense.
  • WLDock
    WLDock Posts: 3,073
    Joey_V wrote: »
    Clipdat wrote: »
    Joey_V wrote: »
    I am using a bluesound node 2.
    In my opinion you owe it to yourself and the rest of your system to upgrade to a better streamer. The measurements on the Bluesound are mediocre:
    "Bluesound specs the unit at 0.005% and measurements are actually better in both channels. Resulting SINAD though (signal over noise and distortion) is not great at just 88 dB. This is well short of the dynamic range of the CD so the statement that the unit supports high-resolution, 24-bit playback is moot. The SINAD lands in out lowest quarter as far as DACs/streamers tested"
    https://www.audiosciencereview.com/forum/index.php?threads/review-and-measurements-of-bluesound-node-2i-streamer.6631/
    For the price I think it is adequate
    Not my reference playback for digital anyway
    What would you recommend for similar cost?
    The same fellow tested the MiniDSP SHD DAC audio processor / streamer. Its seemed to measure pretty well. $899 - $1199 price range. Its an interesting looking unit for sure with the added Dirac room correction.
    https://www.audiosciencereview.com/forum/index.php?threads/review-and-measurements-of-minidsp-shd-dac-dsp-and-streamer.4286/
    https://www.minidsp.com/products/streaming-hd-series/shd-series#network-audio
    minidsp-shd-audio-processor-streamer-png.15063
  • Joey_V
    Joey_V Posts: 8,600
    WLDock wrote: »
    Joey_V wrote: »
    Clipdat wrote: »
    Joey_V wrote: »
    That streams Tidal?
  • K_M wrote: »
    Ive tried Spotify and Tidal and thought they both sounded better than the actual CD....at times.
    ....Other times, not sure, and also at times, maybe a very slight softening of the sound, but never did a truly in depth comparison.
    I guess overall, easily good enough to not leave any bad impressions.
    I've used and am using both currently, Spotify for about 3 years or so. It took me a while to try out Tidal and even more important have something that can show me the difference. To me at least there is a discernable difference in Tidal's favor BUT it could have just been what my system needed in terms of Soundstage expansion. That and the slight softening you mentioned were the most noticeable changes. I had same feelings with CDs, I chaulk it up to the version of the CD was a bad digital file or an already compressed file uncompressed in a bad way.
    Could I live with Spotify... Yeah but man I like the other side. :D
  • Willow wrote: »
    Yep Tidal has family accounts.
    audioluvr Posts: 5,865
    Has anyone A/B'd the difference between Tidals HiFi and Premium service? Just wondering if it's worth the extra ten bucks a month.
  • Joey_V
    Joey_V Posts: 8,600
    I’ll try it when my new preamp comes
    audioluvr wrote: »
  • audioluvr wrote: »
    In my experience it isn’t THAT far off. Not as resolving but still good sounding, better than Spotify. I say this but have the Hifi option, I’ve been skating by on promotions after I cancelled. 3 months for $2!
    OOO! Sweet deal there! Not a bad idea.
    Joey_V wrote: »
    Thanks Joey. Can you do this on a crappy (to you) pre? Your stuff is WAY nicer than mine.
  • steveinaz
    Well, $20 won't buy you 2 CD's a month, so....
  • rooftop59
    rooftop59 Posts: 8,121
    steveinaz wrote: »
    It will of you buy used or look for the amazon deals $10 or less, of which there are a ton. But even if you find three a month for $20, if will take you decades to build a library anywhere near the size of tidal...
    Game Room 5.1.4:
    Bedroom 2.1
  • WLDock
    WLDock Posts: 3,073
    Joey_V wrote: »
    That streams Tidal?
    Yeah man, Its on topic and on point! Don't listen to me, check out the pages I linked. I'm have a paid Spotify subscription but I'm about to try Tidal myself.
    https://www.minidsp.com/aboutus/newsletter/listid-1/mailid-69-minidsp-q4-2018-newsletter
    miniDSP wrote:
    SHD SERIES UPDATE
    We are very happy to report that the popular Qobuz and Tidal music streaming have been added to the SHD Series. These additions further solidify this series as a great fit for any modern audio system.
    Existing customers can easily upgrade with the Over The Air (OTA) upgrade process from the Volumio web GUI. Go to the system settings page and click on "Check Updates". Done!
    Both SHD and SHD Studio products are in stock. A great Christmas gift to fit under the tree! :-)
    SHD Series Manual: https://www.minidsp.com/images/documents/SHD Series User Manual.pdf
    ________________________________________________
    I JUST DISCOVERED THIS, CHECK THIS OUT!
    VOLUMIO is the interface, platform that its build off of. As I understand it, they are a software company that offers computer add ons, etc. Now, they just released their first complete streaming unit, the Primo model from overseas is just $409.99 at their USA store!!!
    https://volumio.org/
    https://www.volumiousa.com/volumio-primo/
    https://volumio.org/volumio-primo-first-product-on-sale/
    https://www.audioasylum.com/cgi/vt.mpl?f=pcaudio&m=174320
    https://darko.audio/2018/11/volumio-goes-primo/
    https://www.facebook.com/volumio/
    https://youtu.be/5jn1SWfK1VI
    Post edited by WLDock on
  • Mikey081057
    I have a new streamer on the way.... B)B)B)
  • steveinaz
    That Volumio Primo looks very cool.
  • Mikey081057
    Lumin U1 Mini to pair with my Mytek Brooklyn DAC+
  • WLDock
    WLDock Posts: 3,073
    Also, there are several other cool productson the Volumio USA website for putting together a high performing budget music player, DAC, Digital amp w/bluetooth, etc
    https://www.volumiousa.com/products/?limit=100
    WHAT IS VOLUMIO
    Volumio is a Free and Open Source Linux Distribution, designed and fine-tuned exclusively for music playback.
    It runs on a variety of devices, typically small and cheap computers like Raspberry PI, but also on low power PCs, Notebooks or Multimedia PCs.
    By flashing (installing) Volumio on any of this platforms, it will then become a headless Audiophile Music Player. Headless means that the only way to control it will be with another device, such as a Smartphone, Tablet, PC or anything that has a browser.
    This is made possible by Volumio’s UI: a web applications that runs on any device with a browser, and that allows an easy and intuitive control of your playback sessions. All communications between the Web App and Volumio will happen through your home network.
    •Runs on Raspberry PI, UDOO, Cubox-i, Odroid, PC, Mac and a variety of other small
    devices
    •Minimal operating system, tailored for Bit-Perfect Audio Playback
    •The system is loaded entirely on RAM and optimized for lightweight operations
    •Various Audio related tweaking for best audio performances
    •Works with any USB 2.0 DAC
    •Raspberry PI and Odroid I2S DACs supported natively
    •Supports all filetypes: FLAC, Alac, Aac, Vorbis, Mp3, DSD etc
    • Playback
    •Airplay Playback
    • Over PCM support, for non Direct-DSD compatible hardware
    •Integrated WebRadio directories
    •If a compatible wireless hardware is found, Volumio will create a hotspot network for
    first configuration
    •Mount CIFS and NFS Network Attached Storage, with an auto-discovery function
    •Custom playlist editing and creation
    •Plugin support with new functions available like Spotify and Digital Room Correction
    •Seamless update system: no need to reinstall when a new version is available
    • with a growing number of translations available
    •Image background support, even your favourite one
    •Alarm and sleep function
    HOW DOES IT WORK
    Once you’ve installed (or flashed) Volumio to your device, and connected it to your network and Audio equipment you will be ready to play. Volumio will discover automatically the music on a USB drive, or allow you to connect your network storage and your streaming services account.
    From now on you will control your playback from anything that has a browser: a tablet, a mobile phone, a computer or even your Smart TV.
    Volumio can adapt itself to a variety of configurations.
  • gyosa
    gyosa Posts: 769
    Yes ..
    Bk
    audioluvr wrote: »
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
    gyosa wrote: »
    Yes ..
    Bk
    audioluvr wrote: »
    Sweet! Thanks!
