Master Bath Remodel
    xschop Posts: 5,732
    Good job. Probably took longer organizing and storing all the beauty supplies than the gut-out.
  • steveinaz
    steveinaz Posts: 19,546
    AWESOME. You're a BRAVE soul.
  • joecoulson
    joecoulson Posts: 4,968
    Either that or dumb as a box of rocks. We’ll see when it’s done. Thanks Steve.
  • joecoulson
    Tile floor almost done (commode area).
    Shower floor poured. Durock fitted.
    Tomorrow shower gets tile and floor grouted
    Clipdat Posts: 13,101
    Hey that tub looks like it won't take a half hour to fill! Nice.
  • joecoulson
    no doubt. Same width. Just not as long.
    xschop Posts: 5,732
    Looking good. When my home was being built. They used some kind of black-tar or butyl brush on layer over the Durock. No leaks after 5 years.
  • Milito
    Milito Posts: 2,003
    edited February 2019
    Joe, just a word of advice on the framing of your tub. If you used nails, I would also use some wood screws as they don't work loose near as easily. The framing for my tub in my new bathroom used nails and I wish I had gone after the contractor and added screws as I can tell some of the nails have loosen some as I sometimes hear noise when my wife or I get out of the tub. The vibration of the pump could also cause this on the framing.
  • joecoulson
    Thank you and yes we used screws after the framing nails.
  • scubalab
    scubalab Posts: 3,105
    Awesome progress. Looks fantastic so far Joe!
  • joecoulson
    Thanks Al!
  • DaveHo
    DaveHo Posts: 3,584
    Nice work!
    Our house has the original late 80's bathrooms & kitchen. It's needed remodeling for years now. I keep trying to convince my wife to just move & make it someone else's problem! Besides, I need a better listening room!
  • joecoulson
    Here is today’s progress. Grout done on flooring. Looks awesome !!
    Shower 90% done. Still needs a few more tiles and then final grout tomorrow.
    Tomorrow will be done with tile and then onto Sheetrock finishing.
    Vanity installation Saturday.
    mhardy6647 Posts: 35,501
    big thumbs-up!
  • steveinaz
    Beautiful!
  • Willow
    Willow Posts: 11,335
    @Milito how hard is it to keep that shower glass clean? I love the look of those, just afraid that it will show soap stains all the time.
    Just apply some rainX every so often
  • Milito
    Milito Posts: 2,003
    Thanks, but I tried RainX as I have used it on my cars at times. It didn't last very long at all, even after applying several coats on our shower glass.
    Looks great Joe!
  • mrbiron
    mrbiron Posts: 5,721
    You have crown molding in your bathroom?! Very fancy...
    I like the floor tile, where did you buy it so i can steal the idea ;)
  • cfrizz
    cfrizz Posts: 13,415
    Wow very nice, I love the floor.
  • joecoulson
    mrbiron wrote: »
    Floor and Decor was cheap too
    Thanks all
  • steveinaz
    You did a really clean demo.
  • BlueFox
    BlueFox Posts: 15,250
    Looks very nice. Just curious, why not put the shower head on the back wall?
  • joecoulson
    It would spray against the door not ideal. Plus the niches are a focal point and would not be on that wall.
  • joecoulson
    Sheet rock done today. Tile done.
    Frameless shower door guys wouldn’t Template because I didn’t have the step and cap on knee wall. Oh well. Probably 2 weeks from competition now because of that.
    Cabinets go in tomorrow and we’ll probably paint this weekend and then final electrical trim out.
    More pics to come.
  • steveinaz
    You'll LOVE the frameless shower. We did one 2 houses ago, it was gorgeous and not crazy expensive ($1200 IIRC) even with the thicker glass. Yes, they do want all construction finalized because the dimensions are TIGHT.
  • steveinaz
    Master updates done. Mirrors, faucets, medicine cabinets, lights, towel bars, etc:
    Still waiting for mirror (same type) and light fixture for the guest bath.
  • polrbehr
    polrbehr Posts: 2,866
    That's some beautiful work there guys, you certainly set the bar high for me (see my ugh mold thread). We sure will have our work cut out for us, though our space is not even close to what you have.
  • steveinaz
    Thank you, ours was pretty minimal---just cosmetic upgrades.
  • joecoulson
    Today’s pics. Too tired to explain. So much done.
  • joecoulson
    So yesterday was:
    Paint trim, crown, doors in white
    Paint walls in that grey
    Install new hinges and plates on doors.
    Install vanities and hardware
    Install sconces
    I’m sore
