VTL 2.5 PreAmp in the House!
1356
  • gmcman
    gmcman Posts: 1,851
    I just let the tubes cool off for a few min. I used a piece of paper towel to remove the tubes, tried to avoid oil from fingers to get on glass.
    I dont know if that's detrimental, but basing on headlight bulbs I was going on the same principal.
    Also as a precaution...just be super careful not to poke the pin sockets with anything metallic. Unplugged, even for days, the caps will hold sufficient juice to light you up..or even worse. The energy stored can be lethal.
    If you ever feel you need to check tension or clean the sockets, make sure you know what you're doing and use a non-metallic pick or similar.
    Clipdat Posts: 13,098
    gmcman wrote: »
    I don't think that oils from your skin have any detrimental effect, but if you're looking to avoid it, standard nitrile gloves certainly work:
  • GlennDog
    GlennDog Posts: 3,152
    Hey Dave,
    Local guy, er well . . . he's in Michigan. If you're in need of quality tubes, check out Andy at Vintage Tube Services
    (616) 454-3467
    vintageTubeServices.com
    no afil, but I've had great experience with him
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • gmcman
    gmcman Posts: 1,851
    edited October 2018
    Have you tried the bugle boys yet? I don't know what color the pins are supposed to be on those but it looks like they could possibly use a good cleaning.
    heiney9 Posts: 25,465
    Short plate w/large halo are just about as good as the long plates. Make sure and clean the PINS on all your tubes. DeOxit and a swab stick and little elbow grease does wonders.
  • verb
    verb Posts: 10,176
    Hi Doug - Have not yet. But thanks for the advice! Will do!
  • verb
    verb Posts: 10,176
    heiney9 wrote: »
    Will do! Thanks!
  • verb
    verb Posts: 10,176
    heiney9 wrote: »
    DeOxit newbie here. What formula should I use? There’s a bunch it seems.
    Why not try ~99% isopropyl alcohol first, and see how that goes?
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    Good idea, but I drank it all up! :smile:
    edited October 2018
    I fill my car with E85 these days, as I'm running a FlexFuel kit and custom tune. It's kindof funny to think that my car is running on an 80/20 mix of alcohol/gasoline.
    I quit drinking the stuff, and now run my car on it instead! :)
  • verb
    verb Posts: 10,176
    Sorry my brother! I know you did. Bad joke! I for sure will give it a try!
  • verb
    verb Posts: 10,176
    Shout out to Brock @heiney9 for another set of 12AU7's !
    Here's his quite compelling sales pitch:
    I do have a rare, killer pair of early 50's Westinghouse, long black plates that are superb!! One of my favorites. Only made for a couple years by Westinghouse, hard to come by real deal tubes. Most are relabled Sylvania's or RCA's, as Westinghouse stopped manufacturing their own tubes around 1954-55.
    Some reading about them
    http://www.tubemaze.info/westinghouse-12au7-carbon-plates/
    How can I resist! Brock my man you are an enabler! I give em a roll once the new tweeters on the SRS's break in, as they only have a couple of hours on em.
    Thanks brother! :blush:
    pitdogg2 Posts: 27,110
    edited October 2018
    Regular De-oxit is what you want to clean pins with. I also use green 3m scrubbing pads first.
    Red De-oxit has more cleaning power than gold. De-oxit gold i only use on gold and silver AFTER i clean with red first. Best to use a small lid that you can pour some in and stand tube pins in it for a while then a stuff nylon bristle brush.
    That is what i do
    The other thing i found works good is those gold and silver jewelry cleaning pads ymmv
  • verb
    verb Posts: 10,176
    Thanks Dogg!
    tonyb Posts: 33,071
    Ha....hooked another one gents, our work here is done. :p
    Happy to feed a new addiction...lmao!
    I do clean the PINs on all my tubes with DeOxit red and a cotton swab. Good stuff to have around.
    Enjoy and welcome to the warm, glowing side!
  • dromunds
    dromunds Posts: 10,133
    Staring into the tube glow will directly and immediately transport you to the other side.
    DSkip wrote: »
    Some tubes do more than just glow - they light up a room.
    especially when they go all red dwarf on you :p
  • verb
    verb Posts: 10,176
    DSkip wrote: »
    I just had flashbacks of my monoprice incident! Thanks Dogg! :smile:
  • verb
    verb Posts: 10,176
    Found this DeOxit starter kit on eBay:
    Plus a carry case included!
    edited October 2018
    Thank me later...
    https://www.ebay.com/itm/CAIG-D100L-25C-Contact-Cleaner-100-Solution-25ml/322662430146?epid=2254580732&hash=item4b202df5c2:g:U-YAAOSwXk9bkK41
    Keep a search going and you can get the gold 100% solution for about $40.00
    That will get you started with the starter kit.
  • verb
    verb Posts: 10,176
    Thank me later...
    Why wait? Thanks Dogg! :smile:
    edited October 2018
    No problem ;)
    You're welcome
    I started out with the little nail polish bottles and then moved up to the bigger bottles. I just refill the little nail polish bottles. The stuff is not cheap. Over at fmtunerinfo.com one guy came up with a work around. The basic ingredients are as he put it oleic acid aka olive oil. So somehow he got oleic acid and mixed transmission fluid said it worked very well and super cheap.
    Disclaimer i never tried to duplicate it but others on the forum did and said it worked very well. So ymmv.
    I just buy caig i found a quart can for 90.00 but shoot that would last me past my lifetime lol
    audioluvr Posts: 5,949
    Ok you've had just about enough time to fiddle with your new toy... We are all (no longer patiently) waiting for the review... Not that I am going to jump into the tube pre rabbit hole any time soon but maybe we just all enjoy watching the clawing around for a possible escape route.
    tonyb Posts: 33,071
    audioluvr wrote: »
    Ok you've had just about enough time to fiddle with your new toy... .
    Eh, maybe not. He's still looking for his left nut under the couch. Scratching his head about why he didn't do this sooner.
  • verb
    verb Posts: 10,176
    tonyb wrote: »
    audioluvr wrote: »
    Can’t find my right nut either! :smile:
  • lightman1
    lightman1 Posts: 10,797
    verb wrote: »
    tonyb wrote: »
    audioluvr wrote: »
    Been married for a while, I take it?
    tonyb Posts: 33,071
    verb wrote: »
    tonyb wrote: »
    audioluvr wrote: »
    Pffft….what's an Almond Joy without the nut eh ? Throw up a review, maybe a comparison to something else your familiar with. The dogs are getting restless.
