The DEMON is coming...
11415171920
    nooshinjohn Posts: 25,883
    They are 25mb....
    Have one on the way.... Inside the driver's door opening, you can tell where someone at the factory went nuts with a buffer because the entire inside of the jamb is caked with compound residue. The scratches on the hood are very subtle, and the scratches on the door are just deep enough to need a respray. The underbody shows no rust, at least as I would describe it, but there is the type of oxidation you expect to see when aluminum is exposed to the elements. This can even be found on some components under the hood, such as the intake.
    Perhaps I am expecting far too much from the car, but I did drive it around the block, and all I can say is HOLY F...................................................................
    This thing is FAST, and DANGEROUS if you do not respect what this wild animal can do, and will do if you don't know what you are doing. You can have a grin like the Joker, or a couple shillings placed on your eyelids to give St. Peter when you meet him.
    nbrowser wrote: »
    They are 25mb....
    Try one...add hotmail.com to my username here...
    Sent... thanks.
  • Nightfall
    Nightfall Posts: 10,084
    This thing is FAST
    Ridiculous fast. Almost 900hp? Forget about it. Have fun, be careful.
    afterburnt wrote: »
    Village Idiot of Club Polk
    audioluvr Posts: 5,879
    edited April 2018
    The difference is the generations. Today we have baby boomers reliving their youth from the muscle car era. Millennials don't care about those things, heck a good percentage don't even drive, so to think there will be the demand for muscle cars 20 years from now doesn't make sense.
    ^^^ what he said! Now a vintage Prius on the other hand...
  • mikeyb128
    mikeyb128 Posts: 2,885
    Nice choice on the color. She looks niiice!
    2 channel:
    Theater:
  • Nightfall
    edited April 2018
    How much do those tires run? I'd be scared to find out. I just took off my snow tires and put summer tires on, my set of summer tires were done. $58 a tire brand new, most expensive ones they had. :D
    That car is sex on wheels.
    afterburnt wrote: »
  • BlueFox
    BlueFox Posts: 15,251
    mikeyb128 wrote: »
    Yes, it is a nice looking car. Does it have just the driver's seat, or did you get the entire seat?
    Clipdat Posts: 13,087
    Does it still have the helper springs installed for shipping or something? What's up with that ridiculous rear wheel gap?
  • Nightfall
    Clipdat wrote: »
    Extra room for when you stomp on it and the rear end squats down?
    afterburnt wrote: »
    nbrowser wrote: »
    Nightfall wrote: »
    Clipdat wrote: »
    Good theory, Google up classic Gasser Dragsters, they sit rather high on the axles. I'd surmise this to gain the most weight shift to the rear axle to provide as much traction as possible at launch.
    That is exactly right. This car transfers weight to the rear like no other factory car ever has. The car seems very compliant and easy to drive if you use featherweight pedal application, but if you think you can just drive it like a regular car and push the gas pedal like you would in a regular car, it will get away from you faster than you can blink.
    F1nut Posts: 51,685
    That is one bada$$ looking machine!!!
    BlueFox wrote: »
    mikeyb128 wrote: »
    The car is fully optioned, including the sunroof. The only item I did not check off was the blackout on the roof and trunk.
  • codycatalist
    codycatalist Posts: 2,662
    VERY nice!
  • Jaybeez
    Jaybeez Posts: 748
    Holy Mackeral. You may have some local celebrities knocking on your door asking for a ride! What a beautiful car.
    2 Channel "Polk" Room:
    Marantz PM8004 Integrated
    Marantz SA8004 SACD Player
    WiiM Mini
    Polk 7B with RDO198s
    Are you going to accept it even with all the cosmetic dealer installed flaws that you mentioned earlier?
    Not sure yet what direction it will take. The wife and I are going tommorow to see it in direct sunlight. The hood cannot be corrected without being painted. I also learned my car was one of the units that had rear main seal issues, which explains the nearly three month delay from build date to ship date.
    pitdogg2 Posts: 26,944
    Very nice John. They should bend over backwards to make you 1000% satisfied. Can't blame you one bit for being upset.
  • vmaxer
    vmaxer Posts: 5,120
    Agreed, I wish I could own it.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • stangman67
    stangman67 Posts: 2,329
    edited April 2018
    If they have to respray it in any fashion, I’d run away fast. Color matches are never perfect. Awesome looking car though
    mhardy6647 Posts: 34,925
    edited April 2018
    I'll say.
    Absolutely.
    What does this imbroglio say about FCA? To my way of thinking, it's nigh-on unbelievable they could eff up something like this. I mean, do they do better or worse when you buy a 500?
  • DaveHo
    DaveHo Posts: 3,582
    IMHO, any kind of paint work will ruin its value. If your goal is to keep it low mileage & pristine to resell some time down the road, bail.
    DaveHo wrote: »
    Not that my opinions matter one whit in this context, but I think that's an excellent point.
    As I recall, a key part of the strategy was to buy the vehicle as an investment (not that I can find direct reference to that in the early posts in this thread from the OP). The investment potential of this particular vehicle may well be compromised, perhaps significantly, given the vagaries of the rarefied, high-end collectors' market.
    heiney9 Posts: 25,406
    edited April 2018
    FCA is abysmal. I love the new Alfa's, but since FCA is involved, I'll never take a chance unless the track record magically gets a whole lot better over a long period of time.
  • NotaSuv
    NotaSuv Posts: 3,871
    edited April 2018
    Have owned Dodge since the 80's and never a problem and never left stranded....a combo of Rams, Dakotas, Wranglers and now a challenger which is a 707 hp daily driver that delivers lots of smiles with every mile, now the fit and finish on the wife's Ford is a whole nuther story..............
    ZLTFUL wrote: »
    heiney9 wrote: »
    I love my JGC...I hate dealing with FCA on ANYTHING.
    Example, earlier this week I took my Jeep in for an oil change. When I got home, I went to change the brakes on it and noticed the access panel in the skid plate for the oil plug was missing.
    So I shot a text to my buddy at the dealer (he's the parts manager).
    He said he found it in the trash next to the oil tech's station. When I asked WTF?, he sent me the following screenshot:
    So apparently, even though mine had one, it is not wanted/needed/blah blah blah.
    FCA...lol
    Well -- On the bright side, they were able to explain why it wasn't there! :|
    Reminds me of this:
    http://www.airliners.net/forum/viewtopic.php?t=160531
    edited April 2018
    All brands are going to have their issues. Lead times and product developments and gov't regs means a much shorter life cycle and many times the early production models are the guinea pigs...............
    But from what I've seen reported FCA is the terrible overall. Ever since FIAT and Marccione took over they have been much worse than before.
    Full transparency, I've never owned a Chrysler product. Just going on what I read and what friends. family, co-workers and acquaintances and workers at the plant have experienced.
    I don't want to turn this into an automobile war thread, it was simply an observation. For what the Demon is and what it costs, this type of thing is inexcusable.
    FWIW
    Drove next to a Jeep SRT...
    Saweeeeeet it had some serious low rumble and sounded like it had some fun ponies up front.
    Nice i liked. It was very close to the color if John's car.
    Toolfan66 Posts: 17,991
