Equipment Racks
    Clipdat Posts: 12,633
    I want to know how stoned this guy was when he reviewed this rack and wrote this:
    "Components placed on it will sound more upbeat and lively, which will be right up the alley of Naim-oriented people. By this I mean that if timing and a rhythmic quality is valued above everything else, this rack might be an excellent choice. However, it tends to harden and flatten the sound in a way that does not complement my system."
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    Pretty sure it will not help his Hello Kitty Boombox! :smiley:
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    Yeah, so that's my conundrum right now. Finding something affordable with the least amount of front to back and side to side wobble, that can support a 30lb turntable on the top shelf.
    That was my worry as well, that because they have to make these things shippable, that the parts where they screw together would be the weak/flex point. As opposed to one solid length of column like the Adona racks.
    They do look like they can be filled with lead shot, maybe if you insert each individual piece of shot one at a time. :lol:
    So I'm sure you knew this was coming :smiley: Using the failsafe @Clipdat method of mass loading one individual lead shot sphere at a time, assuming 8 hours/day with no potty breaks, it will take you 33.6 days to fully complete your task!
    Another point for consideration! Hope this helps! :smiley:
  • delkal
    delkal Posts: 764
    verb wrote: »
    Clipdat wrote: »
    Just make a funnel out of a 2 liter bottle and use sand. Then call it a day.
    Lead is more dense but sand packs harder and is much easier to fill. And last time I priced shot for reloading it was almost $2 a pound. You can buy a 50 pound bag of sand for about $3.
    Unless you just want to spend more money for bragging rights??
  • TNTsTunes
    TNTsTunes Posts: 751
    delkal wrote: »
    verb wrote: »
    Clipdat wrote: »
    Molten lead fill for the win. ;)
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
  • kharp1
    kharp1 Posts: 3,453
    edited March 2018
    delkal wrote: »
    verb wrote: »
    Clipdat wrote: »
    Sand has a high moisture content and should be dried (usually in the oven) before using. I paid around a buck a pound for coated.
  • BlueFox
    BlueFox Posts: 15,251
    Clipdat wrote: »
    Looks sweet. Wish I had room for a "double wide" rack like that.
    In hindsight I wish I had bought a single width rack, with two maple plinths on each side for the amps. I think it would look better, and certainly provide better airflow for the amps. In fact, I have been wondering what piece of gear to upgrade next. Maybe a rack upgrade is in the cards. :)
  • Hermitism
    Hermitism Posts: 4,205
    Clipdat wrote: »
    Those holes are bigger than what I had to deal with.
  • GlennDog
    GlennDog Posts: 3,095
    BlueFox wrote: »
    Clipdat wrote: »
    Fox,
    You've relegated PASS ... To-The-Floor??
    Sacrilege!
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • BlueFox
    That ‘floor’ is more solid than the rack. It is on a concrete slab, which sits on the ground. Actually, it works out perfect for the Pass pre power supply.
  • Mike Reeter
    Mike Reeter Posts: 4,314
    BlueFox wrote: »
    Clipdat wrote: »
    Bud, It looks to me like you could have the existing shelving cut in half, re-drill new holes in the shelves and accomplish this.
    Utilize the large, lower shelf for you Amp Stands.
  • GlennDog
    BlueFox wrote: »
    Sorry!
    Not sure where you reside. I (mistakenly) assumed you lived in a home with a basement (like most folks in my vicinity)
    Cannot beat the slab for SQ
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • BlueFox
    BlueFox wrote: »
    Clipdat wrote: »
    That’s not a bad idea. Thanks.
  • verb
    verb Posts: 10,176
    verb wrote: »
    After a bit of schooling on mass loading, these 3"x3" extrusions from 80/20 would fit the bill. For the main posts.
    So I was looking for an alternative to the big honking 3" x 3" posts for legs, and found these. Same overall size, ability to mass load, but would look more integrated when assembled.
  • verb
    verb Posts: 10,176
    Hermitism wrote: »
    Clipdat wrote: »
    For you DIYers out there, a common 2" ID pipe could use these for easy assembly. they also have nice endcaps for a finished look.
    https://www.ebay.com/itm/Oajen-metal-threaded-star-type-insert-2-OD-round-tube-3-8-16-20-pcs/231688691332?ssPageName=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649
  • kharp1
    kharp1 Posts: 3,453
    verb wrote: »
    verb wrote: »
    Have a link handy?
  • verb
    verb Posts: 10,176
    Yep. Looks like were a custom run and these are surplus.
    https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/331341606913
    Tony M Posts: 11,022
    Shipping just to me is over 50.00 each. So it's 120.00 a piece. Ouch.
    I like it, but, it's not for me.
    I'll have to stick with wood I guess.
  • verb
    verb Posts: 10,176
    edited March 2018
    Tony M wrote: »
    I’m negotiating shipping for 2 pieces, which will be cut in half for the legs. Yeah he’s pretty steep on shipping. We’ll see what he comes up with.
  • kharp1
    kharp1 Posts: 3,453
    Yeah, that shipping would price me out. If I was close by and could work a deal out I'd like to try and build a rack with this material.
    Can you build one for me while you're at it?
    kharp1 wrote: »
  • WLDock
    WLDock Posts: 3,073
    edited March 2018
    BlueFox wrote: »
    I think it would look better......
    That front end, the rack, the speakers, the cable / wire, and surroundings just look amazing. Even a non audiophile can see that something expensive and special is going on in that room!
    Having sad that....
    I agree about modifying your rack given its $3500+ price and the reduced resale value and possibility of having to ship to sell it. I bet a good woodworker could cut off one half of those maple shelves to make a singe width rack. Then make amp stands with the others using the left over hardware....with some cutting and modifications. They should be able to match the deep rosewood finish. Heck, Samson / Mapleshade might even tell you what products they use to finish them?
    Someday, I would love to build a DIY rack like yours.
    2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Mirage Omni S8 sub1 | Mirage Omni S8 Sub2
  • kharp1
    kharp1 Posts: 3,453
    DSkip wrote: »
    12 pages... wow.
    Jealous?
  • marvda1
    marvda1 Posts: 4,881
    Speaker Cables: Organic Audio Organic Reference 2
    Interconnects: Argento Organic Reference 2, Argento Organic 2
    Puritan PSM156
    edited March 2018
    LOL, we've officially come full circle, back to the racks that were discussed on Page 1!
    marvda1 wrote: »
    My threads go the distance!
    DSkip wrote: »
    12 pages... wow.
    I wonder what the functional/real world/rigidity/wobble/isolation/etc. difference is between these two:
  • marvda1
    looks like the isolation will be better on the first one.
    Puritan PSM156
    Too bad those platforms are small, I can't fit my preamp and monoblocks on the same shelf.
    marvda1 wrote: »
  • marvda1
    maybe go with the 3 or 4 level rack and 2 amp stands.
    Puritan PSM156
    A good suggestion but I don't have any room. I only have room for a rack of this shape/size.
    I could put the amps on the same surface as the speakers. But not sure how they would like the vibrations.
    marvda1 wrote: »
