Topping D10 USB DAC
Clipdat
in Electronics
I just ordered the Topping D10 mini USB DAC, for my PC rig. It checks all the boxes of small formfactor, USB powered, and impressive specs. Listening impressions/review once it arrives!
https://www.amazon.com/dp/B07B46KQVP
http://www.tpdz.net/en/products/d10/index.htm
Nice... their products look well Engineered for the cost.
I don't know anything about their stuff, but I agree the price was right.
Slightly questioning the "VFL-style" display because it just seems like something that would potentially add noise.Conradicles wrote: »Nice... their products look well Engineered for the cost.
If you can hear that noise then you need to call NASA they need your ears to listen for extraterrestrial radio signals from deep space....
ET could be phoning home
I'll let you know if I can detect any high pitched noise coming from the VFL screen!
But I primarily meant internal "noise" added by the display simply being on. Kinda like how Marantz has the ability on several of their high end CD players to turn off the display.If you can hear that noise then you need to call NASA they need your ears to listen for extraterrestrial radio signals from deep space....
It has arrived!
Specs are pretty much meaningless. The sound is what counts. I am curious why you went with a hi-res component when you play 320kbps mp3's?
Good luck
I fed a stray cat once. And that mother ******* just kept coming back.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
I have a variety of digital music files stored in my collection across various file formats, bit depths and sample rates.I am curious why you went with a hi-res component when you play 320kbps mp3's?
Yet initially you did the review on the other dac with mp3's. Also don't expect a $90 dac to really knock your socks off. But I'm not the one who has to listen to said rig.
Have fun
H9Post edited by [Deleted User] on"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
It will definitely be fun to review this DAC! I don't have any expectations or preconceived notions, I'm going into this with an open mind.
Interestingly enough, it uses the same ESS chip that's used in several high end DACs including the North Star Designs Excelsio ($2,300) and Supremo ($3,000).
Obviously this doesn't really mean anything, since the implementation of the chipset is very important. Would be exciting to test them head to head though!Also don't expect a $90 dac to really knock your socks off.
Have fun
That's one thing you got right.
Let us know what your ears tell you.HT SYSTEM-
lsi 9's -
For the money how could you not give this a shot.....
Let us know what you think of it for sure! -
[emphasis added]For the money how could you not give this a shot.....
Sadly (and I'll admit this here) I've bought a fair amount of cr@p over the years by applying that logic.
Heck, I've done it within the past month
Initial listening is happening now. First impressions to follow!
Front display works!
Ok, so before I even get into listening impressions, let's talk about that VFD style screen.
It runs at a refresh rate that is visible to the eye when you affix your eyes on it and then rapidly move your head from side to side, or when you look at the screen and then blink your eyes a few times. Doing these things allows you to see the flicker/refresh of the screen.
It's a slight detail, but still would've been nice if they made the refresh faster so that you couldn't see the slight flicker under certain circumstances.
Not a deal killer by any means, but just means that when I find a final place for it, I might put it so that I can't see the screen. No humming or high frequency buzz from it at least! -
@DSkip - You have some gear that uses VFD style screens, right? Your North Star CDP and DAC have similar displays.
Ever notice that you can detect the flicker/refresh rate when doing what I described above? -
Do you expect to be moving your head this way while using the DAC? Makes me dizzy just thinking about it.
2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources. -
no, not at all. But still, even sometimes when you just quickly glance down at it after looking at the monitor, you can catch a glimpse of the flicker.
Just trying to be thorough with my review!
Oi.....close yer eyes whilst hearing the sounds.
Then perhaps the 60Hz cycling of the display won't distract you......
To hear music, at times you have to separate from the components you at trying to hear it through.
Clippers.........stop listening to the gear....just listen to what it is trying to do to help you hear that music. -
If I close my eyes I can't listen and post on Club Polk at the same time!
It's only the first day of listening, and it's raining heavily here so my noise floor is already raised from the white noise background.
Plus my cat is inside sleeping near me, don't wanna play stuff too loud and bother him.
Yes 100% -
This has to be one of the most ridiculous complaints I think I’ve ever heard! It’s 89$ dude!2 channel:
Theater:
Did you return the other one?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Shrug. I'm sensitive to refresh rates. I use a 144hz refresh rate LCD on my computer FFS.
Edit: Is it really one of the most ridiculous complaints you've EVER heard? Personally I wouldn't call certain individuals being more sensitive than others to visual stimulus in their immediate vicinity "ridiculous".This has to be one of the most ridiculous complaints I think I’ve ever heard! It’s 89$ dude!
I'm still gathering my thoughts and notes for listening impressions and details, but I'll likely be keeping this DAC.
I'm liking what I am hearing so far. -
Popcorn Pug is too exhausted to make an appearance in this thread.
@Clipdat when I move my head like that I hear a rattling sound a milk shoots out of my nose, and I don't drink milk. Lactose intolerant and all that. I hate cows. Anyway it is quite distracting from the music so you should stop doing it even if milk doesn't shoot out of your nose.
LOL, we gotta hang out sometime. We would get along.afterburnt wrote: »@Clipdat when I move my head like that I hear a rattling sound a milk shoots out of my nose, and I don't drink milk. Lactose intolerant and all that. I hate cows. Anyway it is quite distracting from the music so you should stop doing it even if milk doesn't shoot out of your nose.
