2B's Más Huevos
    pitdogg2 Posts: 27,881
    Brian did you spray paint the inside or is that something else you applied? Looks good by the way.
  • stainless0steel2
    Thanks, I brushed on 2 coats of cheap paint from Lowe's.
    The Night is Dark and Full of Terrors
    I just may steal that idea next time i have mine apart.
  • stainless0steel2
    You definitely should
    xschop Posts: 5,796
    Hey Brian, I guess I should have asked is there even a brace between the midwoofers to measure?
    The repurposed JBL cabs I saw had a thick coat of roofing polymer brushed on the inside.
  • gimpod
    gimpod Posts: 1,793
  • stainless0steel2
    xschop wrote: »
    Yea there's a 9.25"x9.25"x.75" brace. I beveled down the top edges for a little extra clearance for rings. I wish I'd done something completely different while they were out. But that ship has sailed...
  • stainless0steel2
    Well I'm closing in on finishing theses things.
    I made a template at work for these deals I'm using to mount the board.1zzut7b3sul8.jpg
    Mounted the 16mh inductors
    txcoastal1 Posts: 13,520
    Clean
    I like the wire wrap and shrink job you did in the cabinets
  • ken brydson
    ken brydson Posts: 9,098
    txcoastal1 wrote: »
    Clean
    Toolfan66 Posts: 18,412
    I like the hardware you're using, and I also like the wire wrap, I want you to share that with me..
    I'm not sure I like the paint in the cabinets, I think if it was textured it would look better, but I'm not sure if the texture would change the sound..
    Looking forward to hearing them, and what your thoughts are when you're done with them..
    xschop Posts: 5,796
    This thread proves the moderators no comprende Espanol.
  • deronb1
    deronb1 Posts: 5,021
    xschop wrote: »
    Huevos are eggs :wink:
  • agfrost
    agfrost Posts: 2,493
    I'm still looking forward to how the eggs are incorporated--always looking for ways to improve my 2BTL!
    Jay
  • stainless0steel2
    "Huevos" in Mexican Spanish (which is mostly slang) refers to having guts or balls.
  • agfrost
    Jay
  • agfrost
    Very cool. Reminds me that I've got a full set of Jantzen inductors to put in place of the stockers.
    May I ask how you secured the SDA inductor to the floor? That's the one detail I haven't worked out yet. (Is that a Northcreek inductor?)
    Jay
    I believe could be a Solen. I do not know if Northcreek is making any these days. Price page is gone and inductor page say's "retired2016" at the bottom.
  • stainless0steel2
    They're Northcreek. I bought them off of Larry awhile back.
    I'll take some pics when I get home. Mounting the inductors turned out to be really easy.
  • TNTsTunes
    TNTsTunes Posts: 751
    edited January 2018
    agfrost wrote: »
    Solen makes an air core 16mH 14AWG inductor PN# S1416.0.
    https://solen.ca/products/inductors/standard-inductors-14awg-1-63mm/s1416-0/
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
    Interested as well in the way you mounted as well. post up some pictures ;) Yep if I would of read that second picture it says northcreek right on the box lol
  • westmassguy
    westmassguy Posts: 6,850
    Just make sure the screw or bolt is non-magnetic, either stainless, brass or even aluminum.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • MrBuhl
    MrBuhl Posts: 2,419
    2bTL's eres muy guapo!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • stainless0steel2
    stainless0steel2 Posts: 193
    edited January 2018
    So I used these t-nuts and some stainless all thread that welded at the bottom. Then these plastic spacers that I made fit into the center and that's what holds this whole thing in place. Plus I added a rubber gasket for them to sit on.
    Yes I made sure everything was non-ferrous. B)
  • westmassguy
    Nice Job
  • stainless0steel2
    Man Brian those are super nice binding cups great job on all that. :D
  • agfrost
    So pretty you may want to run the speakers facing the wall. :)
    Jay
  • nikonik
    nikonik Posts: 120
    Órale vato! Those are nice ese.
  • stainless0steel2
    All done! These things sound incredible!!!
    Huge thanks to @gimpod for his guidance! As well as Larry @Toolfan66 for hooking me up with the anodizing and miscellaneous parts!
