2B's Más Huevos
stainless0steel2
Yep it's finally time to upgrade the innards of my 2B's, as well as some other mods...stay tuned.
The Night is Dark and Full of Terrors
Wow, nice looking setup!2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
I like the crimson color. Let us know how low sax, strings and pianos sound after the upgrade.Don't take experimental gene therapies from known eugenicists.
Nice Brian
Looks like you're all set.
¡Eso parece toda la enchilada! ¡Disfrutar!
stainless0steel2 wrote: »Yep it's finally time to upgrade the innards of my 2B's, as well as some other mods...stay tuned.
Aren't the inductors supposed to be mounted at opposing directions??? I believe so.
"Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
^^Sound reasoning. Thanks!
The Night is Dark and Full of Terrors -
Brian, Are you performing the TL Upgrade? Never mind, I see the RDO-198 tweeter boxes after a second look.
Where do you come up with the Replacement Inductors? -
The small ones on the board I got from PartsExpress and Madisound. And I bought the 16mh off of Larry a few months back. But he got them from here.
http://www.northcreekmusic.com/Inductors/inductors.htmlThe Night is Dark and Full of Terrors -
stainless0steel2 wrote: »The small ones on the board I got from PartsExpress and Madisound. And I bought the 16mh off of Larry a few months back. But he got them from here.
Thanks! Your set-up and your 2B's look fabulous, I'm sure will sound as good as they look when the new x-overs and parts have some time on them.
N'joy!!!
I really hate to tell you but your using the wrong inductors, The DCR is to low and the wire gauge (AWG) looks to big.
This is what you should have special ordered from PartsExpress
0.40 mH, 22 AWG, Part No. 1489,
1.25 mH, 20 AWG, Part No. 1137,
2.50 mH, 20 AWG, Part No. 1695,
Here's some link's to read on inductor replacement.
forum.polkaudio.com/discussion/138234/inductor-dcr-insanity-for-sdas/p1
forum.polkaudio.com/discussion/132437/upgrade-high-frequency-inductors-for-the-sda-srs-1-2tl/p1
Sorry.
“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Nit-pic the smaller discrepancies of the inductors while Polk had the driver values all over the place.Don't take experimental gene therapies from known eugenicists.
Sorry.
No I'm glad you said something! After browsing through DarqueKnight's deal it's definitely clear that having the correct AWG is crucial. Thanks! I'll contact PartsExpress and get those ordered.
You may have to order from a UK Jantzen distributor. Last I checked, Parts Express wasn't doing special orders anymore.
https://www.hificollective.co.uk/Home Theater/2 Channel:
dhsspeakerservice.com/ -
I might have him covered, I will check tonight..
I have these:
0.40 mH, 22 AWG, Part No. 1489 and the 2.7 MILLS if needed..
I would check with VR3 and see if he has the other inductors.. -
Well after some delay I'm back at it.
So I've decided to make some sweet cups at work out of some aluminum. Which I'll incorporate the neutrik connector into it. Which means the holes I made in the bottom corners need to be plugged with a dowel rod.
However to do it right and completely conceal that plug. I need to peel off the original veneer to place a new one over it. So that's where I'm at for the time being.
Anybody on here painted the inside of a cabinet before?
If you don't have a shop or ventilation area you can just roll some thick auto primer on and brush the corner areas
Don't take experimental gene therapies from known eugenicists. -
Just finished up the new cups.
Whoa nice side panels!!! Looks like the center strip is aluminum? Hard to tell wood species from the pics, what type did you use? Stain/finish? Also how did you attach to the sides? Can you post some close ups? I'm currently in the middle of re-doing my 1C's. Thanks !!!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Those are very nice Brian. Doing anymore?
Yep I finished up resealing and painting the insides. I replaced the veneers on the backs. The last two big things I need to do is mount the new xovers. As well as build a fixture for the 16mh inductors so they can mount on the bottom.
Yea here's the old thread. The wood caps are just the standard Ash and I put like 3 coats of stain on them. I just used some construction adhesive to attach everything.The Night is Dark and Full of Terrors -
stainless0steel2 wrote: »Just finished up the new cups.
Using my best Tim Allen voice... Uhh Uhh Uhh Stainless Steel! Good Stuff. They look great!Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
Those terminal plates turned out nicely. Looks like 6061 or 7075. Just in time for Christmas too. There's nothing like Burl Ives in SDA lol.Don't take experimental gene therapies from known eugenicists.
Thank you! yea it's 6061. I'd like to have used stainless, but I don't have enough time.The Night is Dark and Full of Terrors
As for placement of the xovers how does this look? I don't think it'll disrupt the airflow?
Airflow? Plan on porting the Brian lol
I do not think that will be a problem area. The old XO was on the cup 3" below. If you are concerned how about just below if the driver wires will be lobg enough. -
That will not be a problem area..
Looks good. I was curious what is the size (lwh) of the factory MDF brace between the midwoofers?Post edited by xschop onDon't take experimental gene therapies from known eugenicists.
