2B's Más Huevos
stainless0steel2
stainless0steel2 Posts: 193
edited October 2017 in Vintage Speakers
Yep it's finally time to upgrade the innards of my 2B's, as well as some other mods...stay tuned.
The Night is Dark and Full of Terrors
«13
  • hochpt21
    hochpt21 Posts: 5,423
    Wow, nice looking setup!
    xschop Posts: 5,838
    I like the crimson color. Let us know how low sax, strings and pianos sound after the upgrade.
  • monepolk
    monepolk Posts: 1,154
    Looks like you're all set.
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    ¡Eso parece toda la enchilada! ¡Disfrutar!
  • TNTsTunes
    TNTsTunes Posts: 751
    Aren't the inductors supposed to be mounted at opposing directions??? I believe so.
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
  • stainless0steel2
    ^^Sound reasoning. Thanks!
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited October 2017
    Brian, Are you performing the TL Upgrade? Never mind, I see the RDO-198 tweeter boxes after a second look.
    Where do you come up with the Replacement Inductors?
  • stainless0steel2
    edited October 2017
    The small ones on the board I got from PartsExpress and Madisound. And I bought the 16mh off of Larry a few months back. But he got them from here.
    http://www.northcreekmusic.com/Inductors/inductors.html
  • Mike Reeter
    Thanks! Your set-up and your 2B's look fabulous, I'm sure will sound as good as they look when the new x-overs and parts have some time on them.
    N'joy!!!
  • gimpod
    gimpod Posts: 1,793
    I really hate to tell you but your using the wrong inductors, The DCR is to low and the wire gauge (AWG) looks to big.
    This is what you should have special ordered from PartsExpress
    0.40 mH, 22 AWG, Part No. 1489,
    1.25 mH, 20 AWG, Part No. 1137,
    2.50 mH, 20 AWG, Part No. 1695,
    Here's some link's to read on inductor replacement.
    forum.polkaudio.com/discussion/138234/inductor-dcr-insanity-for-sdas/p1
    forum.polkaudio.com/discussion/132437/upgrade-high-frequency-inductors-for-the-sda-srs-1-2tl/p1
    Sorry. :disappointed:
    xschop Posts: 5,838
    Nit-pic the smaller discrepancies of the inductors while Polk had the driver values all over the place.
  • stainless0steel2
    edited October 2017
    gimpod wrote: »
    No I'm glad you said something! After browsing through DarqueKnight's deal it's definitely clear that having the correct AWG is crucial. Thanks! I'll contact PartsExpress and get those ordered.
  • westmassguy
    westmassguy Posts: 6,850
    You may have to order from a UK Jantzen distributor. Last I checked, Parts Express wasn't doing special orders anymore.
    https://www.hificollective.co.uk/
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • stainless0steel2
    Well after some delay I'm back at it.
    So I've decided to make some sweet cups at work out of some aluminum. Which I'll incorporate the neutrik connector into it. Which means the holes I made in the bottom corners need to be plugged with a dowel rod.
    However to do it right and completely conceal that plug. I need to peel off the original veneer to place a new one over it. So that's where I'm at for the time being.
    Anybody on here painted the inside of a cabinet before?
    xschop Posts: 5,838
    If you don't have a shop or ventilation area you can just roll some thick auto primer on and brush the corner areas
  • stainless0steel2
    edited December 2017
  • verb
    verb Posts: 10,176
    Whoa nice side panels!!! Looks like the center strip is aluminum? Hard to tell wood species from the pics, what type did you use? Stain/finish? Also how did you attach to the sides? Can you post some close ups? I'm currently in the middle of re-doing my 1C's. Thanks !!!
  • stainless0steel2
    Yep I finished up resealing and painting the insides. I replaced the veneers on the backs. The last two big things I need to do is mount the new xovers. As well as build a fixture for the 16mh inductors so they can mount on the bottom.
  • stainless0steel2
    verb wrote: »
    Yea here's the old thread. The wood caps are just the standard Ash and I put like 3 coats of stain on them. I just used some construction adhesive to attach everything.
  • helipilotdoug
    Using my best Tim Allen voice... Uhh Uhh Uhh Stainless Steel! Good Stuff. They look great!
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
    xschop Posts: 5,838
    Those terminal plates turned out nicely. Looks like 6061 or 7075. Just in time for Christmas too. There's nothing like Burl Ives in SDA lol.
  • stainless0steel2
    Thank you! yea it's 6061. I'd like to have used stainless, but I don't have enough time.
  • stainless0steel2
    As for placement of the xovers how does this look? I don't think it'll disrupt the airflow?
    xschop Posts: 5,838
    Looks good. I was curious what is the size (lwh) of the factory MDF brace between the midwoofers?
  • stainless0steel2
    Brian did you spray paint the inside or is that something else you applied? Looks good by the way.
    Thanks, I brushed on 2 coats of cheap paint from Lowe's.
