Hahahaha just got notification that my screen delivery for tomorrow has been delayed due to mechanic delivery issues.... @TNTsTunes nailed it! Hahahaha only UPS..did I say How much I hate UPS! And when it does arrive it will be all beat up!
Family Room:
Samsung UN75RU710DFXZA,
Denon AVR-X4400H, Emotiva XPA3 GEN3
Oppo BDP-93,Sony UBP-X800BM, WD Live HUB.
Main: Polk LsiM 705
Center: Polk LSiM 704C
Front High/Rear High In-Ceiling Polk 80F/X RT
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Marantz SR5010, BDP-S270
Main: Polk Signature S20
Center: Polk Signature S35
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Sony 2100ES AVR, Sony DVP-NS3100ES for disc
Cerwin Vega AT-12 (blasters) Advent Prodigy (listening)
Old sony 12" Sub
Mini tower PC with 400GB of music
So tomorrow when my sub comes in I'm going to hook up the dvr and the sub. Since I don't habe my speakers I'm going to hook up my HTiB speakers and see what happens. I'm guessing at low volume them will be fine as long as the low volume can pump out some bass.. Worse case is I blow them little things up..hehe
Gonna be honest with you, I'm not a fan of how you're trying to get this done. Not just you, A LOT of people approach it like you are, and it's a mistake.
If you're on a tight budget, don't go for the whole system at once. You end up with key parts of the system that are going to let you down.
Start with the KEY parts. Receiver, main stereo pair and a sub. Budget for good wiring and interconnects (does not have to cost a ton for good entry level stuff). I like Canare 4s8 or 4s11 for budget speaker wire and AudioQuest pearl HDMI cables are a GREAT wire for the $$.
Shop smart and do it over a longer period and in the long run, you will have a FAR better system.
Polk eBay store has the S50 towers for $175 each, the PSW 505 for $199 (if that's all you can swing). However, I personally MUCH prefer SVS for a sub but that's going well outside of your mentioned budget.
Accessories4less has something like the Denon X4300 or Yamaha RX-A1060 for $700.
Then save for center, then do surrounds, then in the long run or when it quits buy a better sub...
It will take longer, but you'll have better results.
That's what I did until I lost my mind. I was upgrading one thing at a time and eventually ended up with a decent second system. But then I lost my mind but now I have two fine systems and no money.
might be a good way to start. be sure to Run Audyssey on the setup
Family Room:
Main: Polk LsiM 705
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Old sony 12" Sub
Just jumpin in here. If you are lazy or spineless like myself, choose your subs carefully because it's a biznitch returning them, or at least I think so cause I either kept or gave away mine (PICK UP ONLY) I never returned any of them.
darn dud where you live... next sub you give away I might do a road trip
Family Room:
Main: Polk LsiM 705
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Old sony 12" Sub
Family Room:
Main: Polk LsiM 705
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Old sony 12" Sub
Dude this SVS sub is beautiful! Haha and I got an SVS shirt with it. I'll have it hooked up later this evening after I get my screen built and hung. Too bad I have to wait until Monday to get my signatures.
Wait till you get the speakers, they are a work of art.
Family Room:
Main: Polk LsiM 705
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Old sony 12" Sub
Well my denon does not seem to be putting a source out. I plugged HDMI from projector to the out on the receiver. Turn on and denon goes into set up and days use tv..but nothing..ugh
Yes I've read it. I hooked up nothing but the denon out to my TV now. The TV does not show denon as a source. I would figure HDMI is plug and play. If not seriously enlighten me because I'm frustrated right now with it. I've even hooked up some speaker and went to the tuner and it locks on a tune but plays no music. I've tried the video passthrough with a DVD player and nothing goes through. I went into the menu on the small denon display and passthrough is on. HDMI's are all assigned. Now I'm no dummy when it comes to technology but dang if it sure dont seem like I'm doing something stupid. I am getting no output of anything video or audio.
I have reseated cables and power cables countless times and even tried different tv's and my projector. I'll habe to wait until tomorrow and call denon and see what they think.
Looks like my projector is not hdcp 2.2 cpmpliant..now what? But that still doesn't seem like it would stop audio from the tuner even when all video output is unplugged?
The last projectors I worked with had 5-wire BNC, so I don't know much about how they deal with newer connections. Sometimes if the output resolution doesn't match a TV's native resolution exactly, you will get no image, although it's odd that a home theater receiver would produce anything that wouldn't be instantly recognized.
Something is not right. I have never played with a projector but would figure it would work like a normal TV. HDMI is backwards compatible so it should work. Zone 2 might be turned on too, that can be a problem.
Family Room:
Main: Polk LsiM 705
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Old sony 12" Sub
I remember seeing a setup video once. the guy had to use a PC monitor that had HDMI to setup everything and turn passthrough on. Doubt you will get sound till setup is ran.
Family Room:
Main: Polk LsiM 705
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Old sony 12" Sub
Family Room:
Main: Polk LsiM 705
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Old sony 12" Sub
I disabled, I am the South Carolina woman who gouged her eyes out on meth.
Family Room:
Main: Polk LsiM 705
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Old sony 12" Sub
Family Room:
Main: Polk LsiM 705
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Old sony 12" Sub
Family Room:
Main: Polk LsiM 705
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Old sony 12" Sub
Carly Simon
Family Room:
Main: Polk LsiM 705
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Old sony 12" Sub
Family Room:
Main: Polk LsiM 705
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Old sony 12" Sub
Family Room:
Main: Polk LsiM 705
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Old sony 12" Sub
