Vinyl Death Grip!!!
    Toolfan66 Posts: 18,414
    The last part is being a pain...
  • agfrost
    agfrost Posts: 2,493
    Maybe avoid tightening with a 3' pipe wrench elongated with a 10' cheater bar...
    (ouch)
    Jay
  • motorhead43026
    Tighten until it turns freely, then tighten an additional 1/4 turn.
    And the boots you lick will stomp you too.
  • BlueMDPicker
    How did it bend/contort so badly? :o
    Sorry you're having mechanical issues.
  • ken brydson
    Toolfan66 wrote: »
    PFB in the house?
    mhardy6647 Posts: 35,555
    Toolfan66 wrote: »
    PFB in the house?
    Avatar + Signature material right there
    pitdogg2 Posts: 27,884
    My guess Larry was machining and it got wonky quick like.
  • dkg999
    dkg999 Posts: 5,647
    With the judicious use of heat and hydraulic pressure that will straighten right up :)
    DKG999
    Yeah, our guys came through!!!
  • scubalab
    scubalab Posts: 3,105
    Looks like the first production run is limited to 18? ;)
    17 Larry gets a freebie
  • dromunds
    dromunds Posts: 10,174
    Awesome! (Says guy who called "dibs" one month ago). o:)
    edited September 2017
  • gimpod
    gimpod Posts: 1,793
    Toolfan66 wrote: »
    Yes tighten 1/4 turn before breaking! (From an old Harley Davidson repair manual) :)
  • dkfreebird
    dkfreebird Posts: 1,189
    I believe that was the instruction on my 73 Sporsters clutch adjustment.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    Eversolo Dmp 8
    SVS SB3000 sub
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
    So I'm having a difficult time finding the rubber piece for the inside of the clamp, I know it doesn't have to be exactly the same for what it does but I would at least like something close..
    Anyone have any ideas I'm all ears.. :)
    F1nut Posts: 52,382
    Goodyear?
  • FestYboy
    FestYboy Posts: 3,861
    Where does it sit and what exactly is it's function? I have a resource or 2 that might get you where you want to be.
  • vmaxer
    vmaxer Posts: 5,123
    Pretty sure the clamp used Sorbothane, may be hard to find in that form??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    It really works as a spring, as you loosen the clamp it helps open the collet..
  • vmaxer
    vmaxer Posts: 5,123
    Discussed on this document.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • FestYboy
    Ok so you need a high durometer low surface friction piece... How much compression are you typically seeing?
  • vmaxer
    vmaxer Posts: 5,123
    There are other materials that dampen also, silicones do well. Not sure how it compares though??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    FestYboy wrote: »
    I would say about 0.060 to 0.090 its really hard to tell with the piece inside the clamp..
    The piece is 1.000 in length..
  • FestYboy
    Ok in that case, I'd recommend a large (thick) undersized O ring supported by a nylon collar. The ring will act like a spring with low friction. A square O ring will be more aggressive but harder to source.
    Accurate Gasket hooked me up..
  • FestYboy
    Well then that's a win... And I still want to know where to send the monies.
