Vinyl Death Grip!!!
The last part is being a pain... -
Maybe avoid tightening with a 3' pipe wrench elongated with a 10' cheater bar...
(ouch)Jay
Tighten until it turns freely, then tighten an additional 1/4 turn.2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
The best way to predict the future is to invent it.
It is imperative that we recognize that an opinion is not a fact.
Imagine making politics your entire personality. -
How did it bend/contort so badly?
Sorry you're having mechanical issues. -
ken brydson wrote: »
Avatar + Signature material right there -
My guess Larry was machining and it got wonky quick like.
With the judicious use of heat and hydraulic pressure that will straighten right upDKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Yeah, our guys came through!!!
Looks like the first production run is limited to 18?
17 Larry gets a freebie
Awesome! (Says guy who called "dibs" one month ago).
Yes tighten 1/4 turn before breaking! (From an old Harley Davidson repair manual)“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
I believe that was the instruction on my 73 Sporsters clutch adjustment.2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Monitor 4 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino Rogue Magnum 66 pre -
So I'm having a difficult time finding the rubber piece for the inside of the clamp, I know it doesn't have to be exactly the same for what it does but I would at least like something close..
Anyone have any ideas I'm all ears.. -
Goodyear?Political Correctness'.........defined
President of Club Polk -
Where does it sit and what exactly is it's function? I have a resource or 2 that might get you where you want to be.
Pretty sure the clamp used Sorbothane, may be hard to find in that form??Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
It really works as a spring, as you loosen the clamp it helps open the collet..
Discussed on this document.
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Ok so you need a high durometer low surface friction piece... How much compression are you typically seeing?
There are other materials that dampen also, silicones do well. Not sure how it compares though??Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I would say about 0.060 to 0.090 its really hard to tell with the piece inside the clamp..
The piece is 1.000 in length..
Ok in that case, I'd recommend a large (thick) undersized O ring supported by a nylon collar. The ring will act like a spring with low friction. A square O ring will be more aggressive but harder to source.
Accurate Gasket hooked me up..
Well then that's a win... And I still want to know where to send the monies.
