Vinyl Death Grip!!!
    The last part is being a pain...
  • Maybe avoid tightening with a 3' pipe wrench elongated with a 10' cheater bar...
    (ouch)
    Jay
  • Tighten until it turns freely, then tighten an additional 1/4 turn.
  • How did it bend/contort so badly? :o
    Sorry you're having mechanical issues.
  • Toolfan66 wrote: »
    PFB in the house?
    PFB in the house?
    Avatar + Signature material right there
  • My guess Larry was machining and it got wonky quick like.
  • With the judicious use of heat and hydraulic pressure that will straighten right up :)
    DKG999
    Yeah, our guys came through!!!
  • Looks like the first production run is limited to 18? ;)
  • 17 Larry gets a freebie
  • Awesome! (Says guy who called "dibs" one month ago). o:)
    edited September 2017
    Yes tighten 1/4 turn before breaking! (From an old Harley Davidson repair manual) :)
  • I believe that was the instruction on my 73 Sporsters clutch adjustment.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
  • So I'm having a difficult time finding the rubber piece for the inside of the clamp, I know it doesn't have to be exactly the same for what it does but I would at least like something close..
    Anyone have any ideas I'm all ears.. :)
  • Goodyear?
  • Where does it sit and what exactly is it's function? I have a resource or 2 that might get you where you want to be.
  • Pretty sure the clamp used Sorbothane, may be hard to find in that form??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • It really works as a spring, as you loosen the clamp it helps open the collet..
  • Discussed on this document.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Ok so you need a high durometer low surface friction piece... How much compression are you typically seeing?
  • There are other materials that dampen also, silicones do well. Not sure how it compares though??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • FestYboy wrote: »
    I would say about 0.060 to 0.090 its really hard to tell with the piece inside the clamp..
    The piece is 1.000 in length..
  • Ok in that case, I'd recommend a large (thick) undersized O ring supported by a nylon collar. The ring will act like a spring with low friction. A square O ring will be more aggressive but harder to source.
  • Accurate Gasket hooked me up..
  • Well then that's a win... And I still want to know where to send the monies.
