which speakers are better?
Howdy, I'm upgrading from my home theater from a sony HIB and looking at polk speakers. Im sticking around a grand for receiver and speakers. So naturally im looking at the complete T-series set up with an onkyo tx nr757. But on Amazon I saw a onkyo tx nr656 with polk TSi speakers bundle that fit my budget as well...Which speaker line is better TSi or The t-series? I cant seem to find much info out there to compare the 2 lines.
The Polk line is this.
"T" series
Signature which replaced TSi
RTIA
LSI
Family Room:
Samsung UN75RU710DFXZA,
Denon AVR-X4400H, Emotiva XPA3 GEN3
Oppo BDP-93,Sony UBP-X800BM, WD Live HUB.
Main: Polk LsiM 705
Center: Polk LSiM 704C
Front High/Rear High In-Ceiling Polk 80F/X RT
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Marantz SR5010, BDP-S270
Main: Polk Signature S20
Center: Polk Signature S35
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Sony 2100ES AVR, Sony DVP-NS3100ES for disc
Cerwin Vega AT-12 (blasters) Advent Prodigy (listening)
Old sony 12" Sub
Mini tower PC with 400GB of music
From experience the Signature are a significant improvement in sound quality. Everyone who's listened to S20 bookshelves is pleased. In comparison to the older design Monitor towers, they're just better overall, except for lacking the low end. Signature towers provide a full range for music.
Can't compare to TSi line as I've no experience.
Other; S60'S, M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
There are three things that give a man a false sense of courage, a keyboard, alcohol and a firearm.
Motorhead, 4.12.20
tonyb said " but even socialists can do a good thing here and there
the substitution of politics for existence is the supreme betrayal of the subjective otherness of man.
Whichever you choose will probably be an improvement to most HTIB systems.
The Tx NR-656 and the Tx NR-757..the only real difference is the 757 has Thx. Is that something that is noticeable and is it worth an extra 100 or so bucks. I've never heard anything other than my HTIB and my buddies full on Klipsch system. I'm not spending that kind or coin..not even close. Haha
This is the bundle I was talking about.
https://www.amazon.com/gp/aw/d/B01N0T84HE/ref=ox_sc_saved_image_4?ie=UTF8&psc=1&smid=AED492BX4II6G
Or go T series but still in the air on receiver.
Personally, not a fan of their sound or build quality.
Have you looked at any of the Yamaha options?
Samsung PN50B860 50" Plasma : XBOX One : Roku Ultra : Oppo UDP-203 : Pioneer Elite SC-87 : APC H15 : Focal 806V mains : Focal 806V Surrounds : SVS SB2000 : SVS SB12-NSD
2Ch:
Sonus Faber Venere S : Rotel RB 1582 MKII : Oppo UDP-205 : Furman Elite 15 DM i : Pro-Ject Debut Carbon with Acryl-It Platter :
in your budget and better speakers https://www.amazon.com/RX-V681BL-7-2-Channel-Receiver-Polk-Audio/dp/B01H25A1RC/ref=pd_day0_504_14?_encoding=UTF8&pd_rd_i=B01H25A1RC&pd_rd_r=2T2NY6YTKYAG7GVRGSS8&pd_rd_w=14dN5&pd_rd_wg=CW8Vi&psc=1&refRID=2T2NY6YTKYAG7GVRGSS8
This is the one I would get in your price range https://www.amazon.com/AVENTAGE-RX-A760BL-7-2-Channel-Polk-Audio/dp/B01GIE0LAU/ref=pd_cp_504_3?_encoding=UTF8&pd_rd_i=B01GIE0LAU&pd_rd_r=RQ1J2NZRMW1XAKXH78VH&pd_rd_w=CHkPC&pd_rd_wg=73Sbo&psc=1&refRID=RQ1J2NZRMW1XAKXH78VH
a lot more but you will love it for years https://www.adorama.com/pkults60b.html
Family Room:
Main: Polk LsiM 705
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Old sony 12" Sub
Not a bad system for the price. Think you'll like it better than your HTIB system.
You'll need speaker wire, a subwoofer cable, and HDMI cable(s) to get everything up and running. Check Blue Jeans cable for budget friendly speaker cable. Would recommend Audioquest's Forrest HDMI cable, may seem a little pricey to you, but the little extra is well worth it.
I always heard good things about Onkyo but the 656 actually has a lot of complaints. I stayed with Onkyo solely to chop the field down as I was overwhelmed with all that was out there.
I have not looked at Yamaha but my BIL has a Yamaha receiver and loves it. So back to the drawing board.
As for speakers, I like your choice. There was a period of time right after the 80's when Polk disappointed a bit but the new ones sound pretty remarkable when paired with a sub.
Let us know what you finally decide.
Go to the Accessories4Less website for the AVR. There factory refurbished, but I personally haven't had any problems/issues with anything I've bought from them.
Looks like it will come out about the same price as the bundle you looked at.
It's true that Onkyo's is having issues with their HDMI boards, but I personally have an issue with their AccuEQ calibration program they use. The board can be replaced, the calibration program can't.
The problem is the receiver I cant seem to find much about and compare to the Onkyo nr656. Ill have to research some, my plan is to stay around 1200 but no more. I have to upgrade my screen as well so have to save some cash for it. Going from a 100" manual pull down to a Wife requested 125" electric tab tension. That will be the max size able to fit in our spot. This is in a bonus room above a garage so its not all that big.
WHOA. 'Wife requested 125"' screen? I guess size matters to women after all! My Wife doesn't want to see any electronics or speakers. Lucky you.
Honestly I would get the Yamaha packages over the Onkyo any day. I would try to push for the RX-A760 more, $200 more and a lot better system.
Family Room:
Main: Polk LsiM 705
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Old sony 12" Sub
I really am! She could likely go without the audio but she wants the bigger screen. So....Im gonna do both, then set the room up like an actual theater with a riser and two rows of seats. I hope it all comes together!
Im scared on the audio though. Spending that much and she cant tell a difference from it and the HTIB we have been using. She is not big on super loud and thunderous but I am.
Ill see what kind of deal they can work on that other system. It is starting to get on up there though and next thing you know Ill be rocking the latest Klipsch..hahaha There is always that next best speaker. I just want a good sounding system for a dedicated smallish theater. But if they can quote me the better package for 1200 or really close I can go that way.
And make sure it's a reliable brand.
Check Crutchfield. You can compare both of those AVR's, side by side on their site.
As for speakers Both the packages above have the same speaker setup. If you can find a Signature package jump on it.
I agree these are good units but the cost is out of the OP's budget.
Family Room:
Main: Polk LsiM 705
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Old sony 12" Sub
https://www.newegg.com/Product/Product.aspx?Item=9SIA36V5X45794
https://www.newegg.com/Product/Product.aspx?Item=9SIA36V5X55205
https://www.newegg.com/Product/Product.aspx?Item=9SIA36V5TE2271
I know they are a little over budget but Signatures man Signatures. You friend with the K things will envy you
Oh yeah buddy
Go for this
https://www.amazon.com/Polk-Audio-Signature-RX-V683BL-Receiver/dp/B072HNR4LC/ref=sr_1_53?s=electronics&ie=UTF8&qid=1505449028&sr=1-53&keywords=polk+signature+speakers
Way over budget
https://www.amazon.com/Polk-Audio-Signature-Subwoofer-AVR-X1300W/dp/B071CZWFZT/ref=sr_1_29?s=electronics&ie=UTF8&qid=1505448963&sr=1-29&keywords=polk+signature+speakers
My wife didn't like my HT before the Signatures. Now she likes it says they look nice
Family Room:
Main: Polk LsiM 705
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Old sony 12" Sub
https://www.amazon.com/Polk-Audio-Signature-Bookshelf-AVR-X1300W/dp/B071XZ5B84/ref=sr_1_178?s=electronics&ie=UTF8&qid=1505449615&sr=1-178&keywords=polk+signature+speakers
Denon "X" series AVR and Signatures can't go wrong just need a sub crud
Family Room:
Main: Polk LsiM 705
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Old sony 12" Sub
https://www.amazon.com/Polk-Audio-Center-Channel-Speaker/dp/B0018QNYSK/ref=sr_1_1?ie=UTF8&qid=1505451216&sr=8-1&keywords=polk+cs+20
http://www.ebay.com/itm/Polk-Audio-PSW505-BLACK-12-Powered-Subwoofer-NEW-/362095388009
https://www.accessories4less.com/make-a-store/item/yamrxa760bl/yamaha-rx-a760-7.2-ch-x-90-watts-networking-a/v-receiver/1.html
Have to go to a few websites, but within your budget.
Moving up from HTiaB, you should love this setup and it's around your budget. You can jump down the rabbit-hole later and enjoy this now. Seems like a great deal.
Add $200 for a PSW 505
If the OP can up his budget by a few bill's that would be a great system for entry level
Family Room:
Main: Polk LsiM 705
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Old sony 12" Sub
North Mississippi...Craigslist is about worthless here. hahaha Even in surrounding areas it is not that good.
This is what I would get, and then start saving money for SVS sub.
