Club Polk Perception
1246711
    EndersShadow Posts: 17,689
    lightman1 wrote: »
    Sweet Petunia Jane! That's a mess o' amps!
    Turn in the Caddy Russ and get you somma dat!
    txcoastal1 Posts: 13,500
    Well if you move to Siberia, those amps would serve a dual purpose and pay for themselves
    gudnoyez Posts: 8,159
    ^Dear Sir or Madame: @DonnerUndBlitzen
    Once again it appears you are missing why people are not happy with you. You are more than welcome to your own opinion on subjects, that is fine.
    However when you post a comment, like the one you did earlier today in this same thread, eluding to the fact this place is still like a "20 acre food fight", you MUST understand how that will be taken offensively by many.
    This is just the same way you seem to be taking offense to comments directed toward you by others because they have a opposite view than you as to the status of this forum.
    You cannot have it both ways. You cannot express YOUR OPINION and then get mad and lash out when people disagree with you.
    Additionally when your having a disagreement with someone that you don't know personally, adding jokes into your commentary (re: bad burrito) doesn't make them funny. It comes off as offensive and an attempt to pass your post off as humor instead of the intended wicked insulting barb it is.
    Polk Management is welcome to allow whoever to post whatever they want, on their forum, subject to their rules. However don't mistake their lack of weighing in on your, or any of our actions for approval of them. Neither you nor I have any idea what conversations may or may not be taking place regarding current members, myself included, and possible bans, removal of posts, etc.
    For one I would appreciate if you kept your attempt at humor when disagree with someone to yourself, as it comes of as insulting. Additionally if the forum continues to be a "20 acre food fight" you are welcome to stay and join in the fun, walk out the door, or sit silent on the sidelines taunting everyone trying to stay clean.
    I have reported your post, and should you continue to act as such, will continue to report all subsequent posts by you.
    My last comment is that perhaps when you discover that everyone on a given forum, this one or otherwise, has a problem with you, and you alone, and that one fact is the only consistent thing tying everything together, perhaps the issue doesn't lie with them, but in some behavior you continue to repeat.
    Something to think about, while you debate how to respond to my post in a passive/aggressive/insulting way.
    Warmer than Warmest Regards
    Dan
    PS I dont like mexican, so make your comments about me reference chinese food or steaks (see I posted humor, so you cant take offense at anything I said above. I will even end it with a :smile: )
    DUB spelled backwards means BUD, or does BUD spelled backwards means DUB? Kindest warmest regards the peanut gallery :o
    F1nut Posts: 51,700
    DSkip wrote: »
    700 watts of tube power is just building it to see if you can. I'd love to say that impresses me, but it doesn't.
    It should. He makes incredible tube amps.
    nooshinjohn Posts: 25,890
    There is a need for that much power, but 95% of us don't need it. The rest can't afford it
  • FestYboy
    FestYboy Posts: 3,861
    DSkip wrote: »
    I know he does. I'm not saying these won't be great. Just pushing a design to that level doesn't impress me. I'd rather see him make a lower watt amp push the boundaries.
    I suspect there will be some trickle down with this and through imitation, the tube community in general will glean better amps from this innovation.
  • BlueFox
    BlueFox Posts: 15,251
    gudnoyez wrote: »
    Dan
    Golly. You cracked my encryption and exposed me. Now the gloves are off. :)
    Mine do an easy 350 and that is enough for me. The 700 watt amps are actually rated at 900 watts as I recall if you run KT120's. I have heard these driving the big Magico speakers. Then listened again using Classe mono amps. The big Carvers were night and day better in every regard.
    If I had the coin, I would not hesitate pulling the trigger.
    F1nut Posts: 51,700
    edited August 2017
    DSkip wrote: »
    John, when would one need 700 watts of tube power? My thoughts would be, at the price point I'm expecting this one to hit, that one who would need that much power would be invested in a true multi-amp configuration and would put a solid state amplifier on the bass drivers. It seems many of the modern designs where that much power is needed already have internal amplifiers for the bass drivers anyways.
    I'm not being argumentative there - I really would like to know where you think this application is needed. I don't even have an issue with your beasts, but doubling down on that seems unnecessary in every situation I can think of.
    FestYboy wrote: »
    DSkip wrote: »
    I need to read through the write-up, but my gut tells me there isn't much innovation in the design so much as setting a power goal and throwing in enough tubes to reach it. That isn't to say its a bad design or Bob doesn't know what he is doing (obviously he does), but when I see that kind of number I think its more to do with sticker-shock as opposed to ingenuity in design.
    There is innovation in his amps, the longevity of the tubes and how that is accomplished being the most note worthy in the current versions. He used the knowledge gained from the original Silver 6, Silver 7 and Silver 9 tube mono blocks with separate power supplies that he made years ago to create the current versions. There may have been a few other tube amps back then that used separate power supplies, but I can't think of any. Let me tell you those original amps are amazing, the sound quality is off the charts great. They also happen to be the only amps I've heard that can properly drive the Carver Platinum speakers. I've heard high powered SS amps choke trying to drive those speakers. So, if his tube amps can drive those just think how well they'd do with other speakers.
    What you get from running high quality, high powered amps, SS or tubes is speed, iron fisted bass and unreal dynamics with an ease that is very hard to perhaps impossible to get otherwise.
    pitdogg2 Posts: 26,961
    No doubt.
    Wonder what he could do with the new Tung Sol tubes ?
    treitz3 Posts: 19,954
    DSkip wrote: »
    That's because you haven't heard them yet. Once you do, you would be singing a different tune.
    On another note, he designed a small tube amp that we (54 of us) actually built up on the mountain at Carverfest one year. To date, I have only heard one smaller tube amp that comes close to the sonic characteristics that little amp puts out. I don't recall the name of it and it's currently no longer on his website but I have two of them configured in mono. If memory serves, they only produce 12 watts and could make a pair of Apogees sound wonderful at reasonable levels. What would make those very same speakers sound incredible? The amps you mentioned not being impressed with.
    They have the reserve power to handle the Apogees, Amazings, Quads and the like without breaking a sweat but have the clarity and finesse to put Eva Cassidy right there in your living room.
    If there is one thing that Bob is truly a master of, that would be tube amps.
    I personally gave Bob mad accolades on the sonic signature of those tube amps we built up on the mountain. Those that own the amps still sing praises of what Bob accomplished with this little amp. I also say this with the first hand knowledge of hearing close to every amplifier, tube and SS, that he has ever produced with all of his companies he has had. The one I wished I had put my ears on was the one that started it all....the coffee can amp.
  • K_M
    K_M Posts: 1,632
    polrbehr wrote: »
    K_M wrote: »
    My last comment is that perhaps when you discover that everyone on a given forum, this one or otherwise, has a problem with you, and you alone, and that one fact is the only consistent thing tying everything together, perhaps the issue doesn't lie with them,but in some behavior you continue to repeat.
    I find this comment somewhat disturbing. I am hoping it was meant in jest, although you implied you do not jest with someone you do not know well.
    I find it quite hard to believe that "Everyone" on this forum has a problem with DuB, and likewise hard to believe you have spoken to literally everyone about him.
    I will even agree with you, at times, some of his comments seem :out of place" or could cause some of the backlash you mention, but to literally insinuate, Every person on the forum has some issue with him?
    I see the same 8-12 guys Bashing him, and a few others people, no matter what they say, then then going back and piling on over and over again, almost as if it is entertainment or a way to fight boredom.
    I seem to remember someone telling me about being embarrassed by how several in the forum behave.......... :*
    I will come right out and ask you. If this place is so horrible/intolerable, why not just stay away? When I joined this place, I acted like an a$$ on several occasions, got into some stupid back-and-forths with a few people, and wondered why I bothered logging in again.
    I Never said anything about this forum being horrible/intolerable. That is your altered perception of what I said.
    I find a lot of valuable information here, and I often PM privately to several people.
    I tend to read a LOT more than I post.
    From what several long term members have told me, things have not been well for many years. The same several guys bash 4-6 'targeted" people and all pile on them, tell them they are trolls, tell them they do not understand the forum etc....till they force them to leave or argue back enough to get banned.
  • mrbiron
    mrbiron Posts: 5,718
  • exalted512
    exalted512 Posts: 10,735
    I only came here for the TBT, now that it's gone I don't frequent nearly as much. The people here are looney. And that JStas guy types too much.
    -Cody
  • K_M
    K_M Posts: 1,632
    heiney9 wrote: »
    polrbehr wrote: »
    K_M wrote: »
    stay away? When I joined this place, I acted like an a$$ on several occasions, got into some stupid back-and-forths with a few people, and wondered why I bothered logging in again. But after awhile, it started to occur to me that - A. the stuff I thought I knew about was nothing compared to what a lot of people actually did (WTH is a noise floor, anyway?), and B. I could learn an awful lot by reading more and posting less. Hence my fairly low post count, even to this day.
    Speaking only for myself, I am glad I stayed, and figured out what this place was all about.
    Stop trying to reason with an unreasonable person. They'll never get it. The world is out to get them at every turn.
    10 guys on an audio forum is not the world. Maybe to you it is.
    edited August 2017
    Speaking words of wisdom Let it be
    https://youtu.be/ZtNU616XqQk
    exalted512 wrote: »
    -Cody
    At least our threads bring folks out of witness protection hiding :p
    mhardy6647 Posts: 34,934
    exalted512 wrote: »
    -Cody
    umm -- "TBT"? das verstehe ich nicht. :/
    "Triple Blind Testing"?
    tonyb Posts: 33,068
    tasteless babe thread......c'mon Mark, your not that old. ;)
  • mrbiron
    My noodle twitched and i knew i had to get to the forum immediately!!!!
    Did someone mention the fabled Rick88 TBT thread?!?!?!?!!?
    Bring it back....bring it back....bring it back....
    Come on guys, if we all chant together, this can happen!
    Bring it back....bring it back....bring it back....Bring it back....bring it back....bring it back....Bring it back....bring it back....bring it back....
  • Jstas
    Jstas Posts: 14,977
    It won't. You know it won't. Don't start causing an issue over it, please.
    Expert Moron Extraordinaire
    tonyb wrote: »
    I -- I forgot the nomenclature :/
    -- and I am getting old, if you catch my drift :(
    edited August 2017
    mrbiron wrote: »
    https://youtu.be/88b0OYxdtyM?t=4m28s
  • mrbiron
    Jstas wrote: »
    All in jest. I'm certain that thread has been wiped from existence as we know it.
    I'd rather the "Leaf" threads be resurrected ;)
  • BlueFox
    DSkip wrote: »
    The Ultimates? If so, those definitely do not need 700 watts. I don't doubt they bested the Classe amplifiers though.
    I heard The Ultimates; $650K, at Magico in their listening room, and demoed by Alon Wolf. Each horn has its own amp and xover, although I didn't ask about the power. They effortlessly filled the listening room with sound, and, obviously, sounded great.
    However, to me, they are ugly as sin, and really didn't sound that much better than the S5s. At that level, you are dealing with nuances in sound, and at a great cost.
  • DSkip wrote: »
    DSkip wrote: »
    FestYboy wrote: »
    DSkip wrote: »
    Thanks for this information. I get the 700 watts... I just don't get it in tube form. Tubes themselves are not the best at controlling woofers. My point was if you need the power, go SS on those bass drivers for better control and overall better sound. For someone playing at that level biamping or triamping can be done right and cost is not an issue. Most speakers needing that much power already help you with an internal amplifier or two - even Rosso Fiorentino's Florentia has powered bass modules.
    The extended life of the tubes - this sounds like something that he already had mastered. Is there anything 'new' that this amp implements other than big power? It is nice to know all those tubes won't be running at full blast though - that would be $$$ to have to retube.
    treitz3 wrote: »
    DSkip wrote: »
    Have you heard the 700 watt amp?
    I don't doubt he has great tube amps and have said as much. I haven't had the pleasure of hearing one yet.
    I just struggle with this particular amp being more than a bragging right for those who can afford it than an all out assault on fidelity. It will sell and owners will love it so in the end it doesn't matter.
    You're now selling Class D amps ? That certainly is a change of tune on your part. Have you heard the KEF LS50 wireless , yet ? You told me they couldn't sound that good with class D woofer amps. They do.
    DSkip wrote: »
    I have heard all of the highly regarded amplifiers. The Silver 6, Silver 7 and the Silver 9. I have also heard all of the current offerings from Bob with the exception of the Silver Seven700. It has the same basic circuitry of the original Silver 7's but with added technology and other improvements he wanted to add into the design. BTW, I believe that original MSRP for the Silver 7's back in the day was around the 22K mark to today's retail price isn't too far off the mark. They are still highly regarded by some every heavy hitters in the industry, even after all of these years. An amplifier can not have that kind of staying power if the sonics are not there.
    When and if you ever get your ears on a set, you tell me. Is it bragging right or great sound that will leave a permanent mark on your audio palette?
    I know where my thoughts lie and I will not shove my thoughts down your throat but I truly think you are doing yourself a disservice by making comments about this legendary amp just being built for bragging rights. Respectfully said.
