Turntables
12357
    mhardy6647 Posts: 35,219
    dromunds wrote: »
    Mhardy: Not sure why that portion of the DL160 manual didn't come through with my post up above.
    The vagaries of the internet :/
    Thanks for digging that out -- of course, had I a wee tad more gumption, I coulda looked it up at: https://www.vinylengine.com/library/denon/dl-160.shtml
    explicitly says (>) 47k is A-OK :)
  • megasat16
    megasat16 Posts: 3,521
    SCompRacer wrote: »
    My Lenco with linear air bearing arm at warp speed...
    https://youtu.be/YYD9CIWJELc
    That vinyl is so warp that the cart would not even able to track it unless it's on shocks.
    Nice video and I am surprised that warp of a record is still playable.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
    SCompRacer Posts: 9,121
    edited August 2017
    megasat16 wrote: »
    No damping at all. Just air bearing. I have a damping trough for the arm but prefer to apply damping only if needed.
    Post edited by SCompRacer on
  • halo
    halo Posts: 5,618
    edited August 2017
    dromunds wrote: »
    If you're heading up to Chicago-land anytime soon, try to give halo a shout and see if you can listen to his Technics SL-Q2.
    Sounds good to me! I will be moving to St. Louis in the near future, but I'd still be happy to audition gear for fellow Polkies :smile:
    dromunds wrote: »
    Sometimes you get a really good cart basically as a throw-in bonus, that's what you want to look for if possible. There used to be a saying that your cartridge was 90% of your sound quality. Don't know for sure how true that is, but carts are very important part of the equation no doubt about it.
    I agree 100% as I got lucky on more than one occasion here. The Technics SL-Q2 came with a Shure M91ED Hi-Track but the stylus is bent and the overhang was way off. Still, a Pfanstiehl 4761-DE stylus was ~ $15 and it sounds brilliant. I may have to invest in a slightly better stylus for this cart or move up to a V15 MK III, IV, or V. Ever since hearing @SCompRacer's stellar vinyl setup, I've been wanting to try a hyper elliptical or micro-ridge stylus!
    On one of my Pioneer PL-7's, it came with an ADC "Series II" cart. Underneath the Series II stylus (which was missing the needle) was a "Tech Series" cartridge body. After a little bit of research on AK, they let me know that the Tech Series body can accommodate any of the later/better ADC Styli so, here too, I can try out a pretty bodacious Nude Micro Ellipse or ViVid Line Contact stylus.
    I have been using a Grado Prestige Black and I love the sound it produces. However, I don't know that Grado cartridges are available in anything other than an elliptical stylus?
    I'm looking to reduce/eliminate the pops & ticks. I've cleaned and vacuumed my very modest record collection and I may have to try the wood glue method with a few of them. I really want that dead silent background I heard at Rich's house but I may not be able to achieve it with my current level of gear & I'm not moving any farther up the TT chain for the moment. In fact, I have 3 TT's (at minimum) that I need to sell before the big move!
  • mikeyb128
    mikeyb128 Posts: 2,885
    edited August 2017
    Lots of great responses here. The first time
    I posted for help on club Polk with turntables, I got something like this:
    Edit: holy crap had to edit about 10,000
    Times, that's what happens when posting from a phone.
    Post edited by mikeyb128 on
    2 channel:
    Theater:
  • dromunds
    dromunds Posts: 10,137
    Now that's some funny shite bro! I was a train dispatcher a thousand lifetimes ago. If you turn that engine backwards at 45 RPM it says "Paul is dead!"
  • dromunds
    Halo: those Shure M91ED carts were very popular back in the day and are pretty desirable still - wouldn't be surprised if it still commands real good coin. The cart itself should last indefinitely and as you mention new styluses can be slipped in. A person has to watch for mediocre substitute styluses tho as with the V15 types.
  • halo
    halo Posts: 5,618
    dromunds wrote: »
    I understand wha you mean. I've not heard a V15 but one would think that a micro-ridge stylus would make a significant difference over a standard elliptical stylus.
  • soundfreak1
    soundfreak1 Posts: 3,414
    halo wrote: »
    dromunds wrote: »
    The stylus on the v15 is significant as to its Ultimate Sound had the regular and the MR the MR far outperforms the standard at least in my system it did. Using a ML (micro line) now on the ATOC9ML and that design is IMHO far better for picking up the detail in the grooves.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    msg Posts: 10,463
    edited August 2017
    kharp1 wrote: »
    Reading these posts I realize I have sooo much to learn about tables. I want to jump in and start enjoying vinyl, but, I don't want to damage albums while I'm learning, especially at the price of new vinyl. Way more about tables than I could have ever imagined. Good info here.
    I can directly relate to this. I think I'd collected about $1k of vinyl before I had a working table of my own. A really good friend sent me one to use while I was trying to learn and decide on a table, but I was so obsessed with the TT reading/learning and trying to find records that I never really got around to trying it out.
    About that same time, I'd caved and tried to buy a "cheap" table just to have something to play with. It was $150 I should have saved and put toward something proper, because it ended up having tired inner workings and didn't run properly (ex., speed fluctuation issues related to the degree to which the power lever was engaged, even after clean/lube), so, good for you for holding out.
    And then even after I got my first decent table, I think it sat for several weeks because 1. I didn't have a cart, and 2. I didn't know how to mount and align the cart when I did finally get one. Just didn't make the time. Reminds me of when I was younger and there was this older gent I worked with who'd been building up this old motorcycle and he was already a couple of years into it. In my early 20s I just couldn't understand how an adult couldn't find the time to get that project completed, and further, how he could managed to NOT be spending his every free moment obsessively working on it. Nowwwww, I completely understand :)
    Post edited by msg on
  • agfrost
    agfrost Posts: 2,474
    SCompRacer wrote: »
    Just curious, have you thought about vertical vinyl?
    https://youtu.be/T8OjlcJjSEE
    I like the reply on youtube: "You'll be rich soon!"--Little did he know that you were Rich at the moment you posted the vid, and that you had been Rich your whole life! :lol:
    Jay
  • agfrost
    SCompRacer wrote: »
    Kicking out the JAAMS!
    Jay
    "dynamic arm balance" (i.e., using a spring instead of a counterweight & gravity) = play yer rekkid in any plane yez likes.
    http://www.audioadvisor.com/prodinfo.asp?number=PRVTE
    "There is nothing new under the sun..."
    Ecclesiastes 1:9b
    28700000410_174647ac5e_z.jpginverted tt by Mark Hardy, on Flickr
    agfrost wrote: »
    That made me LOL too!
    edited August 2017
    agfrost wrote: »
    Who gained notoriety for various anarchic situationist manifestations, sampling and stadium house noise?
    Who started the K Foundation?
    Who were sued by ABBA to stop an album release?
    Who doctored the Tardis?
    Who asked What Time Is Love?
    Who burned 1 million quid on the Scottish island of Jura?
    Who was prevented from throwing buckets of sheep's blood over the audience at the 1992 BRIT Awards?
    Who fired a machine gun with blanks over the heads of the audience on the stage of the 1992 BRIT Awards?
    Who dumped a dead sheep at the after awards party?
    Who were AKA The Justified Ancients of Mu Mu, The JAMs and The Timelords?
    Who kicked out the JAMS?
    King Boy D and Rockman Rock of the KLF!
    You back in skool? We need to spin some tunes!
  • kharp1
    kharp1 Posts: 3,453
    OK, here's a question...any of you guys ever have any experience with an Elac Micacord?
    edited August 2017
    kharp1 wrote: »
    Vintage or current production? Early were idler drives, current are belt.
    Early, more than one model...
    http://audiokarma.org/forums/index.php?threads/elac-miracord-tt-share-all-about-em.390203/
    Current....
    http://www.digitalaudioreview.net/wp-content/uploads/2016/05/elac_miracord_90_1.png
    kharp1 wrote: »
    Couple of the 1960s automatics have passed through here -- they're OK. Complicated, as one might expect. Sort of Dual-like, but a notch cheezier (not that the Duals of that era weren't already pretty cheezy).
    Radio Shack sold 'em in the US, too -- sometimes under their Realistic brand, sometimes as Miracords. The US importer was Benjamin (as, in those days, was United Audio Dual's).
    source: www.radioshackcatalogs.com (1977)
    source: www.radioshackcatalogs.com (1970)
  • kharp1
    kharp1 Posts: 3,453
    Oh, it's vintage. Can probably get it for free. Has a Shure rebranded cart.ec8qgtbrnvpl.jpg
  • kharp1
    kharp1 Posts: 3,453
    Didn't know if it was worth trying, or, a stay away from piece.
    edited August 2017
    Free is good! Like any vintage thing, some maintenance would be in order. Clean and oil. Is that the table in question? If so good to have the solid spindle. I don't care for changers myself. That is stacked LP's in queue.... IIRC, some or all models didn't have damped cueing so you go gently with the arm lifting mechanism.
    Idlers can be refurbished depending on condition. If idler is dry and cracked you'd have to source one.
  • kharp1
    kharp1 Posts: 3,453
    That is the unit
  • kharp1
    kharp1 Posts: 3,453
    I like the look of vintage, but, don't want to get in to costly rebuilding of a piece that will still be "mediocre" st best. Would rather pass and wait. I'm not against putting money in to the right piece to get it to its best if it's going g to produce results and add some potential resale to it.
    It has aged nicely. Respected and taken care of.
    I refurbed a Yamaha YP-D10 that wasn't covered and dust cover was off when a room was repainted.
    edited August 2017
    kharp1 wrote: »
    Well worth free :)
    Be prepared for cleanin' and regreasin' if it's like most of the vintage European automatics ;)
    EDIT For free, it might be worth picking up for the cartridge -- looks like a Shure of some sort (?).
    That looks like a pretty serious piece of hardware behind it -- I'm thinking Pioneer SX-1010 (if not a Pioneer integrated amp?).
  • kharp1
    kharp1 Posts: 3,453
    This guy has a basement full of vintage gear. Floor to ceiling shelves stuffed full of great quality, great condition vintage stuff.
    edited August 2017
    Would love to take a nostalgia trip in that basement!
    I'd still use a speed checker on it. My Lenco has adjustment locks for 16, 33, 45 and 78. The adjustments change position of idler against a tapered motor shaft. Now that I have a tachometer controlled power supply, speed control is automatic.
    Also there are 50Hz and 60Hz model turntables along with multi-voltage wiring (110, 220). Running 50Hz setup on 60Hz will result in few percent speed variance.
    My fav go to speed checker is a KAB SpeedStrobe. It allows for needle in the groove speed checking. Strobe is battery operated so it is not affected by mains variance like a light bulb would. They also use large numbers which are easier to read for my old eyes than tiny lines close together on older speed checkers.
    You can use phone apps too.
    https://www.kabusa.com/gif/strobe.jpggqbxobpnabeh.png
  • voltz
    voltz Posts: 5,384
    edited August 2017
    I started with a Pro-Ject Debut Carbon with a Ortofon red MM cartridge and really liked it.
    I upgraded to a Project 2Xperience classic with a Sumiko Blue Point #2 Cartridge which is a high MC cart.
    now it is available in the SgPRO-JECT - 2Xperience SB Sgt. Pepper's - Beatles Special Edition Turntable
