Why SACD failed
12346
    pitdogg2 Posts: 27,029
    BlueFox wrote: »
    Of course the SACD player can also flake out. At least having duplicate files is trivial. Try copying your SACDs to have backups.
    yes of course it can, but you still have the physical media to play. just having a DSD file of it if it goes for the most part its gone. buy it again. I still have CD's from their inception my kids want to borrow all the time. I tell them I'll make you a copy you are not getting the CD it CAN'T be bought again in most cases. Of course you can get the remastered "maybe" but they I have found are just not the same and for the most part not a better rendition of the original.
  • mrloren
    mrloren Posts: 2,474
    For me SACD is a little better than CD. I only own a couple of doubles and one is Scorpions Moment of Glory. This has a little more depth than CD with the 5.1 mixing vs. the 2 channel of the CD.
    Is it worth trying to replace my entire 2,000+ CD collection for? Heck NO! I would and have been looking to replace some of my favorite CD but they never went to print in SACD
    UFO Obsession and Peter Gabriel SO are two more I would like to have.
    look for Peter Gabriel Shaking the Tree it has some gems very well done as are all of his. They're out some a lot more plentiful than others.
  • BlueFox
    BlueFox Posts: 15,251
    BlueFox wrote: »
    No, it is not gone if you make backups. I have 5 hard drives, and one I keep in my car, to insure I don't lose the files. Also, I installed HDTracks on my work computer so I could download a purchase at work. Once that finished it then proceeded to download every purchase I had made in the past on my home computer. That was surprising.
    Of course the same argument can be made for both plastic disks and hard drives. Basically, they both are the same thing. They are simply a device to store music files, nothing more and nothing less. Its just the HD can store a lot more files than the plastic disk.
  • BlueFox
    Converting pre-1980 analog to digital has also improved tremendously over the last 25 years. There are large box classical CD sets of Mercury Living Presence and RCA Living Stereo (et al) that have been ported over from analog to digital. I have many of these CDs and they sound amazingly good.
    The SACDs of these are nice. Back in the 50s they recorded three channels; left, right, center. After 'stereo' won that format war then they were released with only the L/R tracks. With SACD, they were released as recorded, and sound great in a HT.
  • [Deleted User]
    [Deleted User] Posts: 10,716
    I have a UFO Obsession :o
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited March 2017
    K_M wrote: »
    I think you may be misunderstanding what they meant. I did also at first.
    I understood the authors' meanings and motivations very well.
    K_M wrote: »
    They cherry picked really great recordings to use to make most SACD's.
    It is well understood that excellent recordings must be used in audio equipment evaluations. What should not have been done was inducing the reader to assume, in the absence of credible evidence, that the SACD signal output from the ABX switch box was indistinguishable from the output straight from the SACD player's outputs.
    K_M wrote: »
    I think they mean, at first they attributed the Great sound, to being SACD< but in fact, it was simply just a lot of really great recordings that were picked to make the Various SACD's they happened to use.
    No, they meant exactly what they concluded:
    ****SACD sounds impressive when it is listened to by itself, however, when an SACD player's output is downgraded to CD quality, it still sounds the same as the regular SACD output. Therefore, SACD offers no real performance advantage over 44.1k/16 bit CD.****
    K_M wrote: »
    Re-read it again, I read it 3 times, till I got what they meant also. It is worded very oddly.
    The conclusion is not worded oddly. The test is constructed oddly.
    The oddest thing is that two pieces of equipment were added that would not be found in an actual listening environment: 1) an ABX switch box, and 2) an Analog-to Digital-to Analog converter. The paper did not address the sonic accuracy of either piece of equipment. Apparently, the authors hope the reader will assume that the switch box and the A/D/A converter imparted no audible sonic effects. In the absence of credible data, this is the same as a fiction writer requiring suspension of disbelief in their readers.
    Secondly, a proper test of SACD's efficacy in better sound reproduction would have been to compare the same recording, from the same recording equipment chain, in SACD and CD versions. This is what I did with my vinyl conversions. I made DSD64 and then PCM copies at various sample rates and then compared them with respect to stereophonic performance and qualities.
    This test did not compare a master recording rendered in two digital formats: SACD and CD. It compared the analog output of an SACD player to a degraded version of that analog output as they came from an ABX switch box.
    I find it odd that no comparison of the sound of the SACD player's straight output compared to the SACD players output through the switch box was presented. Shouldn't the authors have evaluated this?
  • DarqueKnight
    So, they admit the test was rigged. Thanks Ray, I don't need to read any more of it.
    No, no, no. They did not admit to the test being rigged. They just wanted everyone to know that there were devices available that can water down the resolution of SACDs to CD level.
    Why are you so mistrustful of "science"? :'(
  • BlueFox
    I probably missed it, but I don't understand the logic behind degrading an SACD to CD quality, and then concluding SACD is no better than CD. LOL.
  • DarqueKnight
    edited March 2017
    Danny Tse wrote: »
    I still haven't invest in an expensive SACD player. My best performer is the Pioneer Elite DV-79DVi DVD/SACD/CD player. Its MSRP was $1000.00 but it was being cleared out at $150.00 new because it doesn't do Blu-ray. I am saving it just for playing SACDs.
    Today, you can pick up a Sony Blu-ray player that can do SACD for $100.00.
    Some, maybe a lot of, inexpensive universal players do not have a true SACD DAC stage. They transcode the SACD DSD bit stream to PCM before it is sent to the DAC stage. I wouldn't expect any sub-$200 universal player to have a true SACD DSD DAC stage.
    Your DV-79Dvi is a true SACD player.
  • [Deleted User]
    ^^^ See, tested on millions | CD = SACD
  • kharp1
    kharp1 Posts: 3,453
    Quote:
    Once you read the paper, you will understand completely. In summary, they took the output of an SACD player and fed it to an ABX switchbox. They then tapped into the SACD output, fed that into a downconverter which converted it to 44.1/16 bit output, then fed that into the ABX switchbox.
    End quote
    So you mean to tell me they took two SACD's, down converted one, and, called that a serious and conclusive test? A more appropriate comparison would have been SACD directly compared to a red book CD. Flawed.
  • K_M
    K_M Posts: 1,632
    @DarqueKnight
    I still think you are not getting what they are saying.
    They were saying SACD sounds impressive listening to it by itself, but they mean based on that they were using unusually great sounding recordings.
    Better than run of the mill CD recordings you normally find.
    That explains why when they switched back and forth they could not find a sound difference. The great sound was attributed to the "Recording alone", not to it being SACD.
    They are trying to say, that great recordings will sound great no matter what, and at first they attributed the great sound to it simply BEING an SACD.
    Read it using my explanation of it and it all makes sense. :)
    @Your comments about the test. They made the test extremely simple, to eliminate the variables you mention as being a more realistic test.
    If they used separate CDs and SACD discs, then one would question if they were mastered the same or not, or some other difference, then try to use that to discredit the validity of how the test was run.
    I am betting worrying about the actual switch box is a red herring also.
  • [Deleted User]
    OMG! So bit depth has an advantage. So like, remove the advantage and the stuff sounds the same! This is starting to sound the same as "cables don't matter."
    I'm sure they think they mean well. :#
  • kharp1
    kharp1 Posts: 3,453
    Bed? What's that. Twelve straight 12 hour days a 2 hr road trip on no sleep for granddaughters birthday and I'm back in the Dr office this morning. Can't shake whatever I've been fighting for the last 2 months.
    So, you mean to tell me...
  • cfrizz
    cfrizz Posts: 13,415
    OMG, it's too early for my brain to comprehend this, but this is what I picked out.
    They picked well mastered music to put the cd/sacd music to the test. Well DUH, we all know that it starts with the mastering, if a crappy job is done, it will sound lousy no matter what the format is.
    Excellent mastering = excellent sound/playback no matter what the format is.
    edited March 2017
    cfrizz wrote: »
    Yes it all starts with the master. For example take the Cars first album i have both CD and SACD both use the same master. SACD sounds much better. I only have one bad sounding SACD it has no CD counterpart to compare to.
    Out of all my SACD's I have that I have duplicate CDs, SACD's are all a better listening experience. Much more analog like. I believe that Sony was really trying to make them more LP like in the sound with higher dynamics.
    treitz3 Posts: 19,979
    edited March 2017
    Hello, if you don't mind me asking, which one pitdogg2? I'd like to know which one to avoid purchasing.
    treitz3 wrote: »
    Alice in Chains best. One of the very first SACD's out. I have all the Alice CD's those songs are much better on the original CD. They upped the bass for the SACD version it just overwhelmed the SACD.
    Ouch. Duly noted. Thanks man.
    The XRCD I have of Dire Straights "Brothers in Arms" album, they pretty much did the same thing. Not with the bass, but with the treble. They made it a little too hot on the top end for my liking. I usually just play the RB or go to LP for this one.
    tonyb Posts: 33,072
    After listening to all the responses, this is what I notice. We all have our various preferences for music, but the crux of the matter always comes back to the quality of the recording. Many of us here have heard quality recordings on redbook cd that can equal if not surpass some on SACD.
    Now, finding the various music you like, with a decent recording of it, can spread across many formats. So...you need a TT to play those great recordings on vinyl, a SACD player for those great recordings, a standard cdp, a blu=ray player for those concert discs, and a digital system for those higher rez recordings also and all that entails.
    You have music spread out across many formats that requires a good investment in front end electronics too. Doesn't make sense to me. Do you switch speakers too because xyz recordings sound better on one pair over another ? Well, leftwinger does, or used to....lol.
    I get it though, many of us already have the physical media we own across many formats, why buy it yet again. Digital in my view, at least has the potential to bring all those formats together in one file that will sound just as good as any of them separately.....IF....the recording studio masters to it. That's a big if, I know. It would appear to me that starting with a piece of gold, and having to downmix to silver for other formats would be more beneficial than starting with lead and trying to make Gold out of it. Know what I'm saying ?
  • Gatecrasher
    Gatecrasher Posts: 1,550
    If the definition of a technology "failing" is that it failed to become universally accepted or become profitable for the companies promoting the technology... then SACD has failed. There is no disputing that fact.
    The companies behind SACD didn't decide to develop it and invest millions of dollars into the technology just to be good Samaritans for a small niche audiophile market. Just like DVD-A they had hoped that it would eventually surpass CDA as the industry standard but they didn't play their cards right and for one reason or another (which is debatable) never succeeded at their objective.
    So in reality even though technically SACDs are superior to regular CDs, it has failed economically. In order for SACD to truly become successful it would have had to replace the older CDA format completely. Now that we are solidly in the digital age where all physical media is in decline, the writing is on the wall.
    Just because a technology is better doesn't prevent it from becoming "dead" with consumers.
    It would be pretty-foolish to rush out to invest your retirement savings in SACD stock.
    F1nut Posts: 51,739
    It seems some of you either missed Danny's post or are ignoring it. Regardless, here it is again.
    Danny Tse wrote: »
    Whoa!! I can't believe the author of the article and the website that published the article didn't even ask me for permission before using my photo off of my Flickr account.
    Back to SACD, what the author failed to mention:
    • 2015 was the biggest year for SACD in terms of new releases, with over 900 new releases worldwide. 2016 almost matched the number of new releases for 2015. Over 11,000 SACD titles have been released worldwide.
    • SACD survived the format war with DVD-Audio, the iPod, and it looks like it will outlast Blu-ray Audio as well. The format is closing in on its 20th anniversary.
    • SACD was designed primary as a two channel stereo source. The multi-channel DSD mix and the addition of the CD layer were afterthoughts. Most of today's top-of-the-line SACD players are 2 channel stereo only models.
    • All of the major music labels, i.e. Sony Music, Universal Music and Warner Music, continues to support SACD today. In the US, their support are through licensing their respective music to reissue labels such as Mobile Fidelity, Audio Fidelity, Analogue Productions, etc.
    Today, there are still 3 SACD pressing facilities in the world....Japan (Sony), Austria (Sony) and Germany (Sonopress). Maybe Sony should consider firing up its SACD production facilities in Indiana again.
    SACD HAS NOT FAILED
  • Gatecrasher
    Like I said, I wouldn't go investing your 401K in SACD stock.
    The two SACD pressing plants in the United States closed because there wasn't any demand for SACDs in the American market. You guys can dream all you want but the demand for physical media is on the decline and while SACDs are awesome, most believe SACDs will die altogether in a few more years and be replaced by DSD downloads.
    In the meantime, I still prefer physical media but that's because I'm not a Millennial.
  • DarqueKnight
    K_M wrote: »
    @K_M
    The authors claim to provide a scientific report on the sound quality differences between SACD and CD. A scientific report must be clear, concise, and scientifically valid with repeatable results by other independent researchers. You noted that the conclusions were oddly worded, and you are reaching and searching "between the lines" to make sense of what they said. Therefore, the scientific criteria of clarity and lucidity were not met.
    Many details of how the test were conducted were left out, such as what were the stereophonic performance parameters evaluated, how long were music samples listened to, and how experienced and proficient the test subjects were in evaluating the spatial and quality aspects of images in a stereophonic sound field.
    K_M wrote: »
    If you think that degrading a source signal and sending signals through a switch box with questionable transparency is realistic, I must question how you listen to music at home.
    By the way, that ABX switch box was a product that was developed and offered for sale to the public. It was a commercial failure.
    K_M wrote: »
    It would not have been too difficult to find SACDs and CDs that were produced from the same master tapes and produced by the same production team, and...RESIDING ON THE SAME DISC! For example, the 1997 hybrid SACD release of Dave Brubeck's "Time Out" had a CD layer and an SACD layer mastered by the same production team from the same master tapes:
    "This CD is a hybrid Super Audio CD that has two distinct layers. One layer contains a newly remastered stereo mix that plays on any CD Player. The other layer contains a high-resolution Super Audio CD (SACD) version and a 5.1 Surround version of the same repertoire that work on SACD-compatible players. Both layers have been remastered from the original tapes to deliver significant improvements in sound quality for all listeners. © 1997 Sony Music Entertainment Inc."
    https://www.discogs.com/The-Dave-Brubeck-Quartet-Time-Out/release/2980812
    It is interesting to note that this hybrid CD/SACD disc was released in 1997, two years before SACD players became generally available. I wonder if Sony had originally planned to release its high end SACD players in 1997, but they were delayed for some reason until 1999. Sony did release two SACD-only versions of "Time Out" in 1999: a 2 channel disc and a 2 channel/multichannel disc.
    Another well known hybrid SACD example is John Coltrane's "Blue Train" released in 2003. The original recording session and the CD and SACD layers were produced by the same person, Rudy Van Gelder:
    "Recorded By, Mastered By, Remastered By – Rudy Van Gelder."
    "SACD and CD mastering by Rudy Van Gelder at the Van Gelder Studios, Englewood Cliffs, NJ."
    https://www.discogs.com/John-Coltrane-Blue-Train/release/1528284
    At the time of this report (2007) there were many hybrid SACD titles to choose from across different musical genres. There was no need to degrade an SACD output to CD resolution because CD versions of SACD titles ON THE SAME DISC, MADE BY THE SAME PRODUCTION TEAM, were conveniently, immediately, and abundantly available.
    K_M wrote: »
    That is a bet you would lose. I find it bizarre that you would think that concern about the sonic transparency of a switch that test signals pass through is an insignificant point.
    Designers of high end, high performance audio equipment try to avoid the use of any type of mechanical switch in the signal path because of the electrical noise such switches cause when contacts are made and broken. In the case of a mechanical switch passing two stereo signals, there is also the possibility of crosstalk to deal with. Low noise mechanical switches, and particularly low noise multichannel mechanical switches, are very expensive.
    The designer of my Pass Labs XP-30 preamp chose to avoid the use of a mechanical switch as the volume control. He custom designed a low noise electronic volume control.
