SDA upgrade thread 2
honestaquarian
Okay this is what happens when you try to do this type of thing from your phone instead of a computer. Somehow this thread landed in the for sale/classifieds section. No idea how that happened.
ANYWAY this thread is for sharing information and tips and pics about upgrades on your SDA's. Since we just had a major group buy on the dreadnought transformer and @toolfan66 stepped up and made some more of his much coveted cases and rings. There are about to be a lot of upgrades and mods going on this year. Let's consolidate it all in one thread.
Go ahead a post some pics!
I had a question on Dreadnought wiring, so I'm pasting stuff from previous build posts here:
Binding post connections from DarqueKnight's original 2008 Dreadnought thread. Note this is using the 800VA, but the 1000VA is the same scheme.DarqueKnight wrote: »Right Pin = Red/Yellow
Right Blade (Negative Speaker Terminal) = Black/Orange
Left Pin = Grey/Brown
Left Blade (Negative Speaker Terminal) = Blue/Violet
Neutrik connections from F1nut's Neutrik Dreadnought. I believe this arrangement is consistent with Larry's latest batch of cases. For same-side Neutriks with 90deg connectors, see ER308L's post directly above.
Red/Yellow (right pin) to 1+Is there a chart here or one that you can post that tells me which wires I should soldered to each numbered tab?
Black/Orange (right blade) to 1-
Grey/Brown (left pin) to 1+
Blue/Violet (left blade) to 1-
DarqueKnight's Dynamatted base
F1nut's Dynamtted top
Other quicklinks:
agfrost's use of slightly different Neutrik's, Fastons, bolt info (use SS or nylon)
Parts discussion on page 10 above.
Larry's Dreadnought cases here. Only 5 left!
F1nut's outriggers and spikes
agfrost's cabling (you may want to order an extra pair of male connectors)
Where do you get the speakons again? -
Lots of places carry them including Parts Express.Political Correctness'.........defined
President of Club Polk -
Aren't there more than one type? -
@F1nut
Where do you get blackhole5? -
sonic craft do 24" x 27" or parts express do 12' x 18" sheets..
There's only one kind of BH5. You may be thinking of Sonic Barrier. I got mine from Sonic Craft.Political Correctness'.........defined
Do you have to move the white batting over when you install the BH5?
The batting goes in the exact spot as it did from the factory.The bh5 installs on the back wall and the batting will cover it when in place.I removed my batting,installed bh5 and then reinstalled batting.2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
honestaquarian wrote: »Do you have to move the white batting over when you install the BH5?
There's no way you wouldn't figure that out on your own.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
WHY I OUGHTA!!
The ONLY upgrades that I've even done to any of my Polks was to replace the SL-2000's and SL_3000's with the RDO series. So this is ALL VERY NEW to me.That's why I started this thread,because I KNOW I cannot be the only one.
I know you're not an idiot. You'd figure it out. Someone that's never driven in their life would figure out you need to remove your seatbelt to get out of a car, same difference. The batting would be directly in your way.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Thanks for the bass ackwards compliment
That's not what I was talking about though. I meant do you have to move it to the side permanently or something. -
Since the BH5 is supposed to absord the backwave of the drivers that is why I was wondering if you have to permanently move the batting out of the way to the side in order for it to work properly once it was installed.
FWIW ---
On your crossover build, we are doing dual SDA cables, NL4 Speak On - P = 1+/2+ B = 1-/2-
The NL4 connector is wired up in a shotgun configuration in case you ever want to go wild with your SDA cable in the future...
So as long as your wiring corresponds to that, you will be fine
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
honestaquarian wrote: »Since the BH5 is supposed to absord the backwave of the drivers that is why I was wondering if you have to permanently move the batting out of the way to the side in order for it to work properly once it was installed.
no it stays in the same place it too slows the back wave, its just the BH5 makes it mo better like you just added 10X the amount of poly which you couldn't really do. -
@pitdogg2
Thanks!FWIW ---
@VR3
Trey you're speaking French and talking dirty to me again!
MASHER!!! -
@VR3
I'll have to get two more speakon terminals for the dreadnought case right? -
Man installing these Neutriks LOOKS easy..............(*drilling these cases turned out to be more work that it looked like because they are high quality and much thicker metal than they appear to be*) Good quality job @toolfan66!!
If anyone needs or wants some black colored screws for their speakons I have plenty
Now time to add the Blackhole 5 and seal the Cabinets and glue the woofers
Thanks for the help with the BH5 @muncybob -
I honestly thought they stopped making the 3.1's in 1991
Nope, my 2.3TL's were made in June 1992.Political Correctness'.........defined
I could use some of those screws if you got some to spare. I even got some BH5 in route thanks to Muncybob. I will be following your thread.Home Theater
@gudnoyez
As you can see I have PLENTY of screws. I only used four of them for the speakons and I'm done.
PM me and lets work something out. -
Oh and BTW I started this thread for ANYONE who wants to share their SDA upgrade experiences.
Not just me. -
What a mess
Okay this isn't gonnna work. When I went to the hardware store all that they had was some squeeze tubes of the power grab. I'm gonna have to go to another store and find the kind you put in the gun
