Group Buy '16: Dreadnought Avel Lindberg 1000VA Isolation Transformers
1…89111314…17
    pitdogg2 Posts: 27,877
    quotidian
    Going to have to tuck this away and whip it out unexpectedly on some unsuspecting chap :pB)
  • edpot1
    edpot1 Posts: 4
    heiney9 wrote: »
    Much appreciated edpot1. $3.41 in fasteners plus $9.61 in shipping seems kind of silly. I will probably go to my local hardware store to get the fasteners. Thanks for including the dimensions and not just the Fastenal part number.
    Thanks again Jay for sharing.
    I did go to Home Depot yesterday and wasn't able to find similar parts. Once I have the case and the transformer, I *might* be able to find parts there that would work - the sizes obviously don't have to be exactly what I posted. But given what I know right now about the dimensions, I'll probably go with Fastenal.
    F1nut Posts: 52,377
    edited January 2017
    To mount the sockets properly those are the correct sizes, it's what Neutrik calls for. I've seen others use improper sizes, which looks like dog poo to me. YMMV.
    txcoastal1 Posts: 13,520
    heiney9 Posts: 25,672
    They were special order only and you missed the group buy. Perhaps someone may have one to sell. If you got to page 1 you will see several links that explains the use and build of one of these. Get your learn on.
    edited February 2017
    I just broke down and bought the fasteners from Fastenal and paid the $10 shipping for $3 worth of stuff. After thinking it through it made sense. I know I could have sourced stuff locally, but my time is worth something and frankly I just want to be done with it and off my mind.
    I also decided to get all the Neutrik parts from Parts Express. Along with the other misc parts including red techflex and gold female disconnects. I was thinking I have Canare 4S11 at home currently for my SDA cable, but it turns out it's 4S8, a tad smaller gauge but it should suffice.
    I was going to get a 12' piece of 4S11 at Performance Audio and the Neutrik parts, but I'm betting the difference between 11g or 13g wire diameter over a 5 foot run on each side for the SDA signal will be negligible.
    I also included one of these if I have issues w/ the tranny or want to run w/o it. Or simply to make a comparison before and after.
    http://www.parts-express.com/neutrik-nl4mmx-speakon-cable-to-cable-adapter-4-pole--092-196
  • agfrost
    agfrost Posts: 2,493
    Hey that coupler is nice! Cool find.
    Jay
    Toolfan66 Posts: 18,410
    ONLY 7 CASES LEFT!!!
  • 250GTLusso
    Wait, what?! Do you still have the 2 I ordered? Did I miss something?
    HT
    Adcom GFP-565 Pre-amp, Adcom GFA-565 Mono Block Amps (Front), Adcom GFA-585 Amp (Side), Adcom GFA-555 Amp (Rear), Adcom ACE-515, Pioneer CLD-3070 Laserdisc, Sony CDP-605esD, Sony BluRay BDP BX59, Samsung 50" Plasma, Polk Audio SDA SRS 1.2TL Front (Walnut), Polk Audio SDA SRS Side (Walnut), Polk Audio SDA SRS Rear (Walnut).
    2 Channel (Living Room)
    Adcom GFP-565 Pre-amp (w/Big Sky Audio Upgrades), Adcom GFA-565 Mono Block Amps (w/Big Sky Audio Upgrades), Adcom ACE-515, Sony CDP-705esD, Magnum Dynalab FT-101A Etude, Polk Audio SDA SRS 2.3TL (Walnut), Polk Audio SDA SRS 2 (Walnut), STAX SR34 Electret Earspeaker System.
    2 Channel (Office)
    Adcom GFP-555 Pre-amp, Adcom GFA-555 Amp, Sony CDP-605esD, Adcom GFT-555 Tuner, Polk Audio SDA 1C (Walnut).
    2 Channel (Garage)
    Hafler DH-110 Pre-amp, Hafler DH-220 Amp, Sony CDP-505esD, Hafler DH-330 Tuner, Polk Audio SDA 2B (Walnut).
  • [Deleted User]
    [Deleted User] Posts: 0
    So Larry gave me a couple different face plates to mess around with after work. So I thought why not put both connections on one side? I took a blank one and machined a counter bore for each and the appropriate hole locations.
    Now I have a blank front facing plate that I'll eventually laser etch the Polk Audio logo on.
  • nspindel
    nspindel Posts: 5,343
    I still say we should come up with a Dreadnought logo.
    nspindel wrote: »
    We might just be able to do that soon, as we just got an Epilog Laser at the shop.
    Won't be anytime soon as we still have to get it up and running for our customers product..
    Looks good Brian!!!
  • nspindel
    That's fine. You don't need to do a run of the boxes. Just make the faceplates. Didn't you used to have something like that? Didn't the crossover mounting plates you used to do have laser etching?
    No, I sent them out to be silk screened..
    Exactly, just the face plate..
  • vcwatkins
    vcwatkins Posts: 1,992
    I had a question on Dreadnought wiring, so I'm pasting stuff from previous build posts here:
    Binding post connections from DarqueKnight's original 2008 Dreadnought thread. Note this is using the 800VA, but the 1000VA is the same scheme.
    Right Pin = Red/Yellow
    Right Blade (Negative Speaker Terminal) = Black/Orange
    Left Pin = Grey/Brown
    Left Blade (Negative Speaker Terminal) = Blue/Violet
    Neutrik connections from F1nut's Neutrik Dreadnought. I believe this arrangement is consistent with Larry's latest batch of cases. For same-side Neutriks with 90deg connectors, see ER308L's post directly above.
    Is there a chart here or one that you can post that tells me which wires I should soldered to each numbered tab?
    Red/Yellow (right pin) to 1+
    Black/Orange (right blade) to 1-
    Grey/Brown (left pin) to 1+
    Blue/Violet (left blade) to 1-
    DarqueKnight's Dynamatted base
    F1nut's Dynamtted top
    Other quicklinks:
    agfrost's use of slightly different Neutrik's, Fastons, bolt info (use SS or nylon)
    Parts discussion on page 10 above.
    Larry's Dreadnought cases here. Only 5 left!
    F1nut's outriggers and spikes
    agfrost's cabling (you may want to order an extra pair of male connectors)
    F1nut Posts: 52,377
    ER308L wrote: »
    Just wanted to point out that the transformer sounds better in the vertical position, hence the reason you see pretty much everyone else's that way.
  • [Deleted User]
    I have alot of different options that I want to try out before I make my spikes and the rest of that apperatus. Does anyone know why it makes a difference having it vertical?
    F1nut Posts: 52,377
    I believe Ray explained that in here somewhere. Magnetic fields or some such.
    EndersShadow Posts: 17,753
    I believe Ray explained that in here somewhere. Unicorn dust, double rainbow mist, fairy tears, the alignment of the space time continuum, and the secondary waves of th butterfly effect were the cause of the magic.
    Fixed it for you @F1nut....
    PS I'm bored so ignore my comment as an attempt at humoristic banter
    Only 4 Cases Left... :)
  • kmeek
    kmeek Posts: 225
    For your Dreadnought project:
    Just an FYI: since several forum members recommended Canare 4S11 speaker cable I picked up some from Performance Audio.
    While it is not on sale (@ $1.16 per foot which doesn't seem like a bad price) they do have a free shipping February event going on right now (with no minimum order which is nice)
    http://www.performanceaudio.com/browse/Speaker-Wire/170/
    Canare 4S11 Star Quad Speaker Cable (4 x 14-Gauge)
  • kmeek
    kmeek Posts: 225
    FYI, for your Dreadnought project:
    Due to forum member suggestions I picked up some Canare 4S11 speaker wire from Performance Audio. It is not on sale but $1.16 per foot did not seem like a bad price. The nice thing though is they have a free shipping February event going on right now (so no minimum order).
    Here is the link:
  • kmeek
    kmeek Posts: 225
    Here is the link:
  • kmeek
    kmeek Posts: 225
    Here is the link:
  • kmeek
    kmeek Posts: 225
    Sorry about the duplicates..... Was having issues posting and then it posted four..... :(
    Anyone start seeing these yet??
  • ptrooper
    ptrooper Posts: 674
    Nothing seen here so far
